Very basic question on how to use rule
MajinJoko
#1 Post by MajinJoko » 01 Jan 2020, 12:24
Dear all, I feel very stupid at the moment.
I wrote a very simple rule but nothing happens.
I am sure I am doing some stupid error at some point, but I can't understand what I am missing.
My goal is to send a gpio pin status everytime I change it via a command.
on System#Boot do
 Monitor GPIO,13
on MQTT#Connected do
 GPIO,13,1
 Publish %sysname%/output/gpio13,2
on GPIO#13=0 do
 Publish %sysname%/output/gpio13,0
on GPIO#13=1 do
 Publish %sysname%/output/gpio13,1
Rules are enabled in "advanced" setttings.
Rule event name is: rule#1 (does it matter?)
In the console log I can't find any error or any trace that my rule is run.
The "on MQTT#Connected" has been added for debugging purpose but, again, nothing happens.
The command I try to send are:
- GPIO,13,1
- Pulse,13,1,500
through the proper MQTT topic. The pin change as intended (the controlled relay open/close).
Can you please help me?
MajinJoko
Re: Very basic question on how to use rule
#2 Post by MajinJoko » 01 Jan 2020, 17:26
Ok, found the problem.
The eventname is the "trigger". So, I had to create three different rules.
