Minimum doubleclick with 500ms possible?
Micha_he
#1 Post by Micha_he » 22 Jul 2020, 09:20
Is it possible (without disturbing other things) to reduce the minimal doubleclick time of the P001_Switch-Plugin to 500ms ?
The check inside the plugin seems to be ten-per-second...
Background of my questions is:
I would like to filter out GPIO-HIGH-signals smaller than ~0.5 seconds and
  • Debunce time is only max. 250ms
  • Rule-Timer are only greater than/equal 1sec
  • and the Doubleclick-time is actually greater than/equal than 1sec
If it's ok, I would do a pull request...
If it's not wanted, I would build a own special-firmware for this case.
Re: Minimum doubleclick with 500ms possible?
#2 Post by TD-er » 22 Jul 2020, 10:29
I see no reason why the doubleclick min limit cannot be decreased.
So a pull req. is welcome.
Micha_he
#3 Post by Micha_he » 22 Jul 2020, 11:10
Oh... damn, I mean the longclick minimal-interval ! In this case, double-clicking doesn't help me.
#4 Post by TD-er » 22 Jul 2020, 12:03
The answer remains the same.... with the added condition that you make up your mind before making the PR ;)
Micha_he
#5 Post by Micha_he » 24 Jul 2020, 09:52
