Reboot ESP32 with ESPEASY from remote?
Alpensepp
#1 Post by Alpensepp » 02 Dec 2019, 06:41
Hi!
I have an ESP32 dev with ESPEASY running in a remote place.
Version: ESP_Easy_mega-20191116_esp32test_4M316k
The ESPs webserver gets stuck irregularly, I cant open it any more.
But I still can ping the ESP and it sends data via MQTT.
Is there a way to reboot it without use of its website?
Re: Reboot ESP32 with ESPEASY from remote?
#2 Post by TD-er » 02 Dec 2019, 08:43
If you portscan it, does it react on port 80?
If so, you could try to send just the reboot url: http://ip/?cmd=reboot
Do you have any idea at what version this started to happen, as you state it happens regularly?
#3 Post by TD-er » 02 Dec 2019, 10:14
I fired up my test ESP32 and it can be reproduced quite easily by clicking the disconnect button on the web interface.
I will make an issue for it.
port 80 of the web interface does not respond anymore, so the web server is not running so it seems.
Alpensepp
#4 Post by Alpensepp » 02 Dec 2019, 11:43
TD-er wrote:
02 Dec 2019, 08:43
When I do a portscan, port 80 is open. But it does not react to any command.
I just started with ESP32s and therefore started with ESP_Easy_mega-20191116_esp32test_4M316k .
When the ESP32 freezed this night, it had to do nothing special. It sent temperature data from a bme280 via MQTT every hour. Suddenly it stopped sending data.
It is quite important for me, that the ESP32 and ESPEASY run stable, because I have 1 1/2h drive to the place, where it is running to restart it.
Is it a common issue for an ESP32? Should I go for an ESP8266, instead? The ESP8266 I run at home seem to run stable.
#5 Post by TD-er » 02 Dec 2019, 11:57
For now it may be better I guess.
I've been testing it here now and it does not seem to act well on WiFi reconnects.
I also see a lot of reconnect issues to the MQTT broker if it does have webserver issues.
And to be honest, I have not tested the ESP32 builds very well.
Alpensepp
#6 Post by Alpensepp » 02 Dec 2019, 16:13
OK, thank you for the quick reaction. I will go for the 8266.
Are there plans to fully support the ESP32 in future?
#7 Post by grovkillen » 02 Dec 2019, 17:17
Alpensepp wrote:
02 Dec 2019, 16:13
Yes but first the stable release (very soon) and then the new GUI. We're only two guys and it's been taking longer than expected to get a grip of the project, but now we're gaining momentum.
#8 Post by TD-er » 02 Dec 2019, 17:19
I've been running tests on ESP32 since your post this morning, but I'm quite worried about the WiFi issues's I'm seeing.
Sure there are plans to support ESP32 and I was under the impression that it was quite OK-ish for the ESP32 even though I have not tested a lot with it.
But now I'm not convinced we should include ESP32 as officially "released" on the upcoming release of ESPEasy.
The WiFi stability is abominable right now and I truly cannot imagine why I haven't seen more issues with it.
