Issues with sunset
Mrwomble
Issues with sunset
#1 Post by Mrwomble » 06 May 2020, 19:32
Hi all,
I've got a project running with some events triggered at sunrise, 2 minutes before sunset and at sunset. The sunrise event is working just fine but the sunset triggers don't seem to be working. The log shows an event at the time, but nothing happens. Is there a known issue with the sunset timer in the latest build (ESP_Easy_mega-20200410_normal_ESP8266_4M1M on a Wemos D1 NodeMcu board)?
Re: Issues with sunset
#2 Post by grovkillen » 06 May 2020, 19:44
How does your rule look like?
#3 Post by TD-er » 07 May 2020, 00:07
Like Jimmy suggested, please show the rules + the error.
There is no known issue with sunrise/sunset.
Mrwomble
#4 Post by Mrwomble » 07 May 2020, 10:49
Thanks for the response.
These are the rules in question:
on CoopClose do //-------Close coop
 timerSet,2,20 //start timer, 10s
 gpio,14,1     //activate motor
 gpio,12,0
 TaskValueSet 3,1,1  //Coopstatus
 SendToHTTP maker.ifttt.com,80,/trigger/Coop_closed/with/key/cHEgUQg_iyUkaVZG-tOaV2  //IFTT
on Motor_stop#State do  //to stop motor, for CoopClose
 gpio,14,0
 gpio,12,0
On Rules#Timer=2 do  //stops motor turning if micro-switch not triggered
 gpio,14,0
 gpio,12,0
//                          Sunrise/Sunset timers
on Clock#Time=All,%sunrise-20m% do //---------20mins before sunrise activation
 event,CoopOpen
on Clock#Time=All,%sunset-2m% do     //---------2mins before sunset trigger, buzzer warning
  rtttl,5:d=5,o=6,b=180,c,e,g
on Clock#Time=All,%sunset% do     //---------sunset trigger
 event,CoopClose
I don't get an error in the logs, but when I tried changing the entry for %sunset-2m% to run earlier so that I could test it, it would work occassionally and other times nothing would happen, but the logs would show this:
1262509: WD : Uptime 21 ConnectFailures 0 FreeMem 20800 WiFiStatus 3
1282666: EVENT: Clock#Time=Wed,17:52
1472509: WD : Uptime 25 ConnectFailures 0 FreeMem 20800 WiFiStatus 3
1502509: WD : Uptime 25 ConnectFailures 0 FreeMem 20800 WiFiStatus 3
1522665: EVENT: Clock#Time=Wed,17:56
Any ideas?
#5 Post by TD-er » 07 May 2020, 20:06
Can you have a look at the timing stats page (Tools => timing stats) ?
N.B. every time you load that page, the statistics are reset, so it is important to have a good look at the first load after running for a while, preferably after these rules executed.
Try to see if there is something that may take longer than a few-100 msec.
Also check if the node does run stable and not reboot quite often.
The more recent builds do keep the time after a crash (about a second offset per crash) but if you run a build older than 1 or 2 months old, then it may be the unit just hasn't got the time from a NTP server after a reboot.
