Shelly plug s
tage
Shelly plug s
#1 Post by tage » 03 May 2020, 22:34
i have put espeasy to a shelly plug s https://shelly.cloud/shelly-plug-s/and got most of it to work
used this guide when flashed https://faulty.cloud/blog/shelly-plug-s-pinout
i used this firmware https://www.letscontrolit.com/forum/vie ... php?t=6681 only one i have found with hlw8012/bl0937 sensor in.
im not sure but i think the memory is like shelly 1 (2mb) worked with hard_Shelly_1_2M256.bin also.
Energy (AC) - HLW8012/BL0937 [TESTING]
GPIO → SEL:     GPIO:12
GPIO ← CF1:     GPIO:14
GPIO ← CF:      GPIO:5
Button           GPIO:13
Relay            GPIO:15
Red led light    GPIO:00
Blue led light   GPIO:02
it is a tempsensor in it but no temp sensors in that firmware so i i can´t try that.
would be nice if hlw8012/bl0937 is added to hard_Shelly_1_2M256.bin so it is possible to update ota .
some strange values sometimes but i´m not sure how to calibrate mostly showing around 230volt.
/Tage
Re: Shelly plug s
#2 Post by TD-er » 04 May 2020, 16:05
So in short, you want also a 2MB build for the "POW" version?
You can indeed flash a build for a smaller flash to a larger flash chip. (the other way around not for obvious reasons)
One day I hope to have a generic "one size fits all" build, but that's not possible right now.
Please note you will loose the stored settings when switching between builds using a different flash layout.
tage
Re: Shelly plug s
#3 Post by tage » 04 May 2020, 20:23
what i understand is HLW8012/BL0937 or plugin P076 under test builds?
and there is only 4mb flash there?
i have no problem to use smaller builds just a little hard when programing the shelly.
/Tage
Re: Shelly plug s
#4 Post by TD-er » 04 May 2020, 21:43
Already implemented it... like 5 hours ago :)
https://github.com/letscontrolit/ESPEas ... 0dfb79a308
Can you test this test build?
https://www.dropbox.com/s/lgpn29w6kwooi ... 6.bin?dl=0
tage
Re: Shelly plug s
#5 Post by tage » 05 May 2020, 11:23
Thx !!
worked perfect
acted litle strange on the other build so i put an empty 2mb flash first before the new one .
i haven´t find out what temp sensor it is yet.
/ Tage
Re: Shelly plug s
#6 Post by TD-er » 05 May 2020, 12:22
Good to hear it worked.
I could not find any confirmation on the flash size of this Shelly version, so I just took your comment on the flash size and made a build descriptor for it.
Let me know when you found out more about the temp sensor.
At least upgrading is now a lot easier when using the 2M layout.
You can also upgrade by using .bin.gz files, so the 1.5M space for sketch + OTA can hold builds of roughly 800 - 900 k (depending on the compression ratio of the new image you try to load)
