Esp connects only with Wifi after flashing
Koenig
#1 Post by Koenig » 24 May 2020, 16:03
My ESP8266 has worked wonderfully to this day. But (possibly after a short circuit) it no longer boots. However, I can reactivate it by re-flashing it. After flashing, it runs perfectly as long as there is a USB serial connection to the PC. However, if I put it back on the normal power supply, it will be dead. The power supply is perfect, that cannot be the problem. Does anyone know advice?
Re: Esp connects only with Wifi after flashing
#2 Post by Ath » 24 May 2020, 16:06
Koenig wrote:
24 May 2020, 16:03
Well, to be really, really sure, can you try another power supply?, as, from where I'm looking, it seems it is not proving sufficient power to your ESP...
Koenig
#3 Post by Koenig » 24 May 2020, 16:10
Already done and checked. The module has enough Power (5V).
#4 Post by Ath » 24 May 2020, 16:56
Well, we'll need a bit more info then.
- What version of ESPEasy was initially installed?
- What version of ESPEasy do you have installed now?
- What short-circuited that made it stop working?
- What plugins do you have active?
- And how are the sensors for these plugins connected? (wiring-type + gpio's)
- Are there any output's connected, like relays etc.? and on what ports?
- Have you really replaced the power supply to verify, or only measured and confirmed to have 5V? (sorry to ask again, but the power supply is always a suspect, especially after a short-circuit)
#5 Post by TD-er » 24 May 2020, 23:16
And also; How do you power it when not powering it via the USB?
A photo or schematic sketch would also be helpful.
What module do you have?
NodeMCU / Wemos D1 mini / etc.
