Repeat an event x times (like a loop) (for-while)
Posted: 20 May 2021, 19:46
by rira2005
hi
so a add some events (forward,reverse,stop)
i want to repeat the
start forward event for 5 min
then reverse event for 5 min
then forward event for 5 min
maybe 10 times or more...
an when the pseudoloop is done
i want to stop with the event stop
the trigger i want to use to start this repeating events i a do on button....
to understand i want to clean my pool and the poolcleaner goes 5 min forward und 5 min backward... and so on...
May anyone have an idea.
TIA
Rira
Re: Repeat an event x times (like a loop) (for-while)
Posted: 20 May 2021, 21:22
Have you looked at the looptimer?
https://espeasy.readthedocs.io/en/lates ... oop-timers
This can be used to set a loop timer and also set the number of loops.
To switch between "forward" and "reverse", you could set a variable (see the "let" command) and set the looptimer for 5 minutes.
Every loop you just toggle the variable to switch between forward and reverse mode.
Posted: 20 May 2021, 22:59
by rira2005
hi
many thx for your help... but i didnt understand the exact commands
tried this one;
on cleanstart do
looptimerset,3,15,10 // loop 1 forward 15 sec / 10 times repead
looptimerset,4,15,10 // loop 2 reverse 15 sec / 10 times repead
On Rules#Timer=3 do
if %eventvalue2% >= 5 // -> what does the >=5 mean ??!
timerSet,3,0 // Stop timer 3 /why the timer will stoped there
event forward
logentry,%eventvalue2% // log the loop count
On Rules#Timer=4 do
if %eventvalue2% = 2 // -> what does the =2 mean ??!
loopTimerSet,4,15 // Restart loop timer 4 (thus clearing loop count)
timerResume,3 // why this what du this
event reverse
timerPause,3 // why this what du this
on cleanstop do
event stop
timerSet,3,0
timerSet,4,0
but it didnt works it olny starts one time forward und this was it...
Sorry for my poor programing skills but my last time i program something it was in pascal in the 1990s....
to understand
i only want to do a loop with
15 sec the event forward |
then 15 sec the event reverse |
-----> do this 10 times....
tia
Rira
Posted: 21 May 2021, 09:24
rira2005 wrote: ↑20 May 2021, 22:59
hi
tried this one;
on cleanstart do
On Rules#Timer=3 do
event forward
On Rules#Timer=4 do
event reverse
on cleanstop do
event stop
timerSet,3,0
timerSet,4,0
to understand
tia
Rira
I think it can be as simple as this:
on cleanstart do
looptimerset,3,15,20 // every 15 seconds, repeat 20 times (10 times forward, 10 reverse)
On Rules#Timer=3 do
let,1,%eventvalue2% // Store the loop count in a variable
if [int#1]%2=0 // Check if the loop count modulo (%) 2 = 0
asyncevent,forward
asyncevent,reverse
What it does:
It does start a single loop timer for 20 loops (10 forward, 10 reverse) with 15 sec interval.
I store the loop counter in a variable first since I need to use the "%" operator and I was not sure if that would interfere with the % in %eventvalue2%. It may be possible to have it even shorter.
What the modulo (%) operator does is, it is computing what is 'left' if you divide an integer number.
e.g. 9%2 = 1 as you can four times subtract '2' from '9' and then are left with '1'
Thus:
- N%2=0 -> even numbers
- N%2=1 -> odd numbers
So on the 'even loops' you call the event "forward" and on the odd loops you call the even "reverse".
I changed "event" to "asyncevent" to add the event to an event queue so the ESP will not be too long in processing the rules.
Posted: 04 Jun 2021, 11:24
by rira2005
hi i done it lite this, many thanks to all!
on cleanstart do
Publish domoticz/in,'{"idx":158,"nvalue":1,"svalue":""}' //mqtt info to start the event
asyncevent,reverse //start yet not to wait 30 seconds
let,2,1 //forward and reverse var to for the if set to 1 --> forward
looptimerset,3,30,200 // every 30 seconds, repeat 200 times (100 times forward, 100 reverse)
On Rules#Timer=3 do
if %eventvalue2% >= 200 //check the loop count is more the 200 if
asyncevent,cleanstop //call the event cleanstop
elseif [int#2]=1 // if direction var is 1(reverse) do the event forward
asyncevent,forward //call the forward event
let,2,0 //forward and reverse var to for the if set to 0 --> reverse
else // else direction var is 0(forward) do the event reverse
asyncevent,reverse //call the reverse event //call the forward event
let,2,1 //forward and reverse var to for the if set to 0 --> reverse
on cleanstop do
Publish domoticz/in,'{"idx":158,"nvalue":0,"svalue":""}' //mqtt info to stop the event
event,stop //call the stop event
looptimerset,3,0 //stop the timer before the loops ends (to stop it with buttoon or http req. via domoticz)
on forward do
if [R2#state]=0
gpio,13,1
gpio,12,1
TimerSet_ms,1,1000
gpio,13,0
GPIO,14,1
let,1,1
on stop do
gpio,12,1
gpio,13,1
GPIO,14,0
let,1,0
on reverse do
if [R1#state]=0
gpio,13,1
gpio,12,1
TimerSet_ms,2,1000
gpio,12,0
GPIO,14,1
let,1,1
on rules#timer=1 do
gpio,13,0
GPIO,14,1
let,1,1
on rules#timer=2 do
gpio,12,0
GPIO,14,1
let,1,1
Posted: 05 Jun 2021, 13:30
by Ath
TD-er wrote: ↑21 May 2021, 09:24
The expression processing actually handles that correctly, so this code:
if %eventvalue2%%2=0 // Check if the loop count modulo (%) 2 = 0
works as expected.
