copy_files.py: Show current timestamp in the build output
Kim_Panda
#1 Post by Kim_Panda » 28 Mar 2021, 18:05
During my recent development I found it helpful to see the current timestamp at the end of the build process.
This makes it more save to allocate the related .bin file, specially if you do several consecutive builds.
Currently only the duration of the build is shown.
I achived that by simply adding the following two lines right at the end of "copy_files.py"
import datetime
print("\u001b[33m Timestamp:\u001b[0m", datetime.datetime.now())
    for suff in [".elf", ".bin", ".bin.gz", "-factory.bin", ".env.txt"]:
        copy_to_build_output(split_path[0], variant, suff)
    import datetime
env.AddPostAction("$BUILD_DIR/${PROGNAME}.bin", [bin_elf_copy])
This could be helpful for others, too.
Would you mind taking it over in the official ESPEasy build?
Re: copy_files.py: Show current timestamp in the build output
#2 Post by Ath » 28 Mar 2021, 18:11
That is a fine idea.
You can add that in a separate PR, but if you find that too much of a hassle, I'll do that for us :D
#3 Post by Ath » 28 Mar 2021, 18:26
Created PR #3562 for this improvement.
Kim_Panda
#4 Post by Kim_Panda » 01 Apr 2021, 17:23
Thanks a lot.
