using values in rules from a sending node which is connected per P2P network
parabacus
#1 Post by parabacus » 17 May 2020, 22:13
Hello together!
I have some problem to use the values sent by Wemos node #1 named RWZ via P2P-Connection at a second Wemos node #2 mamed "Zisterne".
Both nodes are flashed with build version "ESPEasy_mega-20200410".
The node #1 ist configured like below:
- uniqe Unit Nr. 71
- UDP Port 8266
- Controller "ESPEasy P2P Networking" enabled
- 3 Tasks configured (Task 1 to 3) - every Task sends its values to P2P-Connection
https://www.letscontrolit.com/forum/dow ... ew&id=4740
https://www.letscontrolit.com/forum/dow ... ew&id=4742
https://www.letscontrolit.com/forum/dow ... ew&id=4744
https://www.letscontrolit.com/forum/dow ... ew&id=4746
The node #2 ist configured like below:
- uniqe Unit Nr. 34
- UDP Port 8266
- 3 Tasks were configured automatically (Task 1 to 3) - Port is the node #1 "RWZ"
https://www.letscontrolit.com/forum/dow ... ew&id=4741
https://www.letscontrolit.com/forum/dow ... ew&id=4743
https://www.letscontrolit.com/forum/dow ... ew&id=4745
In the Main sheet of both nodes I can see both untis. This shows me that the communication is running right.
In the Task list of node #2 every sent value from node #1 ist displayed correctly.
The problem is that it is not possible to use the received values by rules on node #2!
On system boot a debug variable is initialized with value 255.
Depending on the received state value (values 0 .. 10) sent by node #1 the corresponding LEDs should switched on at node #2.
It doesen't matter which value is received, the debug variable remains 255.
This is the rule 1:
on System#Boot do
 gpio,0,0
 gpio,2,0
 gpio,12,0
 gpio,13,0
 gpio,14,0
 TaskValueSet 4,1,255
On Zisterne#ZisternenStatus do // Status 0 = Leer / 10 = Voll
if [Zisterne#ZisternenStatus]=0.00
 gpio,0,0          // rote   LED    aus
 gpio,2,0          // gelbe  LED    aus
 gpio,12,0         // gelbe  LED    aus
 gpio,13,0         // gruene LED    aus
 gpio,14,0         // gruene LED    aus
 TaskValueSet 4,1,0
if [Zisterne#ZisternenStatus]=1.00 or [Zisterne#ZisternenStatus]=2.00
 gpio,0,1          // rote   LED    an
 TaskValueSet 4,1,1
if [Zisterne#ZisternenStatus]=3.00 or [Zisterne#ZisternenStatus]=4.00
 gpio,2,1          // gelbe  LED    an
 TaskValueSet 4,1,2
if [Zisterne#ZisternenStatus]=5.00 or [Zisterne#ZisternenStatus]=6.00
 gpio,12,1         // gelbe  LED    an
 TaskValueSet 4,1,3
if [Zisterne#ZisternenStatus]=7 or [Zisterne#ZisternenStatus]=8
 gpio,13,1         // gruene LED    an
 TaskValueSet 4,1,4
if [Zisterne#ZisternenStatus]=9 or [Zisterne#ZisternenStatus]=10
 gpio,14,1         // gruene LED    an
TaskValueSet 4,1,5
Here the log from node2 - the value is received right!
43921181: Dummy: value 1: 255.00
43921246: EVENT: Debug#Info=255.00
43923139: WD   : Uptime 732 ConnectFailures 0 FreeMem 17992 WiFiStatus 3
43927646: EVENT: Zisterne#ZisternenStatus=4.00
43953139: WD   : Uptime 733 ConnectFailures 0 FreeMem 18016 WiFiStatus 3
43957646: EVENT: Zisterne#ZisternenStatus=4.00
43981181: Dummy: value 1: 255.00
43981246: EVENT: Debug#Info=255.00
43983139: WD   : Uptime 733 ConnectFailures 0 FreeMem 16424 WiFiStatus 3
43987646: EVENT: Zisterne#ZisternenStatus=4.00
44008981: Rules : Save rulesSet: 1 currentSet: 2
44009140:  Webserver args: 0: 'set' length: 1 1: 'rules' length: 1399
44013139: WD   : Uptime 734 ConnectFailures 0 FreeMem 18016 WiFiStatus 3
44017605: EVENT: Zisterne#ZisternenStatus=4.00
44041181: Dummy: value 1: 255.00
44041205: EVENT: Debug#Info=255.00
44043139: WD   : Uptime 734 ConnectFailures 0 FreeMem 18016 WiFiStatus 3
What is the secret?
Re: using values in rules from a sending node which is connected per P2P network
#2 Post by TD-er » 18 May 2020, 00:15
You should probably use taskvaluesetandrun or taskvalueset followed by taskrun.
See the command reference: https://espeasy.readthedocs.io/en/lates ... nds-listed
parabacus
#3 Post by parabacus » 18 May 2020, 08:32
Sorry, but I think you haven't understood my problem right ..
On system boot I set the debug variable per "TaskValueSet 4,1,255" - this works!
With the debug variable I want to check the IF-Statements and because the check of "On Zisterne#ZisternenStatus do ..." dosen't work in the way I expected the value of the debug variable never changes - an the LEDs won't switched on or off.
Can you tell me, why the evaluation of "On Zisterne#ZisternenStatus do ..." dosen't work?
I'm confused becaus the log shows me the right received values.
On the sending node #1 RWZ I use the same logic and it works.
#4 Post by TD-er » 18 May 2020, 11:28
Are you sure it enters this part?
You can add a logentry (is a command) to track whether it does pass this trigger at all.
What I think is happening, is that the value may get updated, but if you don't "run" the task, it will not send an event to signal the value is actually updated.
So that's why I suggested to try calling taskrun.
parabacus
#5 Post by parabacus » 18 May 2020, 15:30
Now I am littel step further..
I'm sure that the first If-Statemen "On Zisterne#ZisternenStatus do" will be entered. :D
I have added a instruction to write a log info like you suggested - thank you for the hint!
On System#Boot do
 gpio,0,1
 gpio,2,0
 gpio,12,0
 gpio,13,0
 gpio,14,0
LogEntry,EZ
LogEntry,S_0
 TaskValueSet 4,1,12
LogEntry,S_1_2
 TaskValueSet 4,1,1
LogEntry,S_3_4
 TaskValueSet 4,1,2
Here is the log for this:
8817202: EVENT: Fuellstand_Zisterne_Liter#Liter=1566.21
8823670: WD   : Uptime 147 ConnectFailures 0 FreeMem 18456 WiFiStatus 3
8824602: EVENT: Zisterne#ZisternenStatus=3.00
8828225: Upload: START, filename: rules1.txt
8828324: Upload: WRITE, Bytes: 1977
8828325: Upload: END, Size: 1977
8828479:  Webserver args: 0: 'enctype' length: 19
8828543: CRC  : SecuritySettings CRC   ...OK
8832636: EVENT: Fuellstand_Zisterne#Fuellstand=157.33
8835114: EVENT: Clock#Time=Thu,07:10
8847142: EVENT: Fuellstand_Zisterne_Liter#Liter=1566.21
8853670: WD   : Uptime 148 ConnectFailures 0 FreeMem 18480 WiFiStatus 3
8854536: EVENT: Zisterne#ZisternenStatus=3.00
8854544: ACT  : LogEntry,EZ
8854545: Command: LogEntry
8854546: EZ
8858914: Dummy: value 1: 255.00
8858936: EVENT: Debug#Info=255.00
8862636: EVENT: Fuellstand_Zisterne#Fuellstand=157.37
8877142: EVENT: Fuellstand_Zisterne_Liter#Liter=1566.21
8883670: WD   : Uptime 148 ConnectFailures 0 FreeMem 18480 WiFiStatus 3
8884536: EVENT: Zisterne#ZisternenStatus=3.00
8884544: ACT  : LogEntry,EZ
8884545: Command: LogEntry
8884546: EZ
8892636: EVENT: Fuellstand_Zisterne#Fuellstand=157.32
8895115: EVENT: Clock#Time=Thu,07:11
Now it is clear that the follwoing IF-Statement are not passed.
if [Zisterne#ZisternenStatus]= ...
A second log entry doesn't occure.
Is it possible that the evaluation of the received values is not feasible?
#6 Post by ThomasB » 18 May 2020, 18:36
Please ENABLE all the plugins with the Red X in them. The Red X should be changed to the Green Check Mark.
#7 Post by TD-er » 18 May 2020, 22:32
Ah good to see someone is more clear-headed than I am/was.
Thanks Thomas (as always)
parabacus
#8 Post by parabacus » 20 May 2020, 20:14
Hm - it sounds like an easy problem solving... - but...
Ich have enabled the thre Tasks and since I have done this, the variable names of Task 2 an Task 3 have changed to Dummy! :shock:
Only the first Task is displayed correctly. At the sending node the names remain unchanged!
https://www.letscontrolit.com/forum/dow ... ew&id=4752
One question about enabling the tasks on the reciving node. I have read the explanation, but in this description I don't find this to do.
https://espeasy.readthedocs.io/en/lates ... /C013.html
I will start from the beginning...
parabacus
#9 Post by parabacus » 20 May 2020, 20:41
I have started new - on both nodes I have confiured P2P connection from the start.
It looks like before since I enabled the Task 2 with the desired variable name which I want to use in the rule. After this the variable name was changed again from ZisternenStatus to Dummy . In the log I saw Zisterne#Dummy=2.00
And now I modified the rule code using "new" variable name Dummy in Task 2:
On Zisterne#Dummy do // Status 0 = Leer / 10 = Voll
LogEntry,EZ
if [Zisterne#Dummy]=0.00
LogEntry,S_0
 TaskValueSet 4,1,0
if [Zisterne#Dummy]=1.00 or [Zisterne#Dummy]=2.00
LogEntry,S_1_2
 TaskValueSet 4,1,1
Now it works!!!
273892: WD   : Uptime 5 ConnectFailures 0 FreeMem 18680 WiFiStatus 3
282778: EVENT: Fuellstand_Zisterne#Fuellstand=183.00
289544: SW   : GPIO 13 Set to 0
289546: ACT  : gpio,14,0
289548: Command: gpio
289549: SW   : GPIO 14 Set to 0
289552: ACT  : TaskValueSet 4,1,1
289553: Command: TaskValueSet
289595: EVENT: Zisterne#=0.00
289677: EVENT: Zisterne#=0.00
289777: EVENT: Zisterne#=0.00
289877: EVENT: Fuellstand_Zisterne_Liter#Liter=767.75
289977: EVENT: Fuellstand_Zisterne_Liter#=0.00
290077: EVENT: Fuellstand_Zisterne_Liter#=0.00
290177: EVENT: Fuellstand_Zisterne_Liter#=0.00
301122: Dummy: value 1: 1.00
301177: EVENT: Debug#Info=1.00
301277: EVENT: Debug#=0.00
301377: EVENT: Debug#=0.00
301477: EVENT: Debug#=0.00
303892: WD   : Uptime 5 ConnectFailures 0 FreeMem 18704 WiFiStatus 3
312777: EVENT: Fuellstand_Zisterne#Fuellstand=183.42
314336: EVENT: Clock#Time=Thu,02:17
319539: SW   : GPIO 12 Set to 0
319541: ACT  : gpio,13,0
319542: Command: gpio
319544: SW   : GPIO 13 Set to 0
319546: ACT  : gpio,14,0
319547: Command: gpio
319549: SW   : GPIO 14 Set to 0
319551: ACT  : TaskValueSet 4,1,1
319553: Command: TaskValueSet
319630: EVENT: Zisterne#=0.00
319739: EVENT: Zisterne#=0.00
319806: EVENT: Zisterne#=0.00
319877: EVENT: Fuellstand_Zisterne_Liter#Liter=767.75
319977: EVENT: Fuellstand_Zisterne_Liter#=0.00
320077: EVENT: Fuellstand_Zisterne_Liter#=0.00
320178: EVENT: Fuellstand_Zisterne_Liter#=0.00
333892: WD   : Uptime 6 ConnectFailures 0 FreeMem 18704 WiFiStatus 3
Very, very strange für me...! :roll:
I think this not the way it schould work?
#10 Post by ThomasB » 20 May 2020, 21:15
I think this not the way it should work?
Glad you found a workaround. I agree, the slave P2P Dummy device name should not have been reset to "dummy." And since the master Dummy device is single output data type, the slave should also be single output (instead of four data output). I suggest opening a github issue on this.
BTW, it would be more efficient to use one Dummy device for your two variables; A single Dummy device can hold four vars. Fine print: Given the odd P2P behavior you are seeing, I suspect this kind of usage will also be broken.
parabacus
#11 Post by parabacus » 21 May 2020, 11:32
Hey Thomas,
yes I know that all variabels in one Task wil be more efficient, but for the start I tried it this way and for the final solution I need only one information about the filling status of my rain water reservoir.
Perhaps it is planed later to connect a display to show more detailed information but for now this will be enough.
Thank you for your support also to TD-er!
Who will open the issue for this on github? I have no experience for this till yet.
#12 Post by ThomasB » 21 May 2020, 22:38
Fixes to ESPEasy are unlikely if they only get discussed on the forum. So that is why you need to officially report the issue on Github. Here is the link:
https://github.com/letscontrolit/ESPEasy/issues
