Poll: Power Supply Solutions for the small ESP as Sensor network
Posted: 02 Feb 2016, 09:30
by tozett
tried to say all in the subjekt:
i am looking for good Power-Supply solutions for the small ESP,
if you distribute 15 pieces around the house.
should be small, sleek, maybe conform with the local regulaties, not too hot to burn down the house, ....
(at the moment i am testing with a breadboard power-supply to an ESP12,
where the am1117 DC-DC converter get very,very hot. not the best to put it in the wall)
pictures and all IDEAS very wellcome.
Re: Poll: Power Supply Solutions for the small ESP as Sensor network
Posted: 02 Feb 2016, 14:51
by tozett
http://jeelabs.org/2011/06/24/alternati ... index.html
The MCP1702 used in JeeNodes and other circuits here at JeeLabs is a nifty little voltage regulator. It’s not particularly good for high voltages (limited to about 13V), but it has a very low idle current
http://jeelabs.org/2011/06/21/mcp1702-c ... index.html
some more ideas for circuits here:
http://jeelabs.org/tag/power/
but a true solution has circut, case, and costs < 1 EUR
Posted: 04 Feb 2016, 19:36
by Deennoo
Look at wemos mini d1 : this is an esp board on the same seize of an SD Card, working on 5v true USB, lot of gpio aviable, all inside and got a 5v output direct from USB plug.
http://www.wemos.cc/wiki/doku.php?id=en:d1_mini
Posted: 05 Feb 2016, 07:59
by tozett
i orderd some yesterday. How much current max on the 5v can they take, do you now?
you stated 750mA with leds..
http://www.esp8266.nu/forum/viewtopic.p ... 3812#p3812
but max? found nothing on their website.. i will see after they arrive in a month...
Posted: 05 Feb 2016, 10:33
by Deennoo
i don't know... as it looks like to be direct connect to the USB line, can expect thas this delivery the same as usb input.
Posted: 05 Feb 2016, 13:23
by ambassadoro
I have orderered these power-suppliers:
PowerSupply and then I want to go down to 3.3V with those:
DCDC.
The power-supply was tested once from a danish expert:
Expert.
But, all in all this comes up to 3€ per power supply. Thats far away from the 1€ supply that tozett mentioned.
Posted: 05 Feb 2016, 16:17
by tozett
hey, this looks good. i think i will give this also a try.
the 1 EUR was not meant so straight literally, any small EUR will do..
Posted: 05 Feb 2016, 18:09
by BertB
I use the HLK for a while now and so far so good.
I just put a MOV across it, with a fuse.
Posted: 05 Feb 2016, 21:54
by rtenklooster
ambassadoro wrote:Hi,
DCDC.
Expert.
Why should you not buy the 3.3v version? I have a couple of those, working great, no step down required.
Posted: 05 Feb 2016, 22:30
by tozett
to have 5V for the ws2812b LED...?
but not always needed..
Posted: 06 Feb 2016, 12:02
by BertB
rtenklooster wrote:ambassadoro wrote:Hi,
DCDC.
Expert.
@rtenklooster, Which one is that?
Posted: 06 Feb 2016, 12:05
by tozett
Posted: 06 Feb 2016, 14:28
by BertB
Great, thanks. A few months back, when I ordered them, the only ones were 5 volt, but this is very nice.
Posted: 07 Feb 2016, 13:08
by tozett
little bit of solderings, but 5v, 3.3v for ESP01
https://github.com/sfranzyshen/ESP_01_5V
Posted: 07 Feb 2016, 14:14
by tozett
this looks good to me,
a well sorted pcb with components from aliexpress.
only little to solder, if components break, i get new ones from china ..
https://www.domoticz.com/forum/viewtopi ... immer+wifi
Posted: 07 Feb 2016, 15:31
by Palumbus
tozett wrote:i orderd some yesterday. ....
Mine took just a week for delivery
Posted: 08 Feb 2016, 11:55
by tozett
maybe the PSU is only one part of a suitable complete "sensor-module",
this PCB layout seems also nice, compact and "suitable" for an good psu...
http://www.clixx.io/esp8266-01.html
