Syntax question regarding var and calculation with it
chromo23
#1 Post by chromo23 » 22 Mar 2021, 11:46
can i use variables as a trigger like:
On var#1 do
or
On var#1=1 do
Couldn’t find an answer to it yet
And calulations are done like this i thought:
if [ai#Analog] > [var#5] - 100
but i didn´t work like this....(or i did somerwere else a mistake)
On this way i want to show my recent project and thank all the people here that made it softwarewise possible:
It’s called MuFuDi (MultifuncionalDisplay)
It has two tm1637modules and a ldr for dimming the brightness of the displays in the front when it gets dark.
Also a touchbutton sits on top to switch between different modes (eg: shortpress for showing values of different nodes and longpress activates the nightlightfunktion)
inside is a triple ws2812 led-module for the night light as a visual status feedback. (it glows red when humidity reaches a certain level)
a bme280 sits in the foot...
Re: Syntax question regarding var and calculation with it
#2 Post by TD-er » 22 Mar 2021, 11:51
When calculations (often in compares like an if-statement) you should try to store it first in a variable using the let command
let,15,[var#5] - 100
if [ai#Analog] > [var#15]
Variable updates never trigger an event, so "On var#1=1 do" will not work.
If you need to handle an event on a variable update, you should call an event with an event name you made up yourself
Preferrably use "asyncevent" and not "event" as it will then added to the event queue and dealt with later.
When using "event" it will be executed immediately and thus consume a lot more resources (especially if that event handler also triggers an event, etc)
