2 Switch, 1 LED blink and light
druckgott
#1 Post by druckgott » 10 May 2020, 10:08
Hallo, I have two switches on GPIO2 (SW1) and GPIO14(SW2) and I have a LED on GPIO 13.
The two switches can never pushed parallel due to the hardware!
Now I want to have it like this.
If SW1 is pushed and SW2 is not pushed then the LED should be off
If SW1 is not pushed an SW2 is not pushed the LED should blink
If SW2 is pushed and SW1 not pused the LED sould light without blinking
This is my code, but it´s not working:
if SW1 is pushed and SW2 is off the led is off
if SW1 is off and SW2 is off the led is blinking
but if SW2 is pushed and SW1 is off the led is blinking some times or off
On garage_close#Value=0 do
   //blink
   timerSet,1,1
On garage_close#Value=1 do
  //stop blinking
   timerSet,1,0
On garage_open#Value=0 do
 //switch off led and blink
  GPIO,13,0
   timerSet,1,1
//wenn geschlossen aus
On garage_open#Value=1 do
//switch off blink and light
   timerSet,1,0
     GPIO,13,1
 //create an actual warning signal, every time
timer 1 expires:
 On Rules#Timer=1 do
   //repeat after 2 seconds
   timerSet,1,1
    //pulse some led on pin 4 shortly
   Pulse,13,1,200
I do not know why it´s not working.
Re: 2 Switch, 1 LED blink and light
#2 Post by Ath » 10 May 2020, 13:30
Well, I just built your scenario, but I'm not sure you have stuff set up right:
- My led is on GPIO5, and it is active-low, not active-high as you seem to have (on high the GPIO doesn't deliver much current, though on low it can pull some current)
- My switches are set up as Normal Switch, with internal pull-up, and Inversed logic, shorting the GPIO to ground when closed. (IRL, you will need external pull-up resistors ~10k to avoid picking up spurious spikes)
My rules are now like this (I did remove the extra enter you had in one comment, I hope it is not in your actual code)
  //blink
  timerSet,1,1
  // Light off
  GPIO,13,1
  //stop blinking
  timerSet,1,0
  //switch off light start blink
  GPIO,13,1
  timerSet,1,1
  //switch off blink and light on
  GPIO,13,0
  timerSet,1,0
//create an actual warning signal, every time timer 1 expires:
On Rules#Timer=1 do
   //repeat after 1 seconds
   timerSet,1,1
    //pulse the led shortly, non-blocking
   LongPulse_ms,13,0,400
This works as follows:
Garage door closed: Light is off
Garage door is opening: Light blinks
Garage door is fully open: Light is on
Garage door is closing: Light blinks
An improvement could be to have 2 lights, orange for the current light, and green for a second light, that is turned on when the garage door is fully open, that would need these two events to be replaced by this code:
(Green light is on GPIO5, active low, orange light is on GPIO13, active low)
  GPIO,13,1
  GPIO,5,1
  timerSet,1,1
  GPIO,13,1
  GPIO,5,0
  timerSet,1,0
NB: Having 'Value' for the switches, instead of State, makes me wonder what version of ESPEasy you are using? I'd advise to take a current one form Github, like 20200410.
NB2: Having a switch on GPIO2 might get you in trouble, as that is used to put the ESP into one of its special modes during boot. Another GPIO should better be used like 3 or 5.
Edit: Updated to first turn on/off lights and then (re)set the timer.
druckgott
#3 Post by druckgott » 10 May 2020, 21:01
Hallo, I use version 120.
For the level you mean like in the picture.
The switches i also add pictures
I tested the pulse with the url command, bit it says unknown command
http://192.168.0.42/control?cmd=LongPulse_mS,13,1,400
The rules i also add but its not working, i will test it again tomorrow
#4 Post by Ath » 10 May 2020, 21:16
Oefff, version 120 is over 2 years old, and not very up to date, so that's why you are missing the LongPulse_Ms command.
As I suggested earlier, please upgrade to a more current release, there have been many after R120, the latest is always available from here: https://github.com/letscontrolit/ESPEasy/releases and the zip-file includes an updated flash tool, as I'm not sure if your old version can install updates OTA (over the air).
druckgott
#5 Post by druckgott » 10 May 2020, 21:28
Ok thx thisbis what i found on the wiki 😁
I will updaten it tomorrow. And test it again.
druckgott
#6 Post by druckgott » 10 May 2020, 21:50
One more question is it also posible to send a puls with lower voltage or pwm so that the led only has 50 percent light?
#7 Post by grovkillen » 10 May 2020, 22:01
Use the PWM command.
druckgott
#8 Post by druckgott » 11 May 2020, 17:33
Now it works thc
Can i combine pwm and longpulse?
I want to habe a differt lightsize between day and night and want to do this this the time.
On garage_close#State=0 do
  //stop blinking
  timerSet,1,0
// Light off
  GPIO,13,0
On garage_close#State=1 do
  //blink
  timerSet,1,1
On garage_open#State=0 do
  //Light on
  GPIO,13,1
  timerSet,1,0
On garage_open#State=1 do
  GPIO,13,0
  timerSet,1,1
On Rules#Timer=1 do
   timerSet,1,1
#9 Post by grovkillen » 11 May 2020, 18:27
I think you need to set PWM to zero before you can use the pulse commands. Or else it will not work. So if you have used the PWM command, set it to PWM level zero before using GPIO or pulse commands.
You can use fade for PWM fading.
druckgott
#10 Post by druckgott » 11 May 2020, 18:46
Ok so i can note have pulse with only 50 percent pwm signal? Pulse is only 100 percent power for the led if I understand it the right way?
#11 Post by TD-er » 29 Apr 2021, 11:14
BriniGurhi wrote: 29 Apr 2021, 10:32 Is it also posible to send a puls with lower voltage so that the led only has 50 percent light?
You could add a small capacitor (and a small resistor to limit the charging current) and a resistor over the capacitor (to discharge the capacitor) to convert the PWM signal to an analog voltage.
It may require some experimentation to get the right value for the capacitor for your setup.
#12 Post by Ath » 29 Apr 2021, 11:49
A LED is fast enough to react to the PWM command, afaics. It probably isn't linear in behavior, but you could play a little with duty-cycle and frequency to get the brightness as desired.
Users browsing this forum: Ahrefs [Bot] and 35 guests
