how can I transfer multiple sensor values (Temperature1, Temperatur2, Humidity, Pressure) ?
For one sensor value:
MQTT:
Controller Subscribe: %sysname%/#
Controller Publish: %sysname%/Temperature1
Kind Regards
Juergen B.
MQTT: transmit several sensor values
Re: MQTT: transmit several sensor values
I would expect that the MQTT server can only receive 1 value per topic, unless you use the publish command to send a combined message, instead of the more regular way of letting a controller handle it. Via the controller all values of the sensor will be sent to their respective topic one after the other.
The default topic for OpenHAB to publish is like this:
I guess that's what you need?
%sysname%/%tskname%/%valname%
Many thanks for your help.
With the topic publish:
all sensor values are transmitted.
Kind Regards
Juergen B.
Kind Regards
Juergen B.
Users browsing this forum: Google [Bot] and 21 guests
