I could upload the firmware : ESP_Easy_mega-20200426_normal_ESP8266_4M1M.bin to my D1Mini ESP8266.
After a reset, I also could connect to the IP 192.168.4.1.
I changed the SSID and set the password. The problem after 20s nothing append. I'm still on the IP 192.168.4.1.
What are the possible causes of this problem?
Otto
Wifi Setup Wizard / D1 Mini ESP8266
Re: Wifi Setup Wizard / D1 Mini ESP8266
After a successful connect attempt it will save the credentials.
I'm working -as we speak- on the setup procedure which is far from perfect.
For now, as you just flashed the unit, I guess you can easily access it via serial.
So then it is the easiest to set the credentials by hand via serial:
Remember you cannot correct a typo via serial, so better copy/paste it from something like notepad.
wifissid MyWiFiSSID
wifikey MySuperSecretPassword
save
It will be much easier if you pick a newer version of ESPEasy to upload, that one is almost 1 year old and many, many, improvements have been made since, especially to the Wi-Fi related stuff.
Get the latest build from https://github.com/letscontrolit/ESPEasy/releases (Expand the 'Assets' link at the end of a block of release notes text to find the actual downloads)
Many thanks for all your information.
I alredy tested the last version from ESPEasy-mega-20210223, but also without success.
I just tested to compile my source version from 04.02.2020 with the help of Arduino. The compiled version is OK.
I also changed to a fixed IP address in the custom.h file.
The first time also did not work.
After a reboot of the device, despite the Fixed IP I had to reconnect on the IP 192.168.4.1.
I reset the device, set again in the WIfi Setup Wizard the SSID and now it's working.
it's hard to understand why now it works!
I spent more than 3 hours looking for solutions.
Otto
Otto
Sad to hear it is taken so long to get it to work, but on the other hand good to know the changes I have been working on the last 2 days is going to be appreciated as I promise you it will be a lot more intuitive in the next nightly build (probably this weekend or Monday)
Still have to test a few more things, but it will be fixed soon.
I thank you for your help. I will follow the changes.
Congratulations again to the development team of this software which is very intuitive.
