as mentioned in the topic, how can I change the default AP SSID "ESP_Easy_0" and the password to something else?
Thanks in advance,
dino
How to change the AP mode SSID "ESP_Easy_0"
Re: How to change the AP mode SSID "ESP_Easy_0"
The SSID is made from the unit name and number. But if you want to make it something completely different you need to compile your custom version.
And you can change whether the unit number is appended or not in the settings.
Hi!! Where can i change this values?
On the config tab
You can set the host name and unit nr.
