First build
Posted: 14 May 2021, 19:22
I pretty new with ESPEasy. I already use it with the "normal" build. It was very cool working in association with Jeedom for my domotic setup.
Now I want to try to build my own version. For that I have define the default environment on platformio with my board type
Then I have start the build. At the beginning I got some issue regarding Git, but after some search on the web I found that I have to install Git (it was not install with GitHub Desktop).
But now, I have an other issue, and I'm not able to solve it, even after some search on the web...
It seems that it's coming from Compiletime Define. You can see the log below :
Regarding the output of python script to set the define value, I have this :
Something strange is that my Windows version is 10.0.19042 ... (I have already try to overwrite this value with my Windows version but don't change anything)
So if someone have an idea to help me
default_envs = normal_ESP32_4M316k
In file included from C:/users/pierre-yves/.platformio/packages/framework-arduinoespressif32@3.10004.210126/cores/esp32/Arduino.h:146:0,
from src/src/Helpers/CompiletimeDefines.h:4,
from src/src/Helpers/CompiletimeDefines.cpp:1:
<command-line>:0:31: error: too many decimal points in number
C:/users/pierre-yves/.platformio/packages/framework-arduinoespressif32@3.10004.210126/cores/esp32/WString.h:39:76: note: in definition of macro 'FPSTR'
#define FPSTR(pstr_pointer) (reinterpret_cast<const __FlashStringHelper *>(pstr_pointer))
C:/users/pierre-yves/.platformio/packages/framework-arduinoespressif32@3.10004.210126/cores/esp32/WString.h:40:34: note: in expansion of macro 'PSTR'
#define F(string_literal) (FPSTR(PSTR(string_literal)))
src/src/Helpers/CompiletimeDefines.cpp:54:12: note: in expansion of macro 'F'
return F(SET_BUILD_PLATFORM);
src/src/Helpers/CompiletimeDefines.cpp:54:14: note: in expansion of macro 'SET_BUILD_PLATFORM'
src/src/Helpers/CompiletimeDefines.cpp:62:32: warning: character constant too long for its type
return F(SET_BUILD_GIT_HEAD);
src/src/Helpers/CompiletimeDefines.cpp: In function 'String get_binary_filename()':
<command-line>:0:27: error: 'ESP_Easy_mega_20210514_normal_ESP32_4M316k' was not declared in this scope
src/src/Helpers/CompiletimeDefines.cpp:28:12: note: in expansion of macro 'F'
return F(SET_BUILD_BINARY_FILENAME);
src/src/Helpers/CompiletimeDefines.cpp:28:14: note: in expansion of macro 'SET_BUILD_BINARY_FILENAME'
src/src/Helpers/CompiletimeDefines.cpp: In function 'String get_build_platform()':
<command-line>:0:20: error: 'Windows' was not declared in this scope
<command-line>:0:42: error: 'SP0' was not declared in this scope
*** [.pio\build\normal_ESP32_4M316k\src\src\Helpers\CompiletimeDefines.cpp.o] Error 1
Compile time defines
File System: SPIFFS
PROGNAME: ESP_Easy_mega_20210514_normal_ESP32_4M316k
BUILD_PLATFORM: Windows-10-10.0.19041-SP0
GIT_HEAD: 'mega_7aced75'
