RFLINK SOMFY SGS
Posted: 27 Sep 2020, 17:28
I own an RFLINK 433.42 mhz.
For several weeks I have been trying to associate the module with my Somfy SGS portal.
Nothing works. There is no tutorial on this portal, only a tutorial on Somfy stores.
The procedure for associating a remote control is normally done by bringing the new remote control to the control box and leaving the opening button pressed for the time of association.
Whether in use or in association with a remote control, the RFLYNK (via RFLOADER RFLink Gateway V1.1 - R48) sees the frames pass.
The RFLINK records the automatic remote control with the Rolling Code in its "0" memory area.
Following this, the use of a command of the type "10; RTS; 87B2F8; 0; STOP;" increments the rolling code but the gate does not react.
However, I think that it does record an increment of the RC because if I use the remote control then, it is necessary to make two pushs that it works (surely so that the remote control catches up to the RC of the RFLINK)
Very surprisingly, when I listen to the frames of the remote control with RF, he sees an ID on 7 digits.
20; 0D; RTS; ID = 288b2f8; SWITCH = 01; CMD = STOP;
Otherwise it registers the remote control on a 6-digit address
RTS Record: 0 Address: 87B2F8 RC: 01F5
So I wonder if the problem might not come from the address which is truncated?
Or is the command correct ("STOP")?
Is there a step that I forget?
have you got any idea to help me
