is it possible to set the time manually
GravityRZ
#1 Post by GravityRZ » 01 Apr 2020, 11:12
i need to test something on the esp and like to set the time manually to a certain time (23:59)
is this possible?
seb82
Re: is it possible to set the time manually
#2 Post by seb82 » 01 Apr 2020, 15:04
Directly I do not know.
What you could do is to use a local NTP server, declare it in advanced configuration on the ESP Easy device and change the NTP server time.
seb82
#3 Post by seb82 » 01 Apr 2020, 15:05
Easier: use the Timezone Offset option in advanced configuration
GravityRZ
#4 Post by GravityRZ » 01 Apr 2020, 15:46
seb82 wrote: 01 Apr 2020, 15:05 Easier: use the Timezone Offset option in advanced configuration
thanks tried it at the beginning but is was not working (offset to big)
tried it again and this is a workable solution when it is 15:00 and want to test 00:00 functionality
#5 Post by TD-er » 01 Apr 2020, 20:56
Can you open an issue for it as feature request on Github?
#6 Post by TD-er » 01 Apr 2020, 22:55
I did look into the code, as I was convinced I had looked into it not so long ago.
See: https://espeasy.readthedocs.io/en/lates ... nds-listed
The command DateTime
Based on the documentation examples, it seems like it is already present for over a month :)
GravityRZ
#7 Post by GravityRZ » 02 Apr 2020, 08:40
thanks.
i found a lot of threads but none stated that it was implemented
classic RTFM HaHa.
uxhamby
#8 Post by uxhamby » 06 Jul 2021, 16:17
Datetime,2021-07-06,10:00:00
This worked for me and saved me some work. Thanks!
Brian H.
Users browsing this forum: Anthropic Claude Bot [bot] and 0 guests
