Any news to use a Switch/Dimmer with 50Hz input
Posted: 08 Apr 2021, 13:29
I have not noticed all the ESPEasy-changes in the last months...
Are there any news on making a 50Hz-input workable with ESPEasy, without modify the circuit with a electrolytic capacitor? As used e.g. by MOES-switches input's.
Can we configure the switch-input-plugin (or modify the source-code), so that we get the following behavior:
1. When the signal at the input changes to 1 with a 50Hz frequency, we get a constant 1 result (only a single event).
2. If the signal falls to 0 for a period of xxx ms, then the internal result switch back to 0.
In summary: A delay only in the direction from 1 to 0.
The pulse-counter-plugin wasn't a solution in the last test (~ one year ago), because ESPEasy always crashed with the high count of pulses.
I'm searching for a solution, to use a mini-dual-switch (e.g. like this one), with dual-channel input and would like to stay with ESPEasy
