Designing automatic watering system
Posted: 19 Feb 2020, 21:32
Hi Guys,
I've begun designing an automatic watering system for our garden, based on ESPEasy (of course
The overall design will include:
1 x Wemos D1 Mini Pro 2.0
2 x https://www.alibaba.com/product-detail/ ... 58258.html Water Flow sensors for measuring consumption
2 x https://www.aliexpress.com/item/4000208 ... web201603_ Solenoid Valves controlled by 2 x relays
2 x push buttons (to manually control each valve)
2 x https://www.aliexpress.com/i/32858273308.html Soil Moisture v1.2 sensors (Maybe just one, since ESP8266 only has one analog port)
2 x LED's (Valve status)
1 x MCP23017 for easy connection of components
I've started designing my own PCB in EasyEDA, to keep it as clean as possible. But I'm not an electronic expert, so I want to make sure that the design is correct.
So, a "couple" of questions:
1) Any restrictions to which GPIO's the two flow sensors are connected? From what I understand the MCP23017 cannot handle pulses.
2) For the flow sensors, do I need to do anything circuit-wise else than power it, and connect them to a ESP8266 GPIO?
3) Does ESPEasy support any way of adding an analog port for the second soil moisture sensor?
