SDS011 not visible
SDS011 not visible
Hi, I'm trying to attach SDS011 dust sensor, which should be supported. I'm running ESP_Easy_mega-20200310_test_ESP32_4M316k.bin image, which says this in the firmware section:
Build:⋄ 20104 - Mega32
System Libraries:⋄ ESP32 SDK v3.2.3-14-gd3e562907
Git Build:⋄ mega-20200310
Plugin Count:⋄ 76 [Normal] [TEST ESP32]
Build Time:⋄ Mar 10 2020 01:33:00
Binary Filename:⋄ Self built!
This is what I see when I try to add the sensor: Can someone tell me what's going on, please? Thanks!
Re: SDS011 not visible
Yeah, that message puzzles me, because I'm not running a self-built image. I've tried, yes, but this is my last flash command which is using official release:
Anyway, you have pointed me to the right direction, as define_plugin_sets.h says:
That's really sad, is there a possibility that this can be solved somehow?
esptool.py --chip esp32 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x10000 ~/Downloads/ESPEasy_mega-20200310/bin/ESP_Easy_mega-20200310_test_ESP32_4M316k.bin
* Remove incompatible plugins ************************************************
#ifdef PLUGIN_SET_TEST_ESP32
// #undef USES_P056 // SDS011-Dust (doesn't work yet on ESP32)
The marking for "self build" is displayed when the default keys are still found in the binary file.
So that sounds like the Python script we use to mark the binary after build is not working properly. (calculate CRC, store build filename, etc)
I never noticed this myself as I only flash directly from the IDE.
When moving plugins to the ESP32 build, I mainly looked at "what does compile".
In the beginning the plugins in need of serial (UART) connectivity were excluded.
Later I introduced the "ESPEasySerial" wrapper which does add support for HW serial on ESP8266/ESP32 and software serial (ESP8266) so that made it possible to have those added to the ESP32 build also.
Maybe I overlooked the SDS011???
Ah found the cause....
In the P056 code is the following:
#ifdef ESP8266 // Needed for precompile issues.
Not sure why though, but apparently it was causing some issues with ESP32.
If you remove the #ifdef ESP8266 (and the closing #endif) in these files:
jkSDS011.cpp
jkSDS011.h
_P056_SDS011-Dust.ino
Then you can compile it for ESP32.
I will make a PR for it. ( https://github.com/letscontrolit/ESPEasy/pull/2946 )
In the mean time, you can test if it is working: https://www.dropbox.com/s/q13cnc1tugwwa ... k.bin?dl=0
jkSDS011.cpp
jkSDS011.h
Thanks! I will check tomorrow
Actually - I've tried, and it works . Thank you so much for such a fast response!
Thanks for testing.
I merged it.
Still have to 'fix' the test build for ESP8266, as it does no longer fit
If that's fixed, I can make a new nightly.
I merged it.
