[SOLVED] Admin password not accepted, no response to serial commands
Posted: 16 Mar 2021, 12:30
I've just flashed the latest release from Github to my Wemos D1 Mini. All worked well, I connected to the access point, configured my network, accessed it through there, set a device name.
Now I've run into a problem. I set the admin password in the web interface, but cannot connect with the exact password I entered (I generated one with Lastpass and immediately saved it).
I have found these other forum threads:
viewtopic.php?t=6607
viewtopic.php?f=4&t=6607&p=36267#p36267
viewtopic.php?f=6&t=7283&p=41257#p41257
viewtopic.php?t=591
So I tried what was suggested: rebooting with RX and TX connected, and sending "reset" or "password,newpass" through the serial monitor.
Unfortunately none of this seems to work.
In the Serial Monitor of the Arduino IDE I'm receiving logs about the device trying to connect to my WiFi network. But it doesn't respond anything when I send "reset" or "password" or "reboot" or anything else (tried with and without capitalization). I read that re-flashing would not wipe the config, so I don't know what to try next.
Any suggestions would be very much appreciated!
viewtopic.php?t=591
