Why the "if %systime% condition doesn't work both ways?
GG42
#1 Post by GG42 » 12 Apr 2021, 20:08
My purpose is to have a kind of perpetual timer in a definite time slot.
The following rules work well when booted within the time slot and rightly stop at its end, BUT:
point 1: when booted before the time slot, it doesn't work, why? where is the mistake?
point2: when it runs properly, in case of current failure, it doesn't restart. Is it normal?
on System#Boot do
  gpio,13,1  //to be sure it is OFF
  timerSet,3,1
on Rules#Timer=3 do
    if %systime%>19:02:00 and %systime%<19:56:00
          gpio,13,0               // switch ON
          timerSet,7,10           // ON during 10 sec
              on Rules#Timer=7 do
              gpio,13,1          // switch OFF
              timerSet,3,5       // OFF during 5 sec
     gpio,13,1                   //out of time-range, switch OFF
Reason: Added code-tags to improve readability
Re: Why the "if %systime% condition doesn't work both ways?
#2 Post by TD-er » 12 Apr 2021, 20:43
I edited your post to add code wrappers, which makes it quite easy why your code does not work.
Each "if" should end with an "endif" and "on" should end with "endon".
Example taken from the rules documentation:
on <trigger> do
 if <test>
   <action>
   <action>
#3 Post by Ath » 12 Apr 2021, 20:51
GG42 wrote: 12 Apr 2021, 20:08 My purpose is to have a kind of perpetual timer in a definite time slot.
on System#Boot do
timerSet,3,1
on Rules#Timer=3 do
on Rules#Timer=7 do
- Your rules are to be between the 'on <test> do' and 'endon' statements, so no 'if' outside of that
- adding [ code ] [/ code ] (without the spaces) around the code will render it much more readable (TD-er did that for you :D)
- TimerSet only activates the timer once, and you haven't added a re-activate when the condition isn't met
on System#Boot do
  timerSet,3,1
on Rules#Timer=3 do
    TimerSet,3,60 // check again after 60 seconds
on Rules#Timer=7 do
NB: This is only one way to tackle this challenge.
GG42
#4 Post by GG42 » 12 Apr 2021, 22:49
Many thanks Ath, it works well now, however with the exception of a dozen of "1-0-1-0..." just after the boot. But I don't know if there is a way to solve that!
