Syslog level explain / ip-config on startup ?
tozett
#1 Post by tozett » 27 Jan 2016, 08:43
i configured syslogging with level 4 or 5.
it would be helpful (at least to me), if the ESPEASY would report his ip settings on startup.
or to have a startup-status-report. where inital/actual state of devices is send, and the config-settings are reportet via syslog
can i configure this?
are the syslog-levels explained anywhere? did not see something in the wiki...
otherwise +1 as a feature request ;)
this is my syslog on startup. IP (dhcp) settings are elementary helpful to see, to find this device...
Jan 27 08:33:09 ESP Unit: 0 : WIFI : Connected!
Jan 27 08:33:09 ESP Unit: 0 : INIT : I2C
Jan 27 08:33:09 ESP Unit: 0 : PN532: Init: Found chip PN532 FW: 1.6
Jan 27 08:33:09 ESP Unit: 0 : UDP  : Send Sysinfo message
Jan 27 08:33:10 192.168.14.52 hostapd: wlan0: STA 18:fe:34:a6:xx:81 WPA: group key handshake completed (RSN)
Jan 27 08:33:10 ESP Unit: 0 : INIT : Boot OK
Jan 27 08:33:10 ESP Unit: 0 : INIT : Cold Boot
Jan 27 08:33:10 ESP Unit: 0 : NTP  : NTP sync requested
Jan 27 08:33:10 ESP Unit: 0 : NTP  : NTP send to 192.53.103.108
Jan 27 08:33:10 192.168.14.52 hostapd: wlan0: STA 8c:3a:e3:6d:d6:70 WPA: group key handshake completed (RSN)
Jan 27 08:33:11 ESP Unit: 0 : NTP  : No reply
