Sonoff 2 Gan GPIO,5 at 1 when reboot
I have just upgraded my Sonoff 2 gangs used for opening/closing my shuttters to EspEasy mega 20191130 version and I am experiencing an issue I have already seen in the past
Each time the sonoff restarts, GPIO 5 is set to 1 causing my blinds to close.
This was definitely not the case for earlier version I was using (2018-06 as far as I remember)
Do you know how I can prevent that to happen ?
thanks a lot
fishton
thanks a lot
fishton
Re: Sonoff 2 Gan GPIO,5 at 1 when reboot
Have you tried setting boot state for that pin? It's found under the hardware tab.
I tried that in the past and it was not working so I rolled back to previous version but I must confess I didn't this time
I would really like staying with latest version with Wifi stability updates but if the blinds are closing few times a day won't be manageable
I will try putting LOW tonight
thanks
Fishton
thanks
Fishton
Yeah try and get back here with info.
Hey !
So, I have been able to understand the issue here.
when the Sonoff Touch 2 gang is starting, it looks like Switch 2 (GPIO 9) is set to 1 that was triggering a rule based on that value changing and also changing the relay value
I have added :
on System#Boot do
gpio,12,0
gpio,5,0
inputswithcstate,1,0
inputswithcstate,0,0
in the rules
and also changed both buttons to have "Internal PullUp"
and now I still see the switch 2 light showing up but no more relay activation and the light is switched off afterward
any thoughts ?
thanks
fishton
I have added :
on System#Boot do
gpio,12,0
gpio,5,0
in the rules
any thoughts ?
thanks
fishton
also I tried putting Low on GPIO 9 but it does no have any effect
What build did you flash?
It should be ESP8285 and not ESP8266.
GPIO-9 is not available on ESP8266 as it is connected to an external flash chip. On the ESP8285 the flash chip is internal.
Hey
I flashed mega 20191208 normal ESP8285
thanks
thanks
Typo .. must be inputswitchstate
indeed, typo
my rules below
on System#Boot do
event,STOP
on Touch1#Switch1 do
if [Touch1#Switch1]=1 do
gpio,5,0
inputswitchstate 1,0
gpio,12,1
timerSet,1,30 //Set Timer 1 for the next event in 120 seconds
gpio,5,0
gpio,12,0
on Touch2#Switch2 do
if [Touch2#Switch2]=1 do
gpio,12,0
inputswitchstate 0,0
gpio,5,1
timerSet,2,30//Set Timer 1 for the next event in 120 seconds
gpio,12,0
gpio,5,0
On Rules#Timer=1 do
gpio,12,0
On Rules#Timer=2 do //When Timer1 expires, do
gpio,5,0
on UP do
gpio,5,0
gpio,12,1
inputswitchstate 0,1
timerSet,1,30
on DOWN do
gpio,12,0
gpio,5,1
inputswitchstate 1,1
timerSet,2,30
on STOP do
gpio,12,0
gpio,5,0
my rules below
on System#Boot do
event,STOP
gpio,5,0
gpio,12,1
gpio,5,0
gpio,12,0
gpio,12,0
gpio,5,1
gpio,12,0
gpio,5,0
On Rules#Timer=1 do
gpio,12,0
gpio,5,0
on UP do
gpio,5,0
gpio,12,1
timerSet,1,30
on DOWN do
gpio,12,0
gpio,5,1
timerSet,2,30
on STOP do
gpio,12,0
gpio,5,0
