How to command ESPEASY GPIO thru MQTT Mosquitto
xmenne
#1 Post by xmenne » 05 Mar 2020, 12:08
I have a mosquitto broker and Domoticz installed on Pi.
I have a ESPEasy R120 installed on ESP8266 WemosD1 Mini.
All installed recently end of 2019.
I am successfull to have one switch working via Domoticz Http .
http://192.168.1.24/control?cmd=GPIO,15,1 is working fine.
What I want to do is the same thing but thru MQTT.
I have tried several flavor of this configuration without success
ESP03 subscribe Template is >> ESP03/#
Then I Publish on MQTT >> mosquitto_pub -t ESP03/cmd -m gpio,15,1
Therefore I see that on MQTT >> ESP03/cmd gpio,15,1
as expected
The issue is that with several flavor of this command and subscribe template i have no effect on mys ESP and switch.
I have two question for any one who may have a similar configuration :
Where can I see some detailed log in ESPEasy ?
Where am i wrong in the way i write my command ?
Thks
Signed XMenne from France
Re: How to command ESPEASY GPIO thru MQTT Mosquitto
#2 Post by grovkillen » 05 Mar 2020, 16:18
You can use the web log or the serial log to see what's going on.
#3 Post by TD-er » 05 Mar 2020, 16:51
Also the R120 build is quite old, so not all current features may be present.
xmenne
#4 Post by xmenne » 06 Mar 2020, 12:57
Hello Thanks,
I uploaded latest version ESP EASY mega.
This is a big change and i will need time to discover the field of possible with this version.
May be i will find a way to avoid HTTP command to adress the GPIO with this Mega version
Need time as this is not my first activity :)
Thanks again
dynamicdave
#5 Post by dynamicdave » 06 Mar 2020, 15:12
What I do in Node-RED is to use a MQTT-Out node (running Mosquitto) which is set-up with the IP address of your server
then set-up the topic in the MQTT-Out.
Something like... nodeXX/gpio/14
Where nodeXX is the 'Unit Name' as used in the ESP-Easy Config tab.
14 relates to the GPIO pin, which in this case is D5.
Pin mappings are...
D8 GPIO-15
D7 GPIO-13
D6 GPIO-12
D5 GPIO-14
I have about 40 Wemos D1 Mini devices and each one has a fixed IP address, like 192.168.1.41
So I name the Wemos D1 Mini with 'node41' and stick a label on the botton of the breadboard.
This means it's easy to workout the IP address when I pick-up a breadboard.
The Controller Subscribe setting in ESP-Easy looks like this... %sysname%/#
This means the Wemos named 'node41' will subscribe to... node41/#
To test it out (using Node-RED) you could connect an Inject node to the MQTT-Out node.
Set the Inject node to output a payload of a numeric value - either a 1 or 0 to operate the GPIO pin.
Hope this works for you.
xmenne
#6 Post by xmenne » 10 Mar 2020, 19:19
Many thanks, you open my mind to new path to solution and it works now
What I did for the record
I updated ESP with ESPEasy Mega version
I discovered the new function MQTT Import
I create a new Device Generic MQTT import
Name = Task Name >> RelaisChevret
MQTT Topic1 >> domoticz/out/ESP11_Relai1
andValue Name >> Relai1
When you publish on your Broker
mosquitto_pub -h mqtt.xxxx.net -t domoticz/out/ESP11_Relai1 -m 1
Then your Device Value Relai1 is 1
After that I created Rules (also new for me)
On RelaisChevret#Relai1=1 do
GPIO,12,1
end on
and it works and this close this post I suppose.
I now have to work on Domoticz but it is another story.
Many thanks to you all , this forum is very helpful.
Hope i can help some one one day in return .
xmenne
#7 Post by xmenne » 11 Nov 2020, 18:29
The purpose of this MONIT configuration is to have Domoticz restart fully after an electrica shut down of my RASP.
Here we have the config for Web Server monit , config for alerting email and config for Restart Domoticz service
To modify the config go here
sudo nano /etc/monit/monitrc
to check Syntax
sudo monit -t
set mailserver smtp.gmail.com port 587 # primary mailserver
username "xx.mennesson@gmail.com" password "M__7"
using tlsv1
with timeout 30 seconds
set alert xx.mennesson@gmail.com
# backup.bar.baz port 10025, # backup mailserver on port 10025
# localhost # fallback relay
## By default Monit will drop alert events if no mail servers are available.
## If you want to keep the alerts for later delivery retry, you can use the
## EVENTQUEUE statement. The base directory where undelivered alerts will be
## stored is specified by the BASEDIR option. You can limit the queue size
## by using the SLOTS option (if omitted, the queue is limited by space
## available in the back end filesystem).
set eventqueue
basedir /var/lib/monit/events # set the base directory where events will be stored
slots 100 # optionally limit the queue size
set httpd port 2812
use address 192.168.1.107 # only accept connection from localhost (drop if you use M/Monit)
allow 0.0.0.0/0.0.0.0 # allow localhost to connect to the server and
allow admin:monit # require user 'admin' with password 'monit'
# #with ssl { # enable SSL/TLS and set path to server certificate
# # pemfile: /etc/ssl/certs/monit.pem
## Services
###### Monitoring Domoticz selon PROJETSDIY.FRN
check process domoticz with pidfile /var/run/domoticz.pid
start program = "/etc/init.d/domoticz.sh start"
stop program = "/etc/init.d/domoticz.sh stop"
if failed
url http://127.0.0.1:8080/json.htm?type=com ... getversion
and content = '"status" : "OK"'
for 2 cycles
then restart
if 5 restarts within 5 cycles then exec "/sbin/reboot"
## Check that a process is running, in this case Apache, and that it respond
xmenne
#8 Post by xmenne » 11 Nov 2020, 18:35
The purpose of this Script LUA is to activate e relay from Domoticz thru MQTT:
How to rename the file if necessary
mv /home/pi/domoticz/scripts/lua/script_device_chevret_relai1.lua /home/pi/domoticz/scripts/lua/script_device_chevret_relai1_demo.lua
Quand il y a demo dans le nom d'un fichier le script ne l'execute pas
Intention of this script is to publish defined message using MQTT broker running on a localhost.
The script will trigger only when the status of the defined device is changed.
------ Variables to edit ------
devicename = "RelaisChevret" --Name of the device
deviceIDX = 10
debug = false
-- End of variables to edit --
commandArray = {}
if (devicechanged[devicename]) then
print(devicename.." MQTT script running...")
if (devicechanged[devicename] == "On") then
print(devicename.." turned on!")
os.execute('mosquitto_pub -h mqtt.leamicz.net -t domoticz/out/esp11_relai1 -m "1")
elseif (devicechanged[devicename] == "Off") then
print(devicename.." turned off!")
os.execute('mosquitto_pub -h mqtt.leamicz.net -t domoticz/out/esp11_relai1 -m "0")
end
end
return commandArray
