flash writes happen to often.....?
Posted: 13 Apr 2021, 09:29
First of all i am not sure if i understand the flash counter right
Does that mean i had in 24h 27 flash writes and also 38 reboots?
And will it be reset after 24h or only after a power cycle or flashcounter reset
Why is this happening on a device where it shouldn’t happen at all? (i have a lot espeasy powered devices that don´t do it)
Rules:
My Devices:
Build: 20110 - Mega (Sonoff s20)
So either the Hardware has an issue or i did something wrong in rules or the rest of the configuration.
Any suggestions?
Flash Writes: 27 daily / 38 boot
Rules:
on System#Boot do
TaskValueSet 4,1,1
TaskRun,3
On toggle do
if [Relay#State]=0
if [dummy#var]=1
let,2,1
TaskValueSet 4,1,0
gpio,12,1
timerSet,2,14400
if [var#2]=1
TaskValueSet 4,1,1
let,2,0
gpio,12,0
On Button#State=1 do
event,toggle
On Button#State=11 do
if [dummy#var]=1
TaskValueSet 4,1,0
gpio,12,0
TaskValueSet 4,1,1
On WiFi#Connected do
SendToHTTP,api.thingspeak.com,80,/update?api_key=******&field1=[sensor#Temperature]&field2=[sensor#Humidity]
timerSet,1,59
Let,1,0
On Rules#Timer=1 do
Let,1,[VAR#1]+1
if [var#1]<5
TaskRun,3
Let,1,0
timerSet,1,59
On aan do
TaskValueSet 4,1,1
On aaus do
TaskValueSet 4,1,0
On dummy#var=1 do
if [sensor#Humidity]>=75
gpio,12,1
if [sensor#Humidity]<=71 and [dummy#var2]=1
gpio,12,0
On Rules#Timer=2 do
event,toggle
On dummy#var do
if [dummy#var]=1
gpio,13,0
gpio,13,1
Any suggestions?
