send value from one OSP to OLED of another ESP
I'm trying toi send some values from one ESP mesauring temperature etc... to the oled screen of another ESP
The command http://192.168.0.63/control?cmd=OLEDFRAMEDCMD,1,'Hello World'
is working well
now, I want to update temperature from another ESP
I create the following rule
on Temperature#Temperature do
SendToHTTP,192.168.0.63,80,/control?cmd=OLEDFRAMEDCMD,2,Sauna=[Temperature#Temperature]
I suppose that for any change of Temperature, the SentToHTTP will be called to send the temperature. but nothing happen
I tried by using a dummy variable in ESP_OLED and TaskValueSet command
SendTo,13,'TaskValueSet,10,1,Sauna=[Temperature#Temperature]'
My problem is to add a measurement in the command to send
Thomas
is working well
Thomas
Re: send value from one OSP to OLED of another ESP
You need to quote arguments containing commas or spaces paased to SendToHTTP or SendTo, as it sees those as separators, and won't glue them together itself. Quotes can be ", " or `, just use one pair that is not used in the list of arguments you're quoting.
Yep.
See also: https://github.com/letscontrolit/ESPEasy/issues/2724
SendToHTTP,192.168.0.63,80,"/control?cmd=OLEDFRAMEDCMD,2,Sauna=[Temperature#Temperature]"
Hello, can someone help me ?
i have this rule, but it doesn't work... where 'fumo' is the device's name.
On [fumo]#State do
If [fumo]#State=0
SendToHTTP,192.168.1.129,80,"/control?cmd=NEXTION,sleep=1"
Else
SendToHTTP,192.168.1.129,80,"/control?cmd=NEXTION,sleep=0"
Endif
Thankyou for your help
namxcap
On [fumo]#State do
If [fumo]#State=0
Else
Endif
namxcap
The syntax should be [taskname#varname], not [taskname]#varnamenamxcap wrote: ↑07 May 2021, 00:14 Hello, can someone help me ?
On [fumo]#State do
If [fumo]#State=0
Else
Endif
namxcap
I don't know why but it's no working ......
This is the correct syntax:
On fumo#State do
If [fumo#State]=0
Else
Endif
- the line "if [fumo#state]=0" should have [] included, now it is the value that needs to be checked; when having these [] it is replaced by the value (if that taskname/value is available)
YES !!! Now it works .... i learned one more thing !!!
Thankyou very much
Thankyou very much
Users browsing this forum: Ahrefs [Bot] and 33 guests
