Rules for bathroom ventilation
sawo
#1 Post by sawo » 16 Jun 2020, 20:55
Hi all,
could any one please assist me with a espeasy rule?
I would like to setup an bathroom ventilation rule,
so when the lux value is above 100 and/or the humidity is above 65 the fan should turn on and stay on for 5min.
I am using a wemos d1, dht22 and a bh1750.
This is the rule I have to far: but the "delay" doesn't work...
On System#Boot do
gpio,0,0
On Light#Lux>100 do
gpio,0,1
On Light#Lux<99 do
delay 300
gpio,0,0
thx
sawo
Re: Rules for bathroom ventilation
#2 Post by grovkillen » 16 Jun 2020, 21:02
Never use delay, it's blocking.
On System#Boot Do
 Let,1,0
EndOn
On Humidity#Level>65 Do
  Event,FanOn
EndOn
On Light#Lux>100 Do
  Event,FanOn
EndOn
On FanOn Do
  GPIO,0,1
  TimerSet,1,300
EndOn
On Rules#Timer=1 Do
  GPIO,0,0
EndOn
This rule will have the fan running until the lux and humidity is below those values and then run for 300 seconds.
sawo
#3 Post by sawo » 16 Jun 2020, 21:11
hi grovkillen,
thanks alot for your help again!!!
It works!!!
sawo
#4 Post by sawo » 05 Nov 2020, 13:57
Hi grovkillen,
do you think you can help me again with this rule?
I want to have a short delay of 30sec, before the fan turns on, when the lux value is greater then 100.
How can I realize this.
thx
sawo
#5 Post by grovkillen » 05 Nov 2020, 20:32
On System#Boot Do
 Let,1,0
EndOn
  If [Light#Lux]>100
    TimerSet,2,30
  Else
    Event,FanOn
  EndIf
EndOn
On Light#Lux>100 Do
  Event,FanOn
EndOn
On FanOn Do
  GPIO,0,1
  TimerSet,1,300
EndOn
On Rules#Timer=1 Do
  GPIO,0,0
EndOn
On Rules#Timer=2 Do
  Event,FanOn
EndOn
Patou
#6 Post by Patou » 05 Nov 2020, 22:07
I made recently a bathroom fan control based on light on / off ( lux detection was not possible because our bathroom has a window!).
The control is based on the idea to mesure the humidity when the light is switched on, to switch the fan if the humidity value is above a certain level for me : 40%.
Experrience shows me that the humidity change quickly after after fan runs because the humidity sensor near the fan mesures the real ambiance air humidity after some time. So i make a new mesure 60 sec after light on.
When light is switched off : new mesure and compare with value at beginning. If no change turn fan off. If humidity has increased, run the fan until hum level reachs the start level.
After 15 min stop fan anyway. If light is switched on when fan is running no new value is mesured because the deshumidification process is still ongoing : this could be the case to turn light on quickly after having turn thr light off.
Data are send to home assistant for management
See my rules below
See physical layout
and rules ... please delete comments to save space !!
On system#boot do
let,1,50 // Hum Ecl On
let,2,18 //Temp Ecl On
let,3,51 //Hum Ecl Off
let,4,19 // Temp Ecl Off
let,5,0 // Delta Hum
let,6,0 // Delta Temp
let,7,900 // Tempo max Fan on in sec
let,8,40  // low limit Hum %
let,9,0 // fan was not on
gpio,0,0 // Fan Off
// timer 1 :  check interval hum level if  Ecl = 0ff
// timer 2 : max run time of fan
// timer 3 : recheck Hum after Ecl On
On Ecl#State=1 do // Ecl On
 if [Fan#State] = 0
  Let,1,[Temp_Hum#°C]
  Let,2,[Temp_Hum#Hum%]
  Let,3,[Temp_Hum#°C]
  Let,4,[Temp_Hum#Hum%]
  Let,9,0
  TaskValueSet,12,1,[var#2] // Store actual hum in non volatile variable
  Let,9,1 // fan was on
 if [Temp_Hum#Hum%] > [var#8] // higher than low limit hum %
  Gpio,0,1 // Fan On
  Publish, %sysname%/Fan,"On"
 Timerset,3,60 // wait 60 sec and take a new hum mesure
 Publish, %sysname%/Ecl,"On"
On Rules#timer=3 do // new mesure 60 sec after Ecl = On (time needed for ambiance air to reach the fan hum sensor)
 if [Temp_Hum#Hum%]> [var#8] and [Ecl#State]=1
  Gpio,0,1 // Fan On
  Timerset,3,60
 if [Var#9] = 0 // only if fan was not already on
  Let,1,[Temp_Hum#°C]
On Ecl#State=0 do // Ecl Off -> store actual values in spare variables
 Let,3,[Temp_Hum#°C]
 Let,5,[var#3]-[var#1]
 Let,6,[var#4]-[var#2]
 TaskValueSet,12,2,[var#4]
 TaskValueSet,12,3,[var#6]
 Publish, %sysname%/Ecl,"Off"
 Timerset,1,10 // wait 10 sec
 Timerset,2,[var#7]
// Rules set 2
On Rules#timer=1 do
 if [var#5] <= 1 // If hum did not increase ...
  Gpio,0,0 // Fan off
  Publish, %sysname%/Fan,"Off"
 Let,3,[Temp_Hum#°C] // if not : reload the variables
 Publish, %sysname%/Hum1, [var#2]
 Publish, %sysname%/Hum2, [var#4]
 Publish, %sysname%/Delta_Hum, [var#6]
 Timerset,1,10
On Rules#timer=2 do
 Gpio,0,0 // after 15 min Fan off
 Timerset,1,0
On Temp_Hum#°C do
  Publish, %sysname%/Temp, [Temp_Hum#°C]
  Publish, %sysname%/Hum, [Temp_Hum#Hum%]
  Publish, %sysname%/Atm, [Temp_Hum#hPa]
Have fun ...
Patou
iron
#7 Post by iron » 06 Nov 2020, 11:45
Out of curiosity... why the 2 AC adapters ?
-D
-D
Patou
#8 Post by Patou » 06 Nov 2020, 14:32
One ac adapter is the power supply (on the board)
The other monitors the on /off of the light
Users browsing this forum: Bing [Bot] and 31 guests
