Yep, it really does, but it depends on your use case whether that's an issue.
This is what happens;
The ESP does turn off the radio for longer amounts of time.
Normally an access point does send out a beacon at every so called "beacon interval".
A typical beacon interval is ~100 msec (102.4 msec).
When you try to send data to a connected WiFi station, your access point first tries to send directly to the node and if it doesn't immediately reply, the access point includes a notification for this node in such a beacon package.
Meaning, if you send a ping (or just any package) to a WiFi connected node, the first reply typically takes half this interval. (later ping replies may receive a response more quickly as the radio may be on continuously)
If the ESP (or any other WiFi device in "power save mode") is not listening to each beacon interval, it may take longer to reach the node.
Such a "listen interval" is called a DTIM interval and is often set between 1 and 3 for almost all WiFi devices.
I'm not entirely sure what the ESP uses when consuming ~80 mA, but I think it has the radio on all the time, effectively receiving packets before the next beacon interval.
Here a quick test I performed on 2 of my ESPEasy nodes.
One with "Eco mode" enabled and one disabled:
gijs@DESKTOP-QLB7N8I:~/GitHub/letscontrolit/ESPEasy$ ping 192.168.10.92
PING 192.168.10.92 (192.168.10.92) 56(84) bytes of data.
64 bytes from 192.168.10.92: icmp_seq=1 ttl=254 time=6.51 ms
64 bytes from 192.168.10.92: icmp_seq=2 ttl=254 time=4.24 ms
64 bytes from 192.168.10.92: icmp_seq=3 ttl=254 time=104 ms
64 bytes from 192.168.10.92: icmp_seq=4 ttl=254 time=3.01 ms
^C
--- 192.168.10.92 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3005ms
rtt min/avg/max/mdev = 3.007/29.329/103.562/42.876 ms
gijs@DESKTOP-QLB7N8I:~/GitHub/letscontrolit/ESPEasy$ ping 192.168.10.211
PING 192.168.10.211 (192.168.10.211) 56(84) bytes of data.
64 bytes from 192.168.10.211: icmp_seq=2 ttl=254 time=885 ms
64 bytes from 192.168.10.211: icmp_seq=4 ttl=254 time=40.9 ms
64 bytes from 192.168.10.211: icmp_seq=5 ttl=254 time=34.8 ms
64 bytes from 192.168.10.211: icmp_seq=7 ttl=254 time=85.6 ms
^C
--- 192.168.10.211 ping statistics ---
13 packets transmitted, 4 received, 69.2308% packet loss, time 12323ms
rtt min/avg/max/mdev = 34.788/261.588/885.111/360.524 ms
As you can see, one of them did not reply on all ping packets and the first ping took quite some time to get a reply.
N.B. both are connected to the same access point.
What happens if you try to reach any host on your network?
Case 1, your PC does not know the MAC address of the ESP:
- Your PC tries to find the MAC address belonging to an IP address using an ARP packet (question is like: "Who has 1.2.3.4?")
- ARP packets gets broadcasted to the entire network
- If the ESP misses such an ARP request, you cannot route the IP packet to your ESP. -> fail
Case 2, your PR does know the MAC address of the ESP, but a switch or access point does not:
- Your PC sends out a packet for MAC belonging to your ESP
- Switch does not know how to rout and discards packet
- timeout on your PC.
Work around: Send Gratuitous ARP packets (answer to a question nobody asked)
- ESP sends "AA:BB:CC:DD:EE:FF has IP 1.2.3.4"
- All switches, access points and hosts on your network receiving this packet update their ARP table
- Roundtrip time of routing packet depends only on DTIM interval of the ESP.
TL;DR
If you only send data from your ESP to something like a broker, then using "Eco" mode does probably have little to no effect on WiFi performance.
If you need a swift response (e.g. turning on a light), then you should not use "Eco" mode.
