"Generic - MQTT Import" problem
Andrew Mamohin
#1 Post by Andrew Mamohin » 12 Jun 2020, 16:47
I would like to transfer data from nodered over MQTT to my ESPeasy device.
I can not configure this.
I configured Controller, and I saw in mosquitto_sub how ESP sends data.
Client mosqsub|11803-orange received PUBLISH (d0, q0, r1, m0, 'cellar/status/LWT', ... (9 bytes))
Connected
Client mosqsub|11803-orange received PUBLISH (d0, q0, r1, m0, 'cellar/out/LWT', ... (9 bytes))
My data that I want to receive in ESP is as follows:
Client mosqsub|11803-orange received PUBLISH (d0, q0, r0, m0, 'cellar/in', ... (59 bytes))
{"idx":10,"nvalue":31.19,"svalue1":"31.19","t3":31,"t4":19}
Client mosqsub|11803-orange received PUBLISH (d0, q0, r0, m0, 'cellar/in', ... (55 bytes))
{"idx":7,"nvalue":29.3,"svalue1":"29.3","t1":29,"t2":3}
I configured device in ESP. What mistakes have I made? I tried different options in Generic setup - MQTT Import, but I did not receive the data.
Maybe MQTT is not working correctly in my firmware version? But, I can not use another version because of the PZEM-004 device.
Andy.
Re: "Generic - MQTT Import" problem
#2 Post by TD-er » 13 Jun 2020, 11:26
The strings you receive don't look like numerical values, but more like JSON formatted data.
MQTT import currently only supports simple strings which can be read as either an int or a float value.
Andrew Mamohin
#3 Post by Andrew Mamohin » 13 Jun 2020, 14:47
Can you write me an example of such an MQTT message so I can make it in NodeRed?
Andy.
#4 Post by grovkillen » 13 Jun 2020, 15:06
The message should be a simple numerical value.
Andrew Mamohin
#5 Post by Andrew Mamohin » 13 Jun 2020, 21:08
Wow! Thank! I did the conversion in NodeRed and everything started working correctly.
[attachment=0]FwlFnNf8Mf.png[/attachment]
[attachment=1]ceshLXdFhh.png[/attachment]
Andy.
Users browsing this forum: Bing [Bot], Google [Bot] and 30 guests
