ESP-8266EX Soil sensor (chirp!) I2C problem
kochmi
#1 Post by kochmi » 05 Jul 2020, 15:56
Hello!
I tried to connect a chirp!-sensor to a wemos d1 mini using espeasy 20200703 (dev).
This is the sensor: https://wemakethings.net/chirp/
My problem: I can not get the I2C connection working. With various other devices the I2C connection is working perfectly. But connecting the chirp!-sensor not even brings a result in the I2C-Scan.
I tried two devices (display and chirp!-sensor) in the I2C-bus: the display is working well stand alone. As soon as the chirp!-Sensor is connected to the I2C-bus, the I2C-scan does not work any more.
Is there a "real" I2C-bus in the chirp!-sensor? The chirp!-sensor uses a ISP-bus:
pin 1 - MISO
pin 2 - VCC
pin 3 - SCK / SCL – I2C clock
pin 4 - MOSI / SDA – I2C data
pin 5 - RESET
pin 6 - GND
I connected VCC (3.3V) and GND. I2C: pin 3 and pin 4
Any suggestions??
Thanks a lot for your reply!
best regards
Michael
Re: ESP-8266EX Soil sensor (chirp!) I2C problem
#2 Post by TD-er » 05 Jul 2020, 19:41
On some boards that support both I2C and SPI, you may need to set the mode via a pin.
For example pull one pin to GND or VCC or maybe a solder pad on the board?
On the description page you linked, it states:
After reset Chirp reads capacitance and light levels. That can take from 1 up to 9 seconds if dark. If any I2C communication is received during that time, Chirp will switch into sensor mode - it will not chirp, just respond to I2C requests. The default address of the Chirp is 0x20.
So maybe you should try to run an I2C scan immediately after powering on the chirp board?
