RFLink for 868MHz X3D
Posted: 13 Nov 2019, 05:30
I’ve been reading up on the support for 868 MHz devices and from my understanding the Aurel RTX-MID868-OOK is the only supported transceiver for this frequency with RFLink?
I want to use the 868 module to connect to my AeroFlow radiators which are using X3D. Aeroflow (from Germany) have radiators with X3D at 868 MHz as well as radiators with their own protocol at 433MHz. Mine came with the apartment and are of the X3D type.
I live in China and sourcing the Aurel transceiver is a pain, and it takes a very long time to receive it. Or does anyone know of a source in Japan/South Korea/HK/TW?
I also see that the RXB6 receiver is supported for 433MHz, this receiver also exist for 868MHz, will it work with RFLink?
There are also the Aurel RTX-8X3V-ASK with the same pinout, but in 3V, would that one work if voltage is converted to 5V?
A receiver module like the DreamLnk DL-RXS868R with the same pinout as the Qiachip WL101 would be great if they were to be supported, it would make 868 so much easier to get components for. The DL-TXS868T looks like a great transmitter for 868MHz as well.
If the devs would like to support the DreamLnk modules or some other easily sourced 868 modules, I would be more than happy to send samples from here in China. I would also happily develop the support, but since RFLink is not open source that seems difficult.
Thank you for a great piece of software!
