Simple time rule to reset a value every 1h
ciscomike
#1 Post by ciscomike » 10 Feb 2021, 18:27
Hi everyone,
I'm looking for a simple rule to reset a total counter of a pulse sensor to zero every one hour.
I've tried different way to write the rule using for example TaskValueSet etc, also tried to find a solution through the wiki but I couldn't.
The Task No. is 4 and the Value 2 OR Wind_Speed and Wind_Total.
Any help would be really appreciated
Re: Simple time rule to reset a value every 1h
#2 Post by TD-er » 10 Feb 2021, 18:55
The command to reset the pulse counter is resetpulsecounter, with an optional parameter for task index.
So your rules will be something like this:
on Clock#Time=All,**:00 do
  resetpulsecounter,4
N.B. not tested code.
See: https://espeasy.readthedocs.io/en/lates ... Rules.html (Ctrl-F for "Clock#Time")
ciscomike
#3 Post by ciscomike » 10 Feb 2021, 19:01
That worked GREAT for me!
Thank you @TD-er
