I have a standard relay controlled via a mosfet on GPIO D5. 100ko resistor pull down the gate to gnd. And free wheel diode on coil as protection.
I have setup D5 low during boot in espeasy
However, when booting , the relay clicks
Any very simple solution to avoid that ? I don’t have soo much place left on my pcb. Maybe a capacitor to absorb the spike At boot ? Any idea ?
Thank you
Avoir bad relay trigger during boot
Re: Avoir bad relay trigger during boot
It sounds like you are doing all the right things. Does this occur during power-up boot, warm boot (reset button), or both boot modes?
If relay click occurs on all boot modes then perhaps D5's internal weak pull-up has been enabled. That would suggest that the 100K ohm external pull-down value is too high; Try 4.7K ohm instead.
I changed a litle bit the circuit by adding 2 resistors divider + Capacitor 100µF to ground + Zener 3V on the gate to delay introduce a delay.
To activate the relay, I have to send a longer pulse to overcome this delay
It works perfectly and this is simple
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 27 guests
