rule to control relay
Posted: 01 May 2021, 15:48
by florin.ssk@gmail.com
I have a wemos d1 mini whit espeasy to which a humidity sensor is attached.
I would like that when I register a certain value, (less than X) an ON command to be sent to the relay with the IP 192.x.x.x (esp01 + tasmota).
somebody can help me pls ?
Re: rule to control relay
Posted: 01 May 2021, 16:48
by Ath
Welcome.
First you need to have enabled the Rules feature on the Tools/ Advanced page:
- Screenshot - 01_05_2021 , 16_38_07.png (10.31 KiB) Viewed 7097 times
(Tolerant last parameter is optional, both Rules checkboxes should be on)
After that you can enter a new rule in the Rules tab.
on BME280#Humidity do
if %eventvalue1% <> %v1%
if %eventvalue% < 20 // A bit dry, turn humidifier on
sendtohttp,192.x.x.x,80,/cm?cmnd=Power%20ON // Turn relay on
if %eventvalue1% > 30 // Humid enough, humidifier off
sendtohttp,192.x.x.x,80,/cm?cmnd=Power%20OFF // Turn relay off
let,1,%eventvalue1% // Save last checked value
I've assumed a BME280 sensor in this example, and the 20 and 30 used are just somewhat randomly selected values.
Posted: 01 May 2021, 20:30
humidity information is taken from a soil moisture sensor. I already have the active rule option, because I have another rule. I attach print screen with sensors.
Thanks for the help
Posted: 01 May 2021, 21:16
by Ath
Please attach files or screenshots in this forum, not on external, usually unreliable, image storage. After a while they won't be available anymore, so we can't see what was going on.
And rules can be added in a [ code ] [ /code ] tag (without the spaces, I added these so it will show here)
Posted: 01 May 2021, 21:20
by Ath
Sending data to Domoticz is (much) easier by using a Controller, preferably the Domoticz MQTT controller, but you will need a MQTT server too (Mosquitto is often used in combination with Domoticz). Domoticz HTTP will do fine too.
Posted: 01 May 2021, 22:00
I have msqt too .
i have some sensors in the house.
termostat
some shelly 2.5 the control some blinds.
Outside i want to control 1 electrovalve to open/close the water when the soil is to dry. i have the info, but i do not know to make the next step.
i do not know how to configure the rule
i atached the file whit the img.
Thx
Posted: 02 May 2021, 13:54
by Ath
You can extend the current rule with what I posted before (cleaned it up a bit), that would then be like this:
on Soil#Analog do // Values are passed via %eventvalue1%..%eventvalue4%, and %eventvalue% is an alias for %eventvalue1%
SendToHTTP,192.168.0.115,8080,/json.htm?param=udevice&type=command&idx=26&nvalue=%eventvalue1%
if %eventvalue% < 1 // A bit dry, turn water pump on
SendToHTTP,192.x.x.x,80,/cm?cmnd=Power%20ON // Turn Tasmota relay on
if %eventvalue1% > 3 // Wet enough, water pump off
SendToHTTP,192.x.x.x,80,/cm?cmnd=Power%20OFF // Turn Tasmota relay off
NB: Each Rules set can contain multiple rules, a new rule starts with 'on <event> do', and ends with 'endon'
Posted: 03 May 2021, 19:44
And....
it's Workig !!
THX !!!
Now, i just find the corect value when the relay must be on/off.
thx again !!!!!
Posted: 03 May 2021, 20:02
by Ath
Great! Thanks for reporting back.
Posted: 10 May 2021, 17:33
Hello again,
the rule made by you works very well. in this way thank you once again.
because the water pressure does not allow I would like to make 2 zones (zone 1 and zone 2) each zone controlled by a 1 relay, but not to run simultaneously. Can you help me change my rule so that
SendToHTTP, 192.x.x.ZZZ, 80, / cm? Cmnd = Power% 20ON // Turn Tasmota relay on
to send the same order to another IP 192.x.x. YYY , but with a delay of 30 minutes?
Thank you,
Posted: 10 May 2021, 20:13
by Ath
That should be doable, just to be sure: The seconds relay should be turned on 30 min. after the first is turned on, and also off again 30 minutes after the first is turned off?
TimerSet,1,1800 // Timer in seconds, 30m * 60 sec.
TimerSet,2,1800 // Timer in seconds, 30m * 60 sec.
on rules#timer=1 do
SendToHTTP,192.x.x.yyy,80,/cm?cmnd=Power%20ON // Turn second Tasmota relay on
on rules#timer=2 do
SendToHTTP,192.x.x.yyy,80,/cm?cmnd=Power%20OFF // Turn second Tasmota relay off
Another solution could be to start the second pump after the first one stops, and run it for the same amount of time, if you need that, just ask.
Posted: 11 May 2021, 19:12
THX!
i gone try like this !
Posted: 18 May 2021, 19:03
Thank you for your effort. I eventually used variant number 1. in the meantime I discovered that in "domoticz" I can make rules. I used the rule there, which I find easier.
thanks again for your help.
for the delay I used the delay option.
Posted: 18 May 2021, 19:08
by Ath
Great, a solution is a solution
thanks for reporting back
