Where to keep record of my project
Posted: 11 Mar 2020, 19:21
by xmenne
Newcomer in this IOT / EspEasy / Domoticz world, i am looking for a place where i can record and document my project with all the details.
Any suggestion ?
Merci - Rgds
Re: Where to keep record of my project
Posted: 11 Mar 2020, 21:14
by mrwee
You're very welcome to share your project here, but all the "internal" details are better kept safe within your own domain.
Posted: 11 Mar 2020, 23:45
Welcome and I would love to see your project(s).
But like mrwee also suggests, make sure you don't expose any credentials like passwords, or tokens you may be using in your settings or rules and screenshots.
Posted: 25 Oct 2020, 00:53
by Jakiro
I prefer EspEasy
Re: Projet Piscine
Posted: 26 Jan 2024, 17:12
by xmenne
Projet Piscine
Schéma ELectronique
- IMG_20240126_170759.jpg (1.85 MiB) Viewed 6692 times
Config ESP
- Config ESP piscine 1.png (81.77 KiB) Viewed 6692 times
- Image2.png (74.1 KiB) Viewed 6692 times
- image3.png (50.21 KiB) Viewed 6692 times
- image4.png (49.34 KiB) Viewed 6692 times
Config Rules
on chevret_esp26_control_tension_pompe#State do
TimerSet,1,180 //Set Timer 1 for the next event in 180 seconds
On Rules#Timer=1 do //When Timer1 expires, do (On attend que la pompe s'amorce)
if [chevret_esp26_control_tension_pompe#State]=1
if [chevret_esp26_Piscine_pression#Analog]<104 and [chevret_esp26_control_tension_pompe#State]=1 //si pression basse et sous tension alors alarme activé à 1
TaskValueSet 5,1,1
TaskValueSet 5,1,0 // autre situation = pas d'alarme
gpio,14,0
TaskValueSet 5,1,0 // Pas de tension alors A =0 alarme désactivée
