OLEDCMD command and nb of chr in command display
Patou
#1 Post by Patou » 01 Dec 2019, 19:06
Hello friends,
I am using actually ESP_Easy_mega-20191116_normal_ESP8266_4M1M.bin
Probably 1 bug :
It seems that the command OLEDCMD, on /,off, /clear is not working in this version nor in rules nor in direct command
Limitation :
The nb of chr in the commands line seems limited to 32 chr. ( this is not the nb of displayed chr !!)
This limit the length of the variable names specially when adding #transformation# and #Justification#
Is it a big work to extend those line to 65 chr for example ?
Patou
Re: OLEDCMD command and nb of chr in command display
#2 Post by TD-er » 01 Dec 2019, 21:56
Please give the exact command you try to send (including spaces)
Post them here in the [ quote] tags.
#3 Post by TD-er » 01 Dec 2019, 22:03
Hmm in the discussion on Github on another issue you have the OLED Framed plugin. The OLEDCMD is for the other OLED plugin.
Are you sure you're using the correct command?
Patou
#4 Post by Patou » 01 Dec 2019, 22:19
this is the command :
On Up#State=11 do
  OledCmd,on
On Down#State=11 do
 OledCmd,off
Is it possible to switch OLED frame plugin with OLEDCMD,off /on ?
Patou
#5 Post by Patou » 01 Dec 2019, 22:25
Sorry it works with OLEDFRAMEDCMD !!
Thanks for your help !!
Users browsing this forum: Bing [Bot], Google [Bot] and 15 guests
