WiFi disconnects in 20210503
Running a few ESP8266 here with ESP_Easy_mega_20210114_normal_ESP8266_4M1M connected stable to WiFi without any issues.
Updated a few to ESP_Easy_mega_20210503_normal_ESP8266_4M1M and suddenly I see them random disconnect/ reconnect to WiFi.
They remain disconnected for a couple of minutes or hours. At some point they connect back to WiFi.
From setup point of view WiFi is setup as Mesh so SSID's (visible) overlap and the one with best connection to be used. With the most
recent WiFi enhancements in ESP_Easy it appears very often wrong decission is made connecting to the wrong AP (single SSID) with suboptimal connection.
"Last Disconnect Reason: (8) Assoc leave"
is seen then.
Tried to tune as much as possible in the WiFi settings in various combinations:
WiFi Settings
WiFi Settings
Force WiFi B/G: false
Restart WiFi Lost Conn: false
Force WiFi No Sleep: false
Periodical send Gratuitous ARP: false
Connection Failure Threshold: 0
Max WiFi TX Power: 17.50
Current WiFi TX Power: 14.00
WiFi Sensitivity Margin: 3
Send With Max TX Power: false
Extra WiFi scan loops: 2
Periodical Scan WiFi: true
Though I can never reach the same stability level as it was in 20210114. I had seen similar issue already in 20210223 but decided to skip this release at that time.
It somehow sounds a bit like "ESP82xx_mega-20210503 WiFi problem" viewtopic.php?f=6&t=8528 and tried linked ESP_Easy_mega_20210505_custom_ESP8266_4M1M
which seem to improve things as reconnects seem to happen more frequently but overall the issue remains.
I can exclude a device failure as it impacts multiple ones. 2 ESPs sitting next to each other: 20210114 (works stable) and 20210503/20210505 (reconnects randomly)
Any hint how to fix this issue? Is there any WiFi setting combination which would match 1:1 the 20210114 build behaviors?
Many thanks!
is seen then.
WiFi Settings
WiFi Settings
Many thanks!
Re: WiFi disconnects in 20210503
Maybe disable periodical wifi scan?
Tried this already in one of the many combinations it did not really had any impact. I can give it a try again though...
Maybe also test with:
Send With Max TX Power: checked
Max TX Power is indeed something with scared me off a bit to play with but testing now with the following set:
Thx
WiFi Settings
Send With Max TX Power: true
Periodical Scan WiFi: false
See here for more detailed info on what the settings do:
https://espeasy.readthedocs.io/en/lates ... -threshold
Periodical send Gratuitous ARP is also one best to have enabled, although it should not make a difference with disconnects/reconnects, only with reachability of the ESP.
Force WiFi B/G will give you some extra range as the TX-power can be higher (max. 20.5, you still need to increase the setting if you wish to use it) and the RX sensitivity is also better.
Max TX power for 802.11n = 14 dBm, 802.11g = 17 dBm, 802.11b = 20.5 dBm.
But we're not using the 'b' mode, so you won't see any difference between 17.5 and 20.5 dBm as setting. (for now..., might change that later)
Thx, the last change
seem to improve things immense testing it a bit further if it remains stable.
Was this the same behavior in 20210114?
On older builds (not sure when I added the TX pwd option) the TX power was always set to max.
This could lead to some issues on some nodes, but as always it is not a fix for every scenario.
N.B. I just merged some temp fix for units not being able to reconnect to WiFi for a long time (or needing a power cycle).
Last night I had one of my own units (connected to serial log) showing the issue of not reconnecting.
So I could see what was wrong then. It appeared the WiFi events were not considered to timeout, so if not all events were processed (e.g. more likely to happen on static IP) it would wait forever (until it crashed....)
So I do have to take a closer look at it, as it is possible to get in the situation where a new connection cannot be started as there are unprocessed wifi events and those events cannot be processed as they are waiting for another event to happen first.
But for now it should (not so elegantly) get out of this infinite loop.
It was running stable for about 15hrs but then startet to disconnect/ reconnect for about 2hrs never got a stable connection. Power cycled it and now its stable again.
No other devices had issues at that time...
testing now with
if this changes anything.
testing now with
Still on the latest 'nightly' build?
Or are you using the latest code base?
Using the custom build linked from viewtopic.php?f=6&t=8528
shall I go back to the last nightly 20210503?
ESP Easy | Information |
Build:⋄|20113 - Mega|
System Libraries:⋄|ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support|
Git Build:⋄|Skrzypowa: May 5 2021 22:15:20|
Plugin Count:⋄|32 |
Build Time:⋄|May 5 2021 22:15:11|
Binary Filename:⋄|ESP_Easy_mega_20210505_custom_ESP8266_4M1M|
Build Platform:⋄|Windows-10-10.0.19041-SP0|
Git HEAD:⋄|'bugfix/std_move_controllerqueue_e519d0b'|
I can also make one for you, based on the current code as that does contain a fix which hopefully fixes this issue.
What build do you need?
That would be awesome, ESP_Easy_mega_20210503_normal_ESP8266_4M1M.bin in a more recent build needed then.
2 builds for you to test:
* normal 'mega' branch: https://www.dropbox.com/s/ipvhx546kxwm4 ... M.bin?dl=0
* normal build where I hopefully fixed some MQTT reconnect issues: https://www.dropbox.com/s/hiaasmlkcgt41 ... M.bin?dl=0 See related issue: https://github.com/letscontrolit/ESPEas ... -843910973
Would be great if you could test the one of the pending pull request first and if that one works, no need to test the other one.
I would like to hear from you which one you test and whether it is a fix for your issues.
N.B. as a tip on making the WiFi connection more stable, in tools->advanced you can enable the "send with max. TX power"
But for testing the wifi reconnect, I guess you should first try to make it disconnect.
Also, do you use static IP or via DHCP?
Alright using the following now:
Settings
Using DHCP address
Git Build:⋄|'bugfix/MQTT_check_connected_956c329'|
Plugin Count:⋄|47 [Normal]|
Build Time:⋄|May 19 2021 11:41:38|
Binary Filename:⋄|ESP_Easy_mega_20210519_normal_ESP8266_4M1M|
Git HEAD:⋄|'bugfix/MQTT_check_connected_956c329'|
WiFi Settings
Max WiFi TX Power: 17.00
Enabling these will make your WiFi connection more stable, but harder to reproduce the WiFi reconnect issue:
- Send With Max TX Power
- Restart WiFi Lost Conn
- Periodical send Gratuitous ARP
After about 90min it lost connection for about 12min and recovered then. Lets see if this happens more often.
Its a test device so no issues debug further is there any way I can collect more information?
Is this with "Restart WiFi Lost Conn" checked?
Periodical WiFi scan disabled?
Is this with "Restart WiFi Lost Conn" checked? -> No
Periodical WiFi scan disabled? -> Yes
After 1st reconnect as described it took about 6h it somehow struggled again with total connetion loss/ reconnect. Not stable for about 30min so I power cycled it.
After recovered I set "Send With Max TX Power" it stayed up for about 23h and struggled then for about 40min until it recovered on its own (still no Restart WiFi on Lost Conn set".
Another ~10h later struggled again for about 10min recovered on its own then.
I also set now "Periodical send Gratuitous ARP"
All other ESPs on 20210114 connected so same infrastructure had no issues at that times.
Interesting though
Last Disconnect Reason: (202) Auth fail
while previously it was
Let see - next try might be switch on the WiFi Scan again?
Periodical send Gratuitous ARP: true
Interesting though
I don't think the periodical wifi scan may be the fix here, as I do believe there is some bug in the check if it may be allowed to perform a WiFi scan.
The auth fail may also be some indication that there is some mixup in which set of credentials it thinks it is using and what may actually be used.
I think the february build may also work just fine, as I do have the feeling I messed up just a few weeks ago.
So far it seems
turns out to be quite stable no issues since about 48hrs which marks a new high
Saw (202) Auth fail though again but seems its that fast not causing too much of an issue.
As mentioned I had skipped the february build can test this later if this turns out to be stable.
I may ask you later to try a newer build as there was for sure a bug in the code when WiFi events happened out of (expected) order.
Seems I jinxed it shortly after my last post "48hrs" it disconnected.
Extended the setup a bit 3 ESPs next to each other
Prod (and most stable until now):
Lab1:
Lab2:
The bug you mentioned kick in randomly or after longer period of time?
WiFi Settings
ESP_Easy_mega_20210223_normal_ESP8266_4M1M /
WiFi Settings
ESP_Easy_mega_20210519_normal_ESP8266_4M1M (bugfix/MQTT_check_connected_956c329)
WiFi Settings
It depends... (as always )
The problem is related to reconnecting to WiFi and the order in which the WiFi events may occur.
So it depends mainly on the stability and reception quality of WiFi.
Understood any new build I shall test let me know.
So far it seems
and
seem to behave quite similar/ stable.
seem to fail random after some time, reconnects most of time though it has a habbit doing this in a Mesh network
by choosing the wrong AP with worse RSSI ending up in packet loss/ further connection issues.
and
using ESP_Easy_mega_20210802 now and it seem to work very well so far.
Good to hear
