SendToHttp Raw-Message
is it possible to send a RAW-Message from an ESPEasy-Device to another ESP-Device without ESPEasy, using SendToHttp?
"http://192.168.1.137/set_ist?IstTemp=21" for sending a value is working from a Browser.
But sending from ESPEasy it doesn't work.
Any ideas?
Greetings
Any ideas?
Greetings
Re: SendToHttp Raw-Message
What syntax did you use?
sendtohttp,192.168.1.137,80,/set_ist?IstTemp=21
Here is a Logging info:
5218580: ACT : sendtohttp,192.168.1.137,80,/set_ist?IstTemp=21
5218582: Command: sendtohttp
5218692: ACT : timerSet,1,30
5218693: Command: timerSet
but nothing received.
Does the other end require login?
Can you also try to check "SendToHTTP wait for ack" on Tools->Advanced page?
No login required.
I don't find "SendToHTTP wait for ack".
Is this Image to old? "ESP_Easy_mega-20191208_dev_ESP8266_4M1M.bin"
I think it is less than 10 months ago that I added this feature.
Now i tried the newest release with the Option "SendToHTTP wait for ack" but it doesn't work.
By sending only the IP-Address the receiving Device had to answer, but no reaction.
The syntax above is ok?
Just a few checks you can do:
Is the IP you try to reach in the same subnet as your ESP?
Do you use DHCP or static IP on the ESP? If static, please check you have the correct configuration, like correct gateway (needed when you try to reach something not in your subnet), correct subnetmask (e.g. 255.255.255.0 )
As far as I can judge from your log, the syntax looks OK.
Additional the ESPEasy-Device is connected to Fhem, and is working. Can this be possibly the problem?
All is in the same subnet, DHCP is used.
What other device is it where you want to connect to?
If you enable the debug log level you will see the actual request being sent. (given you have debug log level code included in the build, which isn't the case with "test" builds due to size restrictions)
This is only logged if the connection could be made to the other side.
As far as I can see in the code, there is (sadly) no other log indicating a failed connect.
So at least the command sendtohttp should also return a false state if it was not successful. (which it doesn't right now)
I just added an error log.
Can you test this test build?
https://www.dropbox.com/s/n1lyowdzksxww ... 4.zip?dl=0
Unfortunately i have only esp8266 in use
I tested UDP, it dont work too. With the tool Packet Sender it works.
Sorry, made a copy/paste error.
Here's the ESP8266 build: https://www.dropbox.com/s/92maswz93cww1 ... 4.zip?dl=0
Here is the error:
801437: Webserver args: 0: 'cmd' length: 47
805550: SendToHTTP connection failed
So it cannot make a connection to the other host.
Just make sure the port is correct and the rest of the URL.
You only showed what was logged, but can you also show (verbatim in code tags) the exact command you give?
This is what i have in the rules Set:
On Rules#Timer=1 do
SendToHTTP 192.168.1.137,80,/set_ist?IstTemp=21
timerSet,1,30
Port is the same in the other device, and the command is working from a Browser.
or only this line in Tools/Command:
" SendToHTTP 192.168.1.137,80,/set_ist?IstTemp=21"
On Rules#Timer=1 do
timerSet,1,30
Can you show the log (please include a line before and after, and any lines inbetween the cmd and sendtohttp lines) when sending it from the tools page (then it is working, as I read from your comment)?
Does it change if you copy the SendToHTTP command from the rules to your tools page and execute it?
No, both don't work.
this is the logoutput:
5599211: Webserver args: 0: 'cmd' length: 54
5599220: Command: SendToHTTP
5599221: SendToHTTP: Host: http://192.168.1.137 port: 80
5603362: SendToHTTP connection failed
if i send this:
from the tools-page.
if i send this:
Does your receiving ESP use ip filtering, just like ESPEasy (see Hardware tab)? and if so, is the sending ESP in the allowed range?
It looks much like the ESP's can't or won't see each other on the network. That includes having the sending ESP on a separate 'IoT' or guest network, that your router may not allow to access other segments of your network.
All ESPs are in the same network. Ping from PC is ok for all devices.
IP-filtering is only for access to the web interface.
Please show the network related part of the sysinfo page.
Just to be sure we're not missing something here.
Here it is:
Wifi: 802.11N (RSSI -44 dB)
IP Config: DHCP
IP / Subnet: 192.168.1.132 / 255.255.255.0
Gateway: 192.168.1.5
Client IP: 192.168.1.2
DNS: 192.168.1.5 / (IP unset)
Allowed IP Range: 192.168.1.0 - 192.168.1.255
STA MAC: EC:FA:BC:9B:E8:4D
AP MAC: EE:FA:BC:9B:E8:4D
SSID: X-NET-X (38:10:D5:D5:B0:8F)
Channel: 11
Connected: 4h37m
Last Disconnect Reason: (1) Unspecified
Number Reconnects: 0
IP Config: DHCP
Channel: 11
Connected: 4h37m
Meanwhile i tried to check the packets with Wireshark.
I didn't get packets from the sending device by using the SendToHttp-command as shown above, but packets to fhem are shown.
As i see, the device doesn't send the command.
Can anybody confirm that the command is working?
Is the receiving ESP by any chance using https as the protocol? Because your browser does connect, but most browsers nearly automatically use https.
ESPEasy doesn't support https (because of memory, flash-size and CPU restrictions), but a specific, maybe single function, ESP software can use https.
It's no https. Here are the most important parts from the WIFI-Settings of the receiving-device-sketch.
It should be all that i need:
#include <ESP8266WiFi.h>
#include <WiFiUDP.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <ESP8266HTTPUpdateServer.h>
IPAddress ip(192, 168, 1, 137);
IPAddress gateway(192, 168, 1, 5);
IPAddress subnet(255, 255, 255, 0);
ESP8266WebServer httpServer(80);
ESP8266HTTPUpdateServer httpUpdater;
WiFiUDP UDP;
WiFi.mode(WIFI_STA);
WiFi.hostname("Test");
WiFi.config(ip, gateway, subnet);
WiFi.begin(ssid, password);
UDP.begin(UDP_PORT);
httpUpdater.setup(&httpServer);
httpServer.begin();
MDNS.addService("http", "tcp", 80);
httpServer.on("/", handleRoot);
WiFiUDP UDP;
httpServer.begin();
Problem is solved:
Checkbox in my Fritzbox: "Die unten angezeigten aktiven WLAN-Geräte dürfen untereinander kommunizieren" marked, then it works.
That's for the guest network?
I've not seen that option in the normal WiFi.. when I still had a Fritzbox router.
It is widely known as a client-to-client-isolation at the AP level on most WiFi devices
But the http request shall return via the gateway so it should work anyways unless there is no other routing rule enabled at that level.
-D
-D
It's in WLAN/Sicherheit/Verschlüsselung FB7490 FW7.21
