connect to host and send bytes
buzzger0815
#1 Post by buzzger0815 » 14 Aug 2020, 12:23
Hi there!
Is there a command or a controller with which i can connect to the socket of another host to send bytes to this host?
For example
  connecttoHost,192.168.1.1,12345 // connect to host 192.168.1.1 port 12345
  sendtoHost,192.168.1.1,I am connected // sendto (connected) Host the string "I am connected"
  senttoHost,192.168.1.1,0xa0 0x1d 0xff // sendto (connected) Host the bytes (in hex notation) a0 1d ff
Thank you!
Re: connect to host and send bytes
#2 Post by TD-er » 14 Aug 2020, 20:38
Something like a telnet connection you mean?
We don't have something like that.
If you need to send commands to another ESPEasy node, you could take a look at sendto
buzzger0815
#3 Post by buzzger0815 » 15 Aug 2020, 15:48
Yes, something like telnet.
I bought a wifi relais with esp8266, thinking that i can flash espeasy on it and use it. BUT they assembled a whatever microcontroler, which uses the esp8266 only as "wifi card", so no espeasy :(
But you can connect to the controler on the board and send commands, with which you can switch the relais on or off. So i tought i use espeasy to do the mqtt stuff and switch the relais by espeasy over the microcontroler socket commands.
But if there isn't such a function in espeasy, my plans are busted :) But no problem.
Thanks mate!
#4 Post by Ath » 15 Aug 2020, 17:53
buzzger0815 wrote: 15 Aug 2020, 15:48 I bought a wifi relais with esp8266,
What exact board did you buy?
buzzger0815
#5 Post by buzzger0815 » 18 Aug 2020, 01:06
Hi!
I bought this one
http://www.icstation.com/esp8266-wifi-c ... 12593.html
I wanted to use it to control a projector screen with it.
But i now bought a shelly 2.5, flashed espeasy on it and archived my needs, controlling a motorized projector screen via mqtt.
Users browsing this forum: Ahrefs [Bot] and 17 guests
