esp switch+relay <-> domoticz no stop!
hestia
#1 Post by hestia » 20 Mar 2021, 14:24
Hello dear community
My first post… I new in this forum, new with espeasy, new with esp…
I’d like to use a Sonoff 4CHR3 to open and close 4 valves, driven by Domoticz.
So far I think I’ve succeeded in flashing the Sonoff. To be checked and for the record (for other beginners like me, because it was difficult for me to find information that are obvious for most of the community), I did:
what is described at the beginning of this video https://notenoughtech.com/sonoff/flashi ... usel-23132
with info how to put the FTD1232 (USB to TTL Serial Adapter) on 3.3V (and not 5V) with the jumper https://wombat3.kozo.ch/j/smarthome/985 ... -operation
I took this release mega-20210223 https://github.com/letscontrolit/ESPEas ... a-20210223
and the normal esp8285 1M bin
Screenshot 2021-03-20 101026.png (144.38 KiB) Viewed 6695 times
Did I took the right version, it seems to be pre-release, is there a release?
I didn’t succeeded with the postflash action, but in the end I could connect the Sonoff 4CHR3
I did 4 buttons and 4 relays like this
Screenshot 2021-03-20 101407.png (134.92 KiB) Viewed 6695 times
And rules like this
on Button1#State do
  if [Relay1#State]=0
    gpio,12,1
    gpio,12,0
Some relays were on (up?) at the start the sonoff so I put this in the boot
on System#Boot do
   gpio,12,0
   gpio,5,0
   gpio,4,0
   gpio,15,0
But after this, some buttons seemed to be activated at the boot (even though I don’t even have rules on them!)
So I added a flag to avoid it
on System#Boot do
   Let, 1, 0
   Let, 2, 0
   Let, 3, 0
   Let, 4, 0
   gpio,12,0
   gpio,5,0
   gpio,4,0
   gpio,15,0
on Button1#State do
LogEntry,'*** Button1 ? ***'
if [int#1]!=0
LogEntry,'*** Button1 OK ***'
  if [Relay1#State]=0
    gpio,12,1
    gpio,12,0
Let, 1, 1
Is it normal that gpio went to 1 at the boot? (I read, it is for gpio 0, but the others)
What is the best practice to handle this?
After I added a communication with Domoticz with mqtt to update user variables like this
on Button1#State do
if [int#1]!=0 // gpio 0 is at 0 on boot
  if [Relay1#State]=0
    gpio,12,1
    Publish domoticz/in,'{"command": "setuservariable", "idx": 13, "value": 30 }'
    gpio,12,0
    Publish domoticz/in,'{"command": "setuservariable", "idx": 13, "value": 0 }'
Let, 1, 1
(the value is the time to let the valves open, to add rules after...)
This part seemed to be ok
With the other direction troubles arrived :-(
I used the Generic - MQTT Import to receive value from Domoticz
Screenshot 2021-03-20 102821.png (46.6 KiB) Viewed 6695 times
And a script in Domoticz triggered by the user variable update
   on =        {
                variables = VARIABLES
mosquitto_pub -t domoticz/out/RSDz1 -m 77
At that point the update back in the sonoff is done but Button1 is triggered in the Sonoff and also all other Buttons !
Log extract
24310: inputswitchstate is deprecatedinputSwitchState,4,0.00
24319: inputswitchstate is deprecatedinputSwitchState,5,0.00
24327: inputswitchstate is deprecatedinputSwitchState,6,0.00
24337: inputswitchstate is deprecatedinputSwitchState,7,0.00
24364: IMPT : [RelaysSecondsInDz#RelaySecondsInDz1] : 77.00
24371: EVENT: Button1#State=0
24378: ACT : LogEntry,'*** Button1 ? ***'
24380: *** Button1 ? ***
24389: ACT : LogEntry,'*** Button1 OK ***'
24391: *** Button1 OK ***
24419: ACT : gpio,12,0
24422: GPIO : port#12: set to 0
24429: ACT : Publish domoticz/in,'{'command': 'setuservariable', 'idx': 13, 'value': 0 }'
24448: ACT : Let, 1, 1
24678: EVENT: Button2#State=0
25406: *** Button4 OK ***
25423: ACT : gpio,15,1
25425: GPIO : port#15: set to 1
25431: ACT : Publish domoticz/in,'{'command': 'setuservariable', 'idx': 16, 'value': 30 }'
25463: ACT : Let, 4, 1
What I don’t understand is why something is triggered when "MQTT import" receives something because there are no rules on it.
After the system never stops and all relays are switched on and off ; I had to stop the script on Domoticz to stop it!
What is wrong in my understanding?
What are the best practice to avoid this?
hestia
#2 Post by hestia » 22 Mar 2021, 00:18
I did the same test with a Wemos, and same issue
What is strange is that it is the same even though the Generic - MQTT Import is disabled
and more strange (for me) also when the Generic - MQTT Import is deleted
240500 : Info   : SW  : GPIO=13 State=0 Output value=0
240512 : Info   : EVENT: Button1#State=0
240523 : Info   : ACT  : LogEntry,'*** Button1 OK ***'
240526 : Info   : *** Button1 OK ***
240543 : Info   : ACT  : gpio,5,1
240546 : Info   : GPIO : port#5: set to 1
240553 : Info   : ACT  : Publish domoticz/in,'{"command": "setuservariable", "idx": 13, "value": 30 }'
240582 : Info   : ACT  : LogEntry,'*** Relay1 0 -> 1 ***'
240584 : Info   : *** Relay1 0 -> 1 ***
240604 : Info   : ACT  : Let,1,1
240731 : Info   : SW  : GPIO=5 State=1 Output value=1
240743 : Info   : EVENT: Relay1#State=1
240999 : Error  : inputswitchstate is deprecatedinputSwitchState,0,0.00
241010 : Error  : inputswitchstate is deprecatedinputSwitchState,1,0.00
241022 : Error  : inputswitchstate is deprecatedinputSwitchState,2,0.00
241034 : Error  : inputswitchstate is deprecatedinputSwitchState,3,0.00
241046 : Error  : inputswitchstate is deprecatedinputSwitchState,4,0.00
241057 : Error  : inputswitchstate is deprecatedinputSwitchState,5,0.00
241068 : Error  : inputswitchstate is deprecatedinputSwitchState,6,0.00
241079 : Error  : inputswitchstate is deprecatedinputSwitchState,7,0.00
241091 : Info   : EVENT: Button1#State=0
241102 : Info   : ACT  : LogEntry,'*** Button1 OK ***'
241105 : Info   : *** Button1 OK ***
241138 : Info   : ACT  : gpio,5,0
241141 : Info   : GPIO : port#5: set to 0
241149 : Info   : ACT  : Publish domoticz/in,'{"command": "setuservariable", "idx": 13, "value": 0 }'
241179 : Info   : ACT  : LogEntry,'*** Relay1 1 -> 0 ***'
241181 : Info   : *** Relay1 1 -> 0 ***
241188 : Info   : ACT  : Let,1,1
241308 : Info   : SW  : GPIO=5 State=0 Output value=0
241319 : Info   : EVENT: Button2#State=1
241358 : Info   : ACT  : LogEntry,'*** Button2 OK ***'
241361 : Info   : *** Button2 OK ***
241391 : Info   : ACT  : gpio,16,0
241394 : Info   : GPIO : port#16: set to 0
241400 : Info   : ACT  : Publish domoticz/in,'{"command": "setuservariable", "idx": 14, "value": 0 }'
241430 : Info   : ACT  : LogEntry,'*** Relay2 1 -> 0 ***'
241432 : Info   : *** Relay2 1 -> 0 ***
241439 : Info   : ACT  : Let,2,1
241528 : Info   : SW  : GPIO=16 State=0 Output value=0
241538 : Info   : EVENT: Button3#State=1
241609 : Info   : ACT  : LogEntry,'*** Button3 OK ***'
241612 : Info   : *** Button3 OK ***
241643 : Info   : ACT  : gpio,12,0
241645 : Info   : GPIO : port#12: set to 0
241651 : Info   : ACT  : Publish domoticz/in,'{"command": "setuservariable", "idx": 15, "value": 0 }'
241681 : Info   : ACT  : LogEntry,'*** Relay3 1 -> 0 ***'
241683 : Info   : *** Relay3 1 -> 0 ***
241691 : Info   : ACT  : Let,3,1
241752 : Info   : SW  : GPIO=12 State=0 Output value=0
241762 : Info   : EVENT: Button4#State=1
241857 : Info   : ACT  : LogEntry,'*** Button4 OK ***'
241862 : Info   : *** Button4 OK ***
241888 : Info   : ACT  : gpio,0,0
241891 : Info   : GPIO : port#0: set to 0
241895 : Info   : ACT  : LogEntry,'*** Relay4 1 -> 0 ***'
241897 : Info   : *** Relay4 1 -> 0 ***
241904 : Info   : ACT  : Let,4,1
241947 : Info   : SW  : GPIO=0 State=0 Output value=0
241957 : Info   : EVENT: Relay1#State=1
242105 : Info   : EVENT: Relay2#State=1
242255 : Info   : EVENT: Relay3#State=1
242401 : Info   : EVENT: Relay4#State=1
242541 : Info   : EVENT: Relay1#State=0
242679 : Info   : WD   : Uptime 4 ConnectFailures 0 FreeMem 19248 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
242691 : Info   : EVENT: Relay2#State=0
242828 : Error  : inputswitchstate is deprecatedinputSwitchState,0,0.00
242839 : Error  : inputswitchstate is deprecatedinputSwitchState,1,0.00
242851 : Error  : inputswitchstate is deprecatedinputSwitchState,2,0.00
242862 : Error  : inputswitchstate is deprecatedinputSwitchState,3,0.00
242873 : Error  : inputswitchstate is deprecatedinputSwitchState,4,0.00
242885 : Error  : inputswitchstate is deprecatedinputSwitchState,5,0.00
242897 : Error  : inputswitchstate is deprecatedinputSwitchState,6,0.00
242908 : Error  : inputswitchstate is deprecatedinputSwitchState,7,0.00
One more test, it is the same with 1 switch and 1 relay !
20209 : Info   : SW  : GPIO=13 State=0 Output value=0
20219 : Info   : EVENT: Button1#State=0
20232 : Info   : ACT  : LogEntry,'*** Button1 OK ***'
20240 : Info   : *** Button1 OK ***
20261 : Info   : ACT  : gpio,5,1
20263 : Info   : GPIO : port#5: set to 1
20270 : Info   : ACT  : Publish domoticz/in,'{"command": "setuservariable", "idx": 13, "value": 30 }'
20302 : Info   : ACT  : LogEntry,'*** Relay1 0 -> 1 ***'
20305 : Info   : *** Relay1 0 -> 1 ***
20325 : Info   : ACT  : Let,1,1
20451 : Info   : SW  : GPIO=5 State=1 Output value=1
20460 : Info   : EVENT: Relay1#State=1
32408 : Info   : WD   : Uptime 1 ConnectFailures 0 FreeMem 19960 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
36010 : Info   : SW  : GPIO=13 State=0 Output value=1
36019 : Info   : EVENT: Button1#State=1
36030 : Info   : ACT  : LogEntry,'*** Button1 OK ***'
36032 : Info   : *** Button1 OK ***
36063 : Info   : ACT  : gpio,5,0
36066 : Info   : GPIO : port#5: set to 0
36072 : Info   : ACT  : Publish domoticz/in,'{"command": "setuservariable", "idx": 13, "value": 0 }'
36102 : Info   : ACT  : LogEntry,'*** Relay1 1 -> 0 ***'
36104 : Info   : *** Relay1 1 -> 0 ***
36111 : Info   : ACT  : Let,1,1
36230 : Info   : SW  : GPIO=5 State=0 Output value=0
36239 : Info   : EVENT: Relay1#State=0
36762 : Error  : inputswitchstate is deprecatedinputSwitchState,0,0.00
36774 : Error  : inputswitchstate is deprecatedinputSwitchState,4,0.00
36811 : Info   : EVENT: Button1#State=1
36823 : Info   : ACT  : LogEntry,'*** Button1 OK ***'
36825 : Info   : *** Button1 OK ***
36840 : Info   : ACT  : gpio,5,1
36843 : Info   : GPIO : port#5: set to 1
36851 : Info   : ACT  : Publish domoticz/in,'{"command": "setuservariable", "idx": 13, "value": 30 }'
36881 : Info   : ACT  : LogEntry,'*** Relay1 0 -> 1 ***'
36883 : Info   : *** Relay1 0 -> 1 ***
36904 : Info   : ACT  : Let,1,1
37028 : Info   : SW  : GPIO=5 State=1 Output value=1
37038 : Info   : EVENT: Relay1#State=0
37181 : Info   : EVENT: Relay1#State=1
37549 : Error  : inputswitchstate is deprecatedinputSwitchState,0,0.00
37560 : Error  : inputswitchstate is deprecatedinputSwitchState,4,0.00
I'll change the title if possible
Re: esp switch+relay <-> domoticz no stop!
#3 Post by Ath » 22 Mar 2021, 08:08
If you are using push buttons on the default Switch settings, then please be aware that the event you handle here: (and: please share your Switch settings)
on Button1#State do
  if [Relay1#State]=0
    gpio,12,1
    gpio,12,0
is fired twice, once when depressing the switch, and again when releasing the switch.
When using a 'normal' switch this of course shouldn't happen (though it may if you don't use any de-bouncing).
To avoid 'double-firing' an event you could change that to:
on Button1#State=0 do
And simplifying the IF would end you up with:
  gpio,12,=![Relay1#State] // Invert relay state
(I put in the = to avoid confusion when reading the log as it completes the expression parsing)
hestia
#4 Post by hestia » 22 Mar 2021, 09:08
Thanks Ath for your reply
my switch is Push Button Active Low
Screenshot 2021-03-22 090355.png (37.75 KiB) Viewed 6659 times
I've tried your suggestion,
, but with '=0' the switch works only once of 2 times, and it didn't solve the trigger back from domoticz
34823 : Error  : inputswitchstate is deprecatedinputSwitchState,0,0.00
34834 : Error  : inputswitchstate is deprecatedinputSwitchState,4,0.00
I don't know why it is deprecated because it is not present in domoticz
As a workaround,, I added a flag with a timer, but I think it is dirty
on Button1#State do
  LogEntry,'*** Button1 ?? ***'
  if [int#1]!=0 and [int#5]!=0 // gpio 0 is at 0 on boot
    if [Relay1#State]=0
      gpio,5,1
      gpio,5,0
    Let,5,0
    TimerSet,1,3
  Let,1,1
on Rules#Timer=1 do
   Let,5,1
I kept the test on the relay state because I need it to choose what to send to domoticz
#5 Post by Ath » 22 Mar 2021, 09:21
hestia wrote: 22 Mar 2021, 09:08 I've tried your suggestion,
Ah, yes, for a push button config it does that.
And I see you've got the De-bounce covered.
There is a similar discussion going on in the Github issues area: https://github.com/letscontrolit/ESPEasy/issues/3544
You could monitor that to see what you can learn there, repeating the same information here doesn't seem helpful.
hestia
#6 Post by hestia » 22 Mar 2021, 09:45
thanks
I'll read it better to night...
It is relative, but it is not the same "scope"
scope: switch on/off the light using wall switch and use domoticz as well to control the status of the light and switch on/off also the light from domoticz.
My scope is "send a value to a user variable in domoticz, which is not changed by domoticz and in reverse receiving another value"
hestia
#7 Post by hestia » 23 Mar 2021, 14:18
I've read the discussion going on in the Github issues area: https://github.com/letscontrolit/ESPEasy/issues/3544
and didn't find answer to my problem which is get data from domoticz with mqtt when having switch input (connected or not with domoticz) without interfere with thoses switches
hestia
#8 Post by hestia » 24 Mar 2021, 07:54
Hi again
I did it with an "asynevent"
domoticz:
http://esptest/control?cmd=asyncevent,DzTimeSec1=90
esp:
on DzTimeSec1 do
instead of "Generic - MQTT Import"
and I've used your tip for
simplifying the IF
on Button1#State do
if [int#1]!=0
    gpio,5,=![Relay1#State]
    Let, 5, [Relay1#State]-1
    Publish domoticz/in,'{"command": "setuservariable", "idx": 13, "value": [VAR#5]}'
    TaskValueSet 9,1,[VAR#5]
    Let, 5,abs([VAR#5])*60
    TimerSet,1,[VAR#5]
  Let,1,1
on DzTimeSec1 do
  TaskValueSet 9,1,%eventvalue%
  if [Relay1#State]=0 and %eventvalue% !=0
    Publish domoticz/in,'{"command": "setuservariable", "idx": 13, "value": %eventvalue%}'
    gpio,5,1
    TimerSet,1,60
  if [Relay1#State]=1 and %eventvalue% =0
    gpio,5,0
    TimerSet,1,0
Another question, even it is not directly relative to this topic...
As I have 3 switches / relays, is there a way to avoid to triplicate the previous code?
Screenshot 2021-03-24 075137.png (129.01 KiB) Viewed 6516 times
#9 Post by Ath » 24 Mar 2021, 08:26
hestia wrote: 24 Mar 2021, 07:54 Another question, even it is not directly relative to this topic...
As you have seen, you can use eventhandlers as 'subroutines', by using the 'AsyncEvent' (or 'Event' but that's not advised anymore) command. This command can accept up to 4 arguments, %eventvalue1% through %eventvalue4%.
You do have a couple of variable parameters, the GPIO pin, Relay number and Domoticz IDX value, and the rules allow constructs like [VAR#%eventvalue1%] (untested for now, it is known to work with [VAR#%v50%], so might need to assign %eventvalue1% to a variable first), so combining all that you can then use code like this:
on Button1#State do
  if [int#1]!=0
    AsyncEvent,handleButton=5,1,13
  Let,1,1
on Button2#State do
  if [int#2]!=0
    AsyncEvent,handleButton=16,2,14 // IDX was guessed
  Let,2,1
// Usage: AsyncEvent,handleButton=<gpio>,<relay>,<idx> // Fill in the correct values, uses timers 1..4 !
on HandleButton do
    gpio,%eventvalue1%,=![Relay%eventvalue2%#State]
    Let, %eventvalue1%, [Relay%eventvalue2%#State]-1
    Publish domoticz/in,'{"command": "setuservariable", "idx": %eventvalue3%, "value": [VAR#%eventvalue1%]}'
    TaskValueSet 9,%eventvalue2%,[VAR#%eventvalue1%] // Supports max. 4 relays!
    Let, %eventvalue1%,abs([VAR#%eventvalue1%])*60
    TimerSet,%eventvalue2%,[VAR#%eventvalue1%]
on Rules#Timer=1 do
// Turn off GPIO?
NB: All 'air-code' (untested)
hestia
#10 Post by hestia » 25 Mar 2021, 20:12
I did some testing and it is clear now
Thanks Ath :-)
#11 Post by Ath » 25 Mar 2021, 21:25
You're welcome :)
