[SOLVED] 4 capacitive moisture sensor with a PCF8591
Posted: 17 Jan 2020, 05:46
Hi all,
I'm working on a device that will monitor the ground moisture and pilot sprinklers.
I'm planning to have 4 sensors (https://www.amazon.com/Gikfun-Capacitiv ... ial&sr=8-1) with a pcf8591 (https://www.amazon.com/KOOBOOK-PCF8591- ... 081&sr=8-1) to expand the numbers of analog inputs on the esp8266.
The sensors seems fine when plugged directly on A0 (tested with a glass of water).
However when plugged on the pcf8591, I don't get any results back. I tested the inputs with the gnd and 3.3v and get consistent results.
Does anyone see what's wrong with my project ?
