Page 2 of 3
Re: Latest versions crashes my NodeMCU
Posted: 10 Jun 2021, 23:31
Tebogo wrote: ↑10 Jun 2021, 23:22
[WiFi] Only perform network activity when connected
[WiFiClient] Make sure all clients use at least some timeout
Are those two related?
[/quote]
No.... but...
The first one is about "if not connected, don't even bother trying to connect to another host sending data"
The second one is about "Hmm I sent out a request, how long should I wait for a reply?"
Before the timeout was explicitly set, it was a default timeout which was longer than the Software Watchdog timer. Not really hard to imagine what may happen if the connected host was not replying
So that would suggest they are not related... however it is indeed something that might be related somehow so I no longer dare to be very explicit in my opinion they are not related...
Posted: 10 Jun 2021, 23:36
by Tebogo
Nope, same results:
RESET: formatting done…
14838 : Info : SaveToFile: free stack: 3504
14902 : Info : FILE : Saved config.dat offset: 28672 size: 820
14903 : Info : SaveToFile: free stack after: 3504
14904 : Info : SaveToFile: free stack: 3568
14983 : Info : FILE : Saved config.dat offset: 0 size: 1296
14984 : Info : SaveToFile: free stack after: 3568
14985 : Info : SaveToFile: free stack: 3408
15021 : Info : FILE : Saved security.dat offset: 0 size: 593
15022 : Info : SaveToFile: free stack after: 3408
15024 : Info : SaveToFile: free stack: 3072
15034 : Info : FILE : Saved security.dat offset: 1024 size: 128
15035 : Info : SaveToFile: free stack after: 3072
RESET: Successful, rebooting. (you might need to press the reset button if you’ve just flashed the firmware)
16240 : Info : Time set to 3339471953.000
16242 : Info : Current Time Zone: STD time start: 2075-10-27 03:00:00 offset: 0 min
16245 : Info : Local time: 2075-10-28 07:05:5ÿ
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3584, room 16
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
ªU76 : Info :
INIT : Booting version: ‘bugfix/connected_check_timeout_f93e035’ (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
77 : Info : INIT : Free RAM:32152
79 : Info : INIT : Soft Reboot #2 Last Action before Reboot: Intended Reboot: ResetFactory Last systime: 3339471953 - Restart Reason: Software/System restart
81 : Info : FS : Mounting…
105 : Info : FS : Mount successful, used 71284 bytes of 957314
126 : Info : CRC : SecuritySettings CRC …OK
130 : Info : WiFi : Start network scan all channels
2319 : Info : WiFi : Scan finished, found: 6
2321 : Info : WiFi : Start network scan all channels
2430 : Info : INIT : Free RAM:27688
2431 : Info : INIT : I2C
2432 : Info : INIT : SPI not enabled
2452 : Info : INFO : Plugins: 13 (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
2455 : Info : Webserver: start
2456 : Info : Time set to 3339471953.000
2458 : Info : Current Time Zone: STD time start: 2075-10-27 03:00:00 offset: 0 min
2462 : Info : Local time: 2075-10-28 07:05:53
3797 : Info : WD : Uptime 0 ConnectFailures 0 FreeMem 21680 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
4524 : Info : WiFi : Scan finished, found: 4
4527 : Error : WIFI : No valid wifi settings
4527 : Info : WIFI : Set WiFi to AP+STA
5518 : Info : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
33805 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 19352 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
39544 : Info : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
63811 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 16880 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
75124 : Info : SaveToFile: free stack: 3456
75204 : Info : FILE : Saved config.dat offset: 0 size: 1296
75205 : Info : SaveToFile: free stack after: 3456
75206 : Info : SaveToFile: free stack: 3296
75242 : Info : FILE : Saved security.dat offset: 0 size: 593
75243 : Info : SaveToFile: free stack after: 3296
75245 : Info : SaveToFile: free stack: 2960
75255 : Info : FILE : Saved security.dat offset: 1024 size: 128
75256 : Info : SaveToFile: free stack after: 2960
75258 : Info : WIFI : Credentials Changed, retry connection. SSID: Linksys Velop WHW03 V2
75261 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:9 (-69dBm) WPA2/PSK
75262 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:9 (-69dBm) WPA2/PSK attempt #0
75268 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
77780 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 9 Duration: 1647 ms
77781 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
78856 : Info : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1944 ms
78860 : Info : SaveToFile: free stack: 3216
78871 : Info : FILE : Saved security.dat offset: 1024 size: 128
78871 : Info : SaveToFile: free stack after: 3216
78873 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
78972 : Info : firstLoopConnectionsEstablished
87220 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
87221 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
89414 : Info : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 12 s
89415 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
90086 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 9 Duration: 14821 ms
90087 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
93797 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 16000 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
93798 : Info : WiFi : Start network scan all channels
93904 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3717 ms
94007 : Info : WIFI : Set WiFi to OFF
94232 : Info : AP Mode: Client disconnected: 3C:22:FB:0F:A1:70 Connected devices: 0
94243 : Error : WiFi : Scan not allowed, unprocessed WiFi events: disconn
94244 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
98809 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:9 (-69dBm) WPA2/PSK
98811 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (RTC) WPA2/PSK attempt #1
98915 : Info : WIFI : Set WiFi to STA
99125 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
100439 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 1619 ms
100440 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
102243 : Info : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1806 ms
102245 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
110953 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
110953 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
111861 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-71dBm) WPA2/PSK attempt #2
111868 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
112943 : Info : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 962 ms
113045 : Info : WIFI : Set WiFi to OFF
113278 : Error : WiFi : Scan not allowed, unprocessed WiFi events: disconn
113279 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
113949 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:2 (-76dBm) WPA2/PSK attempt #3
114053 : Info : WIFI : Set WiFi to STA
114262 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
114583 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 2 Duration: 616 ms
114584 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
114641 : Info : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 65 ms
114643 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
123449 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8678 ms
123450 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
123635 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 2 Duration: 9677 ms
123635 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
123797 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 19784 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
123798 : Info : WiFi : Start network scan all channels
123903 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 174 ms
124005 : Info : WIFI : Set WiFi to OFF
124239 : Error : WiFi : Scan not allowed, unprocessed WiFi events: disconn
124240 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
128903 : Info : WIFI : Set WiFi to STA
129107 : Info : WiFi : Start network scan all channels
129111 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
131313 : Info : WiFi : Scan finished, found: 4
131315 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:9 (-69dBm) WPA2/PSK
131318 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-70dBm) WPA2/PSK attempt #4
131323 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
131497 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 160 ms
131498 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
133381 : Info : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1893 ms
133383 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
142084 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
142085 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
142199 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 10771 ms
142200 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
142201 : Info : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 53 ms
142203 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
150708 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8515 ms
150709 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
150735 : Info : Reset WiFi.
150737 : Info : WiFi : WiFiConnected() out of sync: DISCONNECTED RSSI: -75 status: STATION_CONNECTING
150950 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2 m 30 s
150951 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
151735 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-75dBm) WPA2/PSK attempt #5
151836 : Info : WIFI : Set WiFi to STA
152043 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
153179 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 1428 ms
153180 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
153225 : Info : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 52 ms
153227 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
153798 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 19616 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
153799 : Error : WiFi : Scan not needed, good candidate present
161927 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8660 ms
161928 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
162498 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 10754 ms
162499 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
162827 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:2 (-79dBm) WPA2/PSK attempt #6
162832 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
164975 : Info : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 2041 ms
165077 : Info : WIFI : Set WiFi to OFF
165311 : Error : WiFi : Scan not allowed, unprocessed WiFi events: disconn
165312 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
166084 : Info : WIFI : Set WiFi to STA
166287 : Info : WiFi : Start network scan all channels
166290 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
168489 : Info : WiFi : Scan finished, found: 5
168492 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-70dBm) WPA2/PSK
168495 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:9 (-71dBm) WPA2/PSK attempt #7
168501 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
170337 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 9 Duration: 1828 ms
170338 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
170396 : Info : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 66 ms
170398 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
179101 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8675 ms
179102 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
179497 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 9 Duration: 10993 ms
179498 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
180001 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-75dBm) WPA2/PSK attempt #8
180006 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
181208 : Info : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1093 ms
181311 : Info : WIFI : Set WiFi to OFF
181544 : Error : WiFi : Scan not allowed, unprocessed WiFi events: disconn
181545 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
182215 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:2 (-78dBm) WPA2/PSK attempt #9
182318 : Info : WIFI : Set WiFi to STA
182526 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
183703 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 2 Duration: 1472 ms
183704 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
183803 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 20584 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
189635 : Info : WIFI : DHCP IP: 10.187.1.122 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 5938 ms
189637 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
Back to ESPEasy_mega-20190226, and problems solved...
Posted: 12 Jun 2021, 13:27
by Tebogo
TD-er wrote: ↑10 Jun 2021, 23:31
I still can't update to a higher version than ESPEasy_mega-20190226.
What else do you suggest to find the problem?
Still like to find out, en help to solve this bug.
Posted: 12 Jun 2021, 13:57
As we speak I am looking into this issue.
I'm only working on WiFi this weekend to get this sorted out once and for all.
However I do find it very strange that your setup is apparently not working at all with builds of the past two years while lots and lots of other users have reported success.
But there is currently still another issue regarding the WiFi state which is bugging lots of other users too, so therefore I will try to disect those mentioned builds to see if I can come up with a more elegant fix here.
Posted: 12 Jun 2021, 15:32
by Tebogo
Great, looking forward to test !
TD-er wrote: ↑12 Jun 2021, 13:57
If you think a version should work of should give you more info, just tell me which one, I'm willing to test again.
Posted: 12 Jun 2021, 16:33
Yep as soon as I have something to test, I will let you know.
It will also be appended to
this PR, so if you have a GitHub account, you can subscribe to it.
Posted: 12 Jun 2021, 19:02
Can you try this build?
https://www.dropbox.com/s/c6rdpo58spjna ... M.bin?dl=0
Still not changed a lot, but I found some strange logic when an event is missed (or thought to be missed).
Posted: 12 Jun 2021, 19:57
by Tebogo
Sorry, but same behaviour,
273 : Info :
INIT : Booting version: ‘bugfix/wifi_not_reconnect_56c4ca1’ (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
274 : Info : INIT : Free RAM:32040
276 : Info : INIT : Cold Boot - Restart Reason: External System
277 : Info : FS : Mounting…
4176 : Info : FS : Mount successful, used 0 bytes of 957314
RESET: Resetting factory defaults… using default settings
RESET: Warm boot, reset count: 0
RESET: formatting…
14843 : Info : SaveToFile: free stack: 3504
14907 : Info : FILE : Saved config.dat offset: 28672 size: 820
14908 : Info : SaveToFile: free stack after: 3504
14909 : Info : SaveToFile: free stack: 3568
14986 : Info : FILE : Saved config.dat offset: 0 size: 1296
14987 : Info : SaveToFile: free stack after: 3568
14988 : Info : SaveToFile: free stack: 3408
15023 : Info : FILE : Saved security.dat offset: 0 size: 593
15024 : Info : SaveToFile: free stack after: 3408
15027 : Info : SaveToFile: free stack: 3072
15037 : Info : FILE : Saved security.dat offset: 1024 size: 128
15038 : Info : SaveToFile: free stack after: 3072
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
ªU75 : Info :
76 : Info : INIT : Free RAM:32040
78 : Info : INIT : Soft Reboot #1 Last Action before Reboot: Intended Reboot: ResetFactory Last systime: 16 - Restart Reason: Software/System restart
80 : Info : FS : Mounting…
104 : Info : FS : Mount successful, used 75802 bytes of 957314
125 : Info : CRC : SecuritySettings CRC …OK
129 : Info : WiFi : Start network scan all channels
2318 : Info : WiFi : Scan finished, found: 9
2320 : Info : WiFi : Start network scan all channels
2429 : Info : INIT : Free RAM:27320
2431 : Info : INIT : SPI not enabled
2540 : Info : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
2546 : Info : Webserver: start
2547 : Info : Time set to 16.000 Time adjusted by 13453.00 msec. Wander: 3.74 msec/second
2549 : Info : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
2551 : Info : Local time: 1970-01-01 00:00:16
3891 : Info : WD : Uptime 0 ConnectFailures 0 FreeMem 19752 WiFiStatus WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
4596 : Info : WiFi : Scan finished, found: 10
4600 : Error : WIFI : No valid wifi settings
4601 : Info : WIFI : Set WiFi to AP+STA
5591 : Info : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
15854 : Info : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
33896 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 15088 WiFiStatus WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
47842 : Info : SaveToFile: free stack: 3456
47922 : Info : FILE : Saved config.dat offset: 0 size: 1296
47923 : Info : SaveToFile: free stack after: 3456
47924 : Info : SaveToFile: free stack: 3296
47959 : Info : FILE : Saved security.dat offset: 0 size: 593
47960 : Info : SaveToFile: free stack after: 3296
47962 : Info : SaveToFile: free stack: 2960
47973 : Info : FILE : Saved security.dat offset: 1024 size: 128
47974 : Info : SaveToFile: free stack after: 2960
47975 : Info : WIFI : Credentials Changed, retry connection. SSID: Linksys Velop WHW03 V2
47978 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-63dBm) WPA2/PSK
47980 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-63dBm) WPA2/PSK attempt #0
47985 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
50284 : Info : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 2200 ms
50386 : Info : WIFI : Set WiFi to OFF
50603 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
50605 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:8 (-69dBm) WPA2/PSK attempt #1
50709 : Info : WIFI : Set WiFi to STA
50816 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
53649 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 8 Duration: 3041 ms
53650 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
61979 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8230 ms
61980 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
62824 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 8 Duration: 12216 ms
62825 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
62879 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:2 (-70dBm) WPA2/PSK attempt #2
62884 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
63926 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 17248 WiFiStatus WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
65962 : Info : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 2968 ms
66880 : Info : WIFI : Set WiFi to OFF
67114 : Error : WiFi : Scan not allowed, unprocessed WiFi events: disconn
67115 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
67889 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:5 (-72dBm) WPA2/PSK attempt #3
67993 : Info : WIFI : Set WiFi to STA
68101 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
68101 : Info : WIFI : Set WiFi to AP+STA
68208 : Info : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
70404 : Info : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 2403 ms
70506 : Info : WIFI : Set WiFi to OFF
70721 : Info : WiFi : Start network scan all channels
72910 : Info : WiFi : Scan finished, found: 11
72914 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-67dBm) WPA2/PSK
72915 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
72916 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-67dBm) WPA2/PSK attempt #4
72922 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
73931 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1006 ms
73932 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
75973 : Info : WIFI : DHCP IP: 10.187.1.230 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 2044 ms
75976 : Info : SaveToFile: free stack: 3216
75987 : Info : FILE : Saved security.dat offset: 1024 size: 128
75988 : Info : SaveToFile: free stack after: 3216
75990 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
76085 : Info : firstLoopConnectionsEstablished
84690 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
84691 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
84705 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 11779 ms
84706 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
85590 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-67dBm) WPA2/PSK
85591 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-67dBm) WPA2/PSK attempt #5
85596 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
86462 : Info : WIFI : DHCP IP: 10.187.1.230 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0
86463 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: IP
93886 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 17448 WiFiStatus WL_CONNECTED3 ESPeasy internal wifi status: IP Init
93888 : Error : WiFi : Scan not needed, good candidate present
94890 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 9197 ms
94891 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
96661 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:8 (-72dBm) WPA2/PSK attempt #6
96667 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
97741 : Info : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 960 ms
97843 : Info : WIFI : Set WiFi to OFF
98058 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
98059 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-72dBm) WPA2/PSK attempt #7
98163 : Info : WIFI : Set WiFi to STA
98369 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
98382 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:2 (-73dBm) WPA2/PSK attempt #8
98388 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
100377 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 2 Duration: 1990 ms
100378 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
100437 : Info : WIFI : DHCP IP: 10.187.1.230 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 62 ms
100439 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
109040 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8565 ms
109041 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
109941 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:5 (-73dBm) WPA2/PSK attempt #9
109946 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
112088 : Info : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 2042 ms
113018 : Info : WIFI : Set WiFi to OFF
113252 : Error : WiFi : Scan not allowed, unprocessed WiFi events: disconn
113253 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
114131 : Info : WIFI : Set WiFi to STA
114337 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
114351 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-67dBm) WPA2/PSK
114352 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-67dBm) WPA2/PSK attempt #10
114358 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
115357 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 991 ms
115358 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
115398 : Info : WIFI : DHCP IP: 10.187.1.230 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 51 ms
115399 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
123886 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 17448 WiFiStatus WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP Init
123888 : Error : WiFi : Scan not needed, good candidate present
124111 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8654 ms
124112 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
124204 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 9842 ms
124205 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
125000 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:8 (-72dBm) WPA2/PSK attempt #11
125005 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
126587 : Info : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1476 ms
126689 : Info : WIFI : Set WiFi to OFF
126923 : Error : WiFi : Scan not allowed, unprocessed WiFi events: disconn
126924 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
127699 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-72dBm) WPA2/PSK attempt #12
127803 : Info : WIFI : Set WiFi to STA
128016 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
128031 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:2 (-73dBm) WPA2/PSK attempt #13
128036 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
129203 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 2 Duration: 1170 ms
129205 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
129361 : Info : WIFI : DHCP IP: 10.187.1.230 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 150 ms
129363 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
137709 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8405 ms
137710 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
137986 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 2 Duration: 9950 ms
137987 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
138609 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:5 (-73dBm) WPA2/PSK attempt #14
138615 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
140664 : Info : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1950 ms
141594 : Info : WIFI : Set WiFi to OFF
141828 : Error : WiFi : Scan not allowed, unprocessed WiFi events: disconn
141829 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
142705 : Info : WIFI : Set WiFi to STA
142909 : Info : WiFi : Start network scan all channels
142913 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
145104 : Info : WiFi : Scan finished, found: 4
145107 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-67dBm) WPA2/PSK
145110 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-67dBm) WPA2/PSK attempt #15
145116 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
146124 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1009 ms
146125 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
148153 : Info : WIFI : DHCP IP: 10.187.1.230 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 2023 ms
148155 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
Back to mega-20190226, for your info, maybe help for you, the serial log info from mega-20190226
INIT : Booting version: mega-20190226 (ESP82xx Core 2_4_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support)
299 : RTC : Checksum error on reading RTC user var
300 : INIT : Warm boot #2 - Restart Reason: External System
302 : FS : Mounting…
4285 : FS : Mount successful, used 0 bytes of 957314
RESET: Warm boot, reset count: 1
RESET: formatting…
RESET: Succesful, rebooting. (you might need to press the reset button if you’ve justed flashed the firmware)
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
öªU69 :
71 : RTC : Checksum error on reading RTC user var
71 : INIT : Warm boot #3 - Restart Reason: Software/System restart
74 : FS : Mounting…
98 : FS : Mount successful, used 75802 bytes of 957314
450 : CRC : program checksum …OK
461 : CRC : SecuritySettings CRC …OK
463 : CRC : binary has changed since last save of Settings
571 : INIT : Free RAM:26472
573 : INIT : I2C
574 : INIT : SPI not enabled
587 : INFO : Plugins: 46 [Normal] (ESP82xx Core 2_4_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support)
590 : WIFI : No valid wifi settings
591 : WIFI : Could not connect to AP!
593 : WIFI : Set WiFi to AP
1514 : WIFI : AP Mode ssid will be ESP_Easy_0 with address 192.168.4.1
2849 : WD : Uptime 0 ConnectFailures 0 FreeMem 23072 WiFiStatus 0
restart
>restart
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
öªU69 :
72 : INIT : Warm boot #4 - Restart Reason: Software/System restart
74 : FS : Mounting…
99 : FS : Mount successful, used 75802 bytes of 957314
451 : CRC : program checksum …OK
488 : CRC : SecuritySettings CRC …OK
597 : INIT : Free RAM:26520
598 : INIT : I2C
599 : INIT : SPI not enabled
612 : INFO : Plugins: 46 [Normal] (ESP82xx Core 2_4_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support)
615 : WIFI : Set WiFi to STA
648 : WIFI : Connecting Linksys Velop WHW03 V2 attempt #0
650 : WIFI : Not configured in Station Mode!!: Linksys Velop WHW03 V2
1985 : WD : Uptime 0 ConnectFailures 0 FreeMem 24576 WiFiStatus 0
Posted: 12 Jun 2021, 20:24
by Ath
You still have the 'Formatting...' messages in your log, and AFAICS, that's not intentional. How big is the chance that your hardware is just kind of broken? (despite ancient versions that seem to work fine...)
Posted: 12 Jun 2021, 20:27
by Tebogo
Ath wrote: ↑12 Jun 2021, 20:24
I do have some more ESP's, I'll grab another one, but already 2 have exactly the same results....
Used a brand new one, never used before, was still in package
But same result again...
(Edit: Didn't copy the right info..)
From PyFlasher console:
Command: esptool.py --port /dev/cu.usbserial-14240 --baud 115200 --after no_reset write_flash --flash_size detect --flash_mode dio 0x00000 /Users/GulikP/Downloads/_PR3676_ESP_Easy_mega_20210612_normal_ESP8266_4M1M.bin --erase-all
esptool.py v3.0
Serial port /dev/cu.usbserial-14240
Connecting....
Detecting chip type... ESP8266
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: f4:cf:a2:ed:b5:76
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Erasing flash (this may take a while)...
Chip erase completed successfully in 8.8s
Flash params set to 0x0240
Compressed 920032 bytes to 605811...
Wrote 920032 bytes (605811 compressed) at 0x00000000 in 58.7 seconds (effective 125.4 kbit/s)...
Hash of data verified.
Leaving...
Staying in bootloader.
Firmware successfully flashed. Unplug/replug or reset device
to switch back to normal boot mode.
From serial terminal after reset device:
291 : Info : INIT : Free RAM:32040
292 : Info : INIT : Manual Reboot #1 Last Action before Reboot: Background Task Last systime: 7 - Restart Reason: External System
294 : Info : FS : Mounting…
7314 : Info : FS : Mount successful, used 0 bytes of 957314
RESET: formatting…
17280 : Info : SaveToFile: free stack: 3504
17339 : Info : FILE : Saved config.dat offset: 28672 size: 820
17339 : Info : SaveToFile: free stack after: 3504
17340 : Info : SaveToFile: free stack: 3568
17410 : Info : FILE : Saved config.dat offset: 0 size: 1296
17411 : Info : SaveToFile: free stack after: 3568
17412 : Info : SaveToFile: free stack: 3408
17445 : Info : FILE : Saved security.dat offset: 0 size: 593
17446 : Info : SaveToFile: free stack after: 3408
17448 : Info : SaveToFile: free stack: 3072
17458 : Info : FILE : Saved security.dat offset: 1024 size: 128
17459 : Info : SaveToFile: free stack after: 3072
18574 : Info : Time set to 7.000 Time adjusted by -11573.00 msec. Wander: -3.21 msec/second
18575 : Info : Current Time Zone: STD time start: 1970-10-25 03:00:00 ofþ
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
ªU77 : Info :
78 : Info : INIT : Free RAM:32040
79 : Info : INIT : Soft Reboot #2 Last Action before Reboot: Intended Reboot: ResetFactory Last systime: 7 - Restart Reason: Software/System restart
106 : Info : FS : Mount successful, used 75802 bytes of 957314
2320 : Info : WiFi : Scan finished, found: 12
2323 : Info : WiFi : Start network scan all channels
2432 : Info : INIT : Free RAM:27064
2434 : Info : INIT : I2C
2434 : Info : INIT : SPI not enabled
2544 : Info : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
2550 : Info : Webserver: start
2551 : Info : Time set to 7.000 Time adjusted by 4450.00 msec. Wander: 1.24 msec/second
2553 : Info : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
2555 : Info : Local time: 1970-01-01 00:00:07
3897 : Info : WD : Uptime 0 ConnectFailures 0 FreeMem 19760 WiFiStatus WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
4601 : Info : WiFi : Scan finished, found: 7
4605 : Error : WIFI : No valid wifi settings
4605 : Info : WIFI : Set WiFi to AP+STA
5595 : Info : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
21676 : Info : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
33900 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 15112 WiFiStatus WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
52335 : Info : SaveToFile: free stack: 3456
52411 : Info : FILE : Saved config.dat offset: 0 size: 1296
52412 : Info : SaveToFile: free stack after: 3456
52413 : Info : SaveToFile: free stack: 3296
52446 : Info : FILE : Saved security.dat offset: 0 size: 593
52447 : Info : SaveToFile: free stack after: 3296
52449 : Info : SaveToFile: free stack: 2960
52459 : Info : FILE : Saved security.dat offset: 1024 size: 128
52460 : Info : SaveToFile: free stack after: 2960
52462 : Info : WIFI : Credentials Changed, retry connection. SSID: Linksys Velop WHW03 V2
52465 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-71dBm) WPA2/PSK
52466 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-71dBm) WPA2/PSK attempt #0
52472 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
53577 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1091 ms
53578 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
55140 : Info : WIFI : DHCP IP: 10.187.1.24 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1579 ms
55143 : Info : SaveToFile: free stack: 3216
55153 : Info : FILE : Saved security.dat offset: 1024 size: 128
55153 : Info : SaveToFile: free stack after: 3216
55156 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
55216 : Info : firstLoopConnectionsEstablished
63821 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
63822 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
63890 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 11415 ms
63891 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
63893 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 13704 WiFiStatus WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
63894 : Info : WiFi : Start network scan all channels
63998 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 14 ms
64100 : Info : WIFI : Set WiFi to OFF
64317 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
64320 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-71dBm) WPA2/PSK
64321 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-71dBm) WPA2/PSK attempt #1
64425 : Info : WIFI : Set WiFi to STA
64589 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
64602 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:8 (-73dBm) WPA2/PSK attempt #2
64606 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
65919 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 8 Duration: 1296 ms
65920 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
67720 : Info : WIFI : DHCP IP: 10.187.1.24 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1815 ms
67722 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
76389 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
76390 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
76787 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 8 Duration: 12176 ms
76788 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
77288 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:5 (-76dBm) WPA2/PSK attempt #3
77293 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
79343 : Info : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1950 ms
79445 : Info : WIFI : Set WiFi to OFF
79660 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
79662 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:2 (-79dBm) WPA2/PSK attempt #4
79766 : Info : WIFI : Set WiFi to STA
79930 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
79943 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-83dBm) WPA2/PSK attempt #5
79948 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
81104 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 1145 ms
81105 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
82938 : Info : WIFI : DHCP IP: 10.187.1.24 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1845 ms
82940 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
91643 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
91644 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
92553 : Info : WiFi : Start network scan all channels
92557 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
92670 : Info : WIFI : Disconnected! Reason: ‘(203) Assoc fail’ Connected for 11 s
92671 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
93897 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 17784 WiFiStatus WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
93898 : Info : WiFi : Start network scan all channels
94756 : Info : WiFi : Scan finished, found: 7
94759 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-71dBm) WPA2/PSK
94762 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-71dBm) WPA2/PSK attempt #6
94769 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
95755 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 990 ms
95756 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
97765 : Info : WIFI : DHCP IP: 10.187.1.24 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 2003 ms
97767 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
106314 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
106315 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
107161 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 12392 ms
107162 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
107214 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:5 (-78dBm) WPA2/PSK attempt #7
107219 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
109268 : Info : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1948 ms
110197 : Info : WIFI : Set WiFi to OFF
110432 : Error : WiFi : Scan not allowed, unprocessed WiFi events: disconn
110433 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
111207 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:8 (-78dBm) WPA2/PSK attempt #8
111311 : Info : WIFI : Set WiFi to STA
111485 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
111500 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:2 (-79dBm) WPA2/PSK attempt #9
111505 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
112673 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 2 Duration: 1153 ms
112674 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
112742 : Info : WIFI : DHCP IP: 10.187.1.24 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 86 ms
112744 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
121410 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8655 ms
121411 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
121708 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 2 Duration: 10201 ms
121709 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
122310 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-84dBm) WPA2/PSK attempt #10
122316 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
123903 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 17952 WiFiStatus WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
124366 : Info : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1951 ms
124468 : Info : WIFI : Set WiFi to OFF
124683 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
124686 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-71dBm) WPA2/PSK
124687 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-71dBm) WPA2/PSK attempt #11
124791 : Info : WIFI : Set WiFi to STA
124955 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
124968 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:5 (-78dBm) WPA2/PSK attempt #12
124973 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
126172 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 5 Duration: 1183 ms
126173 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
126231 : Info : WIFI : DHCP IP: 10.187.1.24 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 70 ms
126233 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
Posted: 12 Jun 2021, 21:19
by Tebogo
Is it cause by a setting in the flash command?
I think because of "--erase-all"
When I
it doesn't format, but keep all the settings.
80 : Info : INIT : Free RAM:32040
82 : Info : INIT : Manual Reboot #6 Last Action before Reboot: Background Task Last systime: 488 - Restart Reason: External System
83 : Info : FS : Mounting…
108 : Info : FS : Mount successful, used 75802 bytes of 957314
129 : Info : CRC : SecuritySettings CRC …OK
130 : Info : CRC : binary has changed since last save of Settings
133 : Info : WiFi : Start network scan all channels
Build changed!
250 : Info : SaveToFile: free stack: 3712
323 : Info : FILE : Saved config.dat offset: 0 size: 1296
324 : Info : SaveToFile: free stack after: 3712
325 : Info : SaveToFile: free stack: 3552
360 : Info : FILE : Saved security.dat offset: 0 size: 593
361 : Info : SaveToFile: free stack after: 3552
364 : Info : SaveToFile: free stack: 3216
374 : Info : FILE : Saved security.dat offset: 1024 size: 128
375 : Info : SaveToFile: free stack after: 3216
377 : Info : INIT : Free RAM:27944
378 : Info : INIT : I2C
379 : Info : INIT : SPI not enabled
489 : Info : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
495 : Info : Webserver: start
496 : Info : Time set to 488.000 Time adjusted by 487504.00 msec. Wander: 135.42 msec/second
498 : Info : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
500 : Info : Local time: 1970-01-01 00:08:08
1845 : Info : WD : Uptime 0 ConnectFailures 0 FreeMem 21000 WiFiStatus WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
2453 : Info : WiFi : Scan finished, found: 3
2457 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
2458 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #0
2464 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
4489 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 2014 ms
4491 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
6467 : Info : WIFI : DHCP IP: 10.187.1.24 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1985 ms
6469 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
6526 : Info : firstLoopConnectionsEstablished
14937 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
14938 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
15786 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 13319 ms
15787 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
15838 : Info : WiFi : Start network scan all channels
15840 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS0 ESPeasy internal wifi status: Conn.
15942 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 61 ms
16044 : Info : WIFI : Set WiFi to OFF
16260 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
16261 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
16262 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #1
16366 : Info : WIFI : Set WiFi to STA
16545 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
16558 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
16560 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #2
16564 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
17551 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 989 ms
17552 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
19579 : Info : WIFI : DHCP IP: 10.187.1.24 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 2026 ms
19581 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
28278 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
28279 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
28303 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 11724 ms
28304 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
29178 : Info : WiFi : Start network scan all channels
29181 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS0 ESPeasy internal wifi status: Conn.
29283 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 896 ms
29385 : Info : WIFI : Set WiFi to OFF
29600 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
29602 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
29603 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #3
29707 : Info : WIFI : Set WiFi to STA
29870 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
29883 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
29884 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #4
29888 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
31721 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1823 ms
31722 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
31844 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 19776 WiFiStatus WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
33701 : Info : WIFI : DHCP IP: 10.187.1.24 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1984 ms
33702 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
42282 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
42283 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
43128 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 13235 ms
43129 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
43181 : Info : WiFi : Start network scan all channels
43184 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS0 ESPeasy internal wifi status: Conn.
43286 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 63 ms
43388 : Info : WIFI : Set WiFi to OFF
43603 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
43605 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
43606 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #5
43710 : Info : WIFI : Set WiFi to STA
43873 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
43886 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
43887 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #6
43892 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
44877 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 987 ms
44878 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
46873 : Info : WIFI : DHCP IP: 10.187.1.24 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1991 ms
46875 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
55539 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
55540 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
55541 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 11649 ms
55542 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
56438 : Info : WiFi : Start network scan all channels
56441 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS0 ESPeasy internal wifi status: Conn.
56543 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 903 ms
56645 : Info : WIFI : Set WiFi to OFF
56861 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
56863 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
56864 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #7
56968 : Info : WIFI : Set WiFi to STA
57131 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
57144 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
57145 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #8
57150 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
58136 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 988 ms
58137 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
58185 : Info : WIFI : DHCP IP: 10.187.1.24 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 42 ms
58187 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
61836 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 19776 WiFiStatus WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP Init
66753 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8518 ms
66754 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
67601 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 10447 ms
67602 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
67653 : Info : WiFi : Start network scan all channels
67656 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS0 ESPeasy internal wifi status: Conn.
67758 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 61 ms
67860 : Info : WIFI : Set WiFi to OFF
68075 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
68077 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
68078 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #9
68182 : Info : WIFI : Set WiFi to STA
68360 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
68374 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK
68375 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-74dBm) WPA2/PSK attempt #10
68379 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
69387 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 992 ms
69388 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
69413 : Info : WIFI : DHCP IP: 10.187.1.24 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 40 ms
69414 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
Re: Latest versions crashes my NodeMCU
Posted: 12 Jun 2021, 21:30
The --erase-all does indeed what it states
Posted: 12 Jun 2021, 21:37
by Tebogo
TD-er wrote: ↑12 Jun 2021, 21:30
Oke,
solved the formatting question.
For the record, also this brand new ESP works as supposed on mega-20190226
75 : RTC : Checksum error on reading RTC user var
75 : INIT : Warm boot #1 - Restart Reason: External System
78 : FS : Mounting…
102 : FS : Mount successful, used 75802 bytes of 957314
455 : CRC : program checksum …OK
466 : CRC : SecuritySettings CRC …OK
467 : CRC : binary has changed since last save of Settings
Build changed!
580 : SaveToFile: free stack: 3696
643 : FILE : Saved config.dat
644 : SaveToFile: free stack after: 3696
647 : SaveToFile: free stack: 3696
682 : FILE : Saved security.dat
683 : SaveToFile: free stack after: 3696
684 : INIT : Free RAM:26256
686 : INIT : I2C
687 : INIT : SPI not enabled
700 : INFO : Plugins: 46 [Normal] (ESP82xx Core 2_4_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support)
703 : WIFI : Set WiFi to STA
735 : WIFI : Connecting Linksys Velop WHW03 V2 attempt #0
737 : WIFI : Not configured in Station Mode!!: Linksys Velop WHW03 V2
2073 : WD : Uptime 0 ConnectFailures 0 FreeMem 24552 WiFiStatus 0
4781 : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 5 Duration: 3944 ms
6472 : WIFI : DHCP IP: 10.187.1.24 (ESP-Easy-0) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1791 ms
6478 : Webserver: start
32073 : WD : Uptime 1 ConnectFailures 0 FreeMem 18928 WiFiStatus 3
62072 : WD : Uptime 1 ConnectFailures 0 FreeMem 18928 WiFiStatus 3
92072 : WD : Uptime 2 ConnectFailures 0 FreeMem 18928 WiFiStatus 3
122072 : WD : Uptime 2 ConnectFailures 0 FreeMem 18928 WiFiStatus 3
Posted: 12 Jun 2021, 23:04
Just to be sure about the settings.
What settings do you use?
Suggested settings:
- Force WiFi B/G: checked
- Force WiFi No Sleep: checked
- Periodical send Gratuitous ARP: checked
- CPU Eco Mode: unchecked
- Send With Max TX Power: checked
- Periodical Scan WiFi: unchecked
I really have no clue at all why your setup is acting like this with the latest build I made.
Like I said lots and lots of users have used builds in the last 2 years (!!) without all these issues you seem to reproduce so well.
Especially the Force B/G setting I mention is to make sure it isn't an issue with 802.11n as it is a known issue that 'n' implementation differs in newer core versions, but the 20190226 to 20190227 build does not change that.
Posted: 12 Jun 2021, 23:09
by Tebogo
TD-er wrote: ↑12 Jun 2021, 23:04
Suggested settings:
I'll try these one by one. If no result than combined.. Keep you posted.
Posted: 13 Jun 2021, 00:19
by Tebogo
I don't have any setting, when I start. As you saw in earlier posts my flashing was always with a total erase. So the settings are the default settings which come with you bin file.
After flashing the ESP reboots, with default settings. I connect laptop with the ESP-Easy AP. Then my browser automatically starts the web page
http://ip-address/setup. I select my wifi network, enter my wifi key. After that the problems start.
So to prevent the problems, I abort the
http://ip-address/setup web page and enter
http://ip-adress/advanced. Then I can set the suggested settings, save, reboot and select on the
http://ip-address/setup, my wifi.
Suggested settings:
All these settings as suggested, individual or together don't solve the problem...
Posted: 13 Jun 2021, 01:26
by Tebogo
I do think it's not on Wifi level, but on IP level.
691547 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
691561 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:2 (-84dBm) WPA2/PSK attempt #73
691566 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
692747 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 2 Duration: 1184 ms
692748 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
692808 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 59 ms
692810 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
693941 : Info : WD : Uptime 12 ConnectFailures 0 FreeMem 18800 WiFiStatus WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP Init
723940 : Info : WD : Uptime 12 ConnectFailures 0 FreeMem 18296 WiFiStatus WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP Init
753941 : Info : WD : Uptime 13 ConnectFailures 0 FreeMem 18464 WiFiStatus WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP Init
783941 : Info : WD : Uptime 13 ConnectFailures 0 FreeMem 18464 WiFiStatus WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP Init
813941 : Info : WD : Uptime 14 ConnectFailures 0 FreeMem 18464 WiFiStatus WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP Init
843941 : Info : WD : Uptime 14 ConnectFailures 0 FreeMem 18696 WiFiStatus WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP Init
873941 : Info : WD : Uptime 15 ConnectFailures 0 FreeMem 18696 WiFiStatus WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP Init
903941 : Info : WD : Uptime 15 ConnectFailures 0 FreeMem 19160 WiFiStatus WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP Init
As you can see, is does connect, and get's a IP-address (10.187.1.143), but after that is start with status Conn. IP Init....
And the ESP is not ping-able on that ip-address.
Posted: 13 Jun 2021, 09:51
by Ath
And besides ping, you have tried to open your webbrowser on that IP-address, I assume? The connection seems stable now.
Posted: 13 Jun 2021, 09:53
Can you also enable NTP on Tools->Advanced?
This does require the ESP to connect to the outside.
Also if you set UDP port to 8266 and another ESP (can be an older version) in the same subnet with the UDP port set to the same port nr, both ESPs will try to exchange info between each other.
N.B. after setting the UDP port on the older node, you need to reboot the node to get the p2p service to start.
Posted: 13 Jun 2021, 10:46
by Tebogo
Ath wrote: ↑13 Jun 2021, 09:51
Yes, did that, but not accessible. Mostly I start trying to open the webpage. No response, than I try to ping
Posted: 13 Jun 2021, 11:21
by Tebogo
TD-er wrote: ↑13 Jun 2021, 09:53
Did that, and it looks like it connect to the NTP server, see logging, below:
134089 : Info : NTP : NTP replied: delay 745 mSec Accuracy increased by 1.152 seconds
134090 : Info : Time set to 1623575138.152 Time adjusted by 5368.52 msec. Wander: 1.49 msec/second
134094 : Info : Local time: 2021-06-13 09:05:38
Did that as well. I've 3 ESP's running, two on mega-20190226, which see each other over UDP:8266
The third one is flashed with your latest "bugfix/wifi_not_reconnect_56c4ca1’ (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)" version
Not seen by the other 2 ESP's...
77 : Info : INIT : Free RAM:32040
79 : Info : INIT : Soft Reboot #3 Last Action before Reboot: Intended Reboot: ResetFactory Last systime: 1623575002 - Restart Reason: Software/System restart
105 : Info : FS : Mount successful, used 75802 bytes of 957314
126 : Info : CRC : SecuritySettings CRC …OK
130 : Info : WiFi : Start network scan all channels
2319 : Info : WiFi : Scan finished, found: 8
2322 : Info : WiFi : Start network scan all channels
2430 : Info : INIT : Free RAM:27408
2432 : Info : INIT : I2C
2432 : Info : INIT : SPI not enabled
2542 : Info : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
2548 : Info : Webserver: start
2549 : Info : Time set to 1623575002.000
2551 : Info : Current Time Zone: STD time start: 2021-10-31 03:00:00 offset: 0 min
2553 : Info : Local time: 2021-06-13 09:03:22
3893 : Info : WD : Uptime 0 ConnectFailures 0 FreeMem 20416 WiFiStatus WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
4589 : Info : WiFi : Scan finished, found: 5
4593 : Error : WIFI : No valid wifi settings
4594 : Info : WIFI : Set WiFi to AP+STA
5584 : Info : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
33732 : Info : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
33905 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 14384 WiFiStatus WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
63902 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 11144 WiFiStatus WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
93889 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 15168 WiFiStatus WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
96145 : Info : Webserver args: 0: ‘usentp’ length: 2 1: ‘ntphost’ length: 13 2: ‘dststartweek’ length: 1 3: ‘dststartdow’ length: 1 4: ‘dststartmonth’ length: 1 5: ‘dststarthour’ length: 1 6: ‘dstendweek’ length: 1 7: ‘dstenddow’ length: 1 8: ‘dstendmonth’ length: 2 9: ‘dstendhour’ length: 1 10: ‘timezone’ length: 1 11: ‘latitude’ length: 8 12: ‘longitude’ length: 8 13: ‘syslogip’ length: 0 14: ‘syslogport’ length: 3 15: ‘syslog_log_level’ length: 1 16: ‘syslogfacility’ length: 1 17: ‘serial_log_level’ length: 1 18: ‘web_log_level’ length: 1 19: ‘useserial’ length: 2 20: ‘baudrate’ length: 6 21: ‘udpport’ length: 4 22: ‘webport’ length: 2 23: ‘ip’ length: 1 24: ‘wdi2caddress’ length: 1 25: ‘wireclockstretchlimit’ length: 1 26: ‘connection_failure_threshold’ length: 1 27: ‘max_wifi_tx_power’ length: 5 28: ‘wifi_sensitivity_margin’ length: 1 29: ‘extra_wifi_scan_loops’ length: 1 30: ‘periodical_scan_wifi’ length: 2 31: ‘edit’ length: 1 32: ‘plain’ length: 521
96151 : Info : SaveToFile: free stack: 3456
96223 : Info : FILE : Saved config.dat offset: 0 size: 1296
96225 : Info : SaveToFile: free stack after: 3456
96227 : Info : SaveToFile: free stack: 2960
96237 : Info : FILE : Saved security.dat offset: 1024 size: 128
96238 : Info : SaveToFile: free stack after: 2960
123910 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 15000 WiFiStatus WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
127401 : Info : SaveToFile: free stack: 3456
127471 : Info : FILE : Saved config.dat offset: 0 size: 1296
127471 : Info : SaveToFile: free stack after: 3456
127472 : Info : SaveToFile: free stack: 3296
127506 : Info : FILE : Saved security.dat offset: 0 size: 593
127507 : Info : SaveToFile: free stack after: 3296
127509 : Info : SaveToFile: free stack: 2960
127519 : Info : FILE : Saved security.dat offset: 1024 size: 128
127520 : Info : SaveToFile: free stack after: 2960
127522 : Info : WIFI : Credentials Changed, retry connection. SSID: Linksys Velop WHW03 V2
127524 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-73dBm) WPA2/PSK
127526 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-73dBm) WPA2/PSK attempt #0
127532 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
129459 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1927 ms
129460 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
132662 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 3199 ms
132675 : Info : SaveToFile: free stack: 3216
132685 : Info : FILE : Saved security.dat offset: 1024 size: 128
132686 : Info : SaveToFile: free stack after: 3216
132688 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
132779 : Info : UDP : Start listening on port 8266
132780 : Info : firstLoopConnectionsEstablished
145139 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 15 s
145139 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
147336 : Info : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 17 s
147337 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
147452 : Info : Reset WiFi.
147454 : Info : WIFI : Set WiFi to OFF
147568 : Info : WiFi : WiFiConnected() out of sync: DISCONNECTED RSSI: -74 status: STATION_CONNECTING
147579 : Info : AP Mode: Client disconnected: 3C:22:FB:0F:A1:70 Connected devices: 0
147682 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2 m 27 s
147683 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
148467 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-73dBm) WPA2/PSK
148469 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-73dBm) WPA2/PSK attempt #1
148572 : Info : WIFI : Set WiFi to STA
148740 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
148754 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:2 (-76dBm) WPA2/PSK attempt #2
148759 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
149937 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 2 Duration: 1177 ms
149938 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
153891 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 17184 WiFiStatus WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
155787 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 5847 ms
155799 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
156577 : Info : NTP : NTP replied: delay 241 mSec Accuracy increased by 0.401 seconds
156579 : Info : Time set to 1623575160.401 Time adjusted by 7.03 msec. Wander: 0.00 msec/second
156582 : Info : Local time: 2021-06-13 09:06:00
165073 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 15 s
165074 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
165978 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:8 (-79dBm) WPA2/PSK attempt #3
165983 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
166185 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 104 ms
167117 : Info : WIFI : Set WiFi to OFF
167351 : Error : WiFi : Scan not allowed, unprocessed WiFi events: disconn
167352 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
168127 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-84dBm) WPA2/PSK attempt #4
168230 : Info : WIFI : Set WiFi to STA
168387 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
168401 : Info : WiFi : Start network scan all channels
168404 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
170606 : Info : WiFi : Scan finished, found: 10
170610 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-73dBm) WPA2/PSK
170613 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-73dBm) WPA2/PSK attempt #5
170618 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
171604 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 988 ms
171605 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
173613 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 2010 ms
173626 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
174356 : Info : NTP : NTP replied: delay 20 mSec Accuracy increased by 0.069 seconds
174358 : Info : Time set to 1623575178.069 Time adjusted by -85.22 msec. Wander: -0.02 msec/second
174361 : Info : Local time: 2021-06-13 09:06:18
182207 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
182208 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
182221 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 11601 ms
182222 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
183107 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:8 (-83dBm) WPA2/PSK attempt #6
183112 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
184326 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 17096 WiFiStatus WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
184905 : Info : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1687 ms
185007 : Info : WIFI : Set WiFi to OFF
185241 : Error : WiFi : Scan not allowed, unprocessed WiFi events: disconn
185242 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
186017 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:2 (-85dBm) WPA2/PSK attempt #7
186120 : Info : WIFI : Set WiFi to STA
186277 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
186291 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-86dBm) WPA2/PSK attempt #8
186296 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
188465 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 2160 ms
188466 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
190318 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1864 ms
190330 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
190407 : Info : NTP : NTP replied: delay 20 mSec Accuracy increased by 0.118 seconds
190409 : Info : Time set to 1623575194.118 Time adjusted by 22.99 msec. Wander: 0.01 msec/second
190412 : Info : Local time: 2021-06-13 09:06:34
198787 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
198788 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
199691 : Info : WiFi : Start network scan all channels
199695 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
199808 : Info : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 11 s
199809 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
201888 : Info : WiFi : Scan finished, found: 9
201891 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK
201895 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-69dBm) WPA2/PSK attempt #9
201901 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
202911 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1003 ms
202912 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
Posted: 13 Jun 2021, 11:52
Can you try this test build:
https://www.dropbox.com/s/mg13ys8m5j2or ... M.bin?dl=0
I find it really strange the unit keeps getting disconnected.
So I now force the SDK to not automatically reconnect.
Maybe your unit has slightly different response (or combination with your APs) so that this may result in some strange interaction between ESPEasy trying to reconnect and the ESP's SDK trying to reconnect.
Posted: 13 Jun 2021, 12:20
OK, new test build:
https://www.dropbox.com/s/5q5qmifmvsx2k ... M.bin?dl=0
Based on your logs I did look again at the disconnect routine and found that there is a recently added semaphore to only handle the disconnect once.
However this semaphore could get in a state where it was not cleared anymore, which appears to have happened at your setup.
Posted: 13 Jun 2021, 13:17
by Tebogo
TD-er wrote: ↑13 Jun 2021, 11:52
This one does not solve the problem...
INIT : Booting version: ‘bugfix/wifi_not_reconnect_56c4ca1’ (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
76 : Info : INIT : Free RAM:32040
78 : Info : INIT : Manual Reboot #4 Last Action before Reboot: Background Task Last systime: 1623582873 - Restart Reason: External System
79 : Info : FS : Mounting…
104 : Info : FS : Mount successful, used 75802 bytes of 957314
125 : Info : CRC : SecuritySettings CRC …OK
129 : Info : WiFi : Start network scan all channels
243 : Info : INIT : Free RAM:27328
244 : Info : INIT : I2C
245 : Info : INIT : SPI not enabled
356 : Info : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
361 : Info : Webserver: start
362 : Info : Time set to 1623582873.000
364 : Info : Current Time Zone: STD time start: 2021-10-31 03:00:00 offset: 0 min
367 : Info : Local time: 2021-06-13 11:14:33
1709 : Info : WD : Uptime 0 ConnectFailures 0 FreeMem 20840 WiFiStatus WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
2407 : Info : WiFi : Scan finished, found: 6
2411 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-72dBm) WPA2/PSK
2412 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (0dBm) - attempt #0
2417 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
4466 : Info : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 1946 ms
4568 : Info : WIFI : Set WiFi to OFF
4803 : Error : WiFi : Scan not allowed, unprocessed WiFi events: disconn
4804 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
5677 : Info : WIFI : Set WiFi to STA
5828 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
5842 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-72dBm) WPA2/PSK
5843 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-72dBm) WPA2/PSK attempt #1
5849 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
6869 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 1005 ms
6870 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
6928 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 69 ms
6940 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
6950 : Info : UDP : Start listening on port 8266
6951 : Info : firstLoopConnectionsEstablished
8068 : Info : NTP : NTP replied: delay 20 mSec Accuracy increased by 0.364 seconds
8069 : Info : Time set to 1623582951.364 Time adjusted by 71580.33 msec. Wander: 19.88 msec/second
8072 : Info : Local time: 2021-06-13 11:15:51
16573 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 9622 ms
16574 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
17481 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:11 (-77dBm) WPA2/PSK attempt #2
17487 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
17788 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 11 Duration: 303 ms
17789 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
17841 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 54 ms
17853 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
18180 : Info : NTP : NTP replied: delay 31 mSec Accuracy increased by 0.478 seconds
18182 : Info : Time set to 1623582961.478 Time adjusted by 35.51 msec. Wander: 0.01 msec/second
18185 : Info : Local time: 2021-06-13 11:16:01
26282 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8395 ms
26283 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
27190 : Info : WiFi : Start network scan all channels
27193 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
29389 : Info : WiFi : Scan finished, found: 5
29392 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:8 (-71dBm) WPA2/PSK
29395 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:8 (-71dBm) WPA2/PSK attempt #3
29402 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
30332 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 8 Duration: 915 ms
30333 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
30380 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 66 ms
30392 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
31180 : Info : NTP : NTP replied: delay 30 mSec Accuracy increased by 0.482 seconds
31181 : Info : Time set to 1623582974.482 Time adjusted by 40.35 msec. Wander: 0.01 msec/second
31184 : Info : Local time: 2021-06-13 11:16:14
31703 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 18944 WiFiStatus WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP Init
31704 : Error : WiFi : Scan not needed, good candidate present
38836 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8423 ms
38837 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS0 ESPeasy internal wifi status: DISCONNECTED
39744 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-72dBm) WPA2/PSK attempt #4
39751 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: DISCONNECTED
39862 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 115 ms
39863 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED6 ESPeasy internal wifi status: Conn.
41405 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1537 ms
41417 : Info : WIFI : Arduino wifi status: WL_CONNECTED3 ESPeasy internal wifi status: Conn. IP
42170 : Info : NTP : NTP replied: delay 20 mSec Accuracy increased by 0.470 seconds
42172 : Info : Time set to 1623582985.470 Time adjusted by 22.66 msec. Wander: 0.01 msec/second
42175 : Info : Local time: 2021-06-13 11:16:25
Posted: 13 Jun 2021, 13:21
by Tebogo
TD-er wrote: ↑13 Jun 2021, 12:20
OK, new test build:
And this one has same result...
77 : Info : INIT : Manual Reboot #5 Last Action before Reboot: Background Task Last systime: 1623583074 - Restart Reason: External System
128 : Info : WiFi : Start network scan all channels
242 : Info : INIT : Free RAM:27616
244 : Info : INIT : SPI not enabled
366 : Info : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
371 : Info : Webserver: start
373 : Info : Time set to 1623583074.000
374 : Info : Current Time Zone: STD time start: 2021-10-31 03:00:00 offset: 0 min
377 : Info : Local time: 2021-06-13 11:17:54
1716 : Info : WD : Uptime 0 ConnectFailures 0 FreeMem 20856 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
2424 : Info : WiFi : Scan finished, found: 8
2429 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:5 (-74dBm) WPA2/PSK
2430 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:5 (-74dBm) WPA2/PSK attempt #0
2436 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
4486 : Info : WIFI : Disconnected! Reason: ‘(4) Assoc expire’ Connected for 1952 ms
4589 : Info : WIFI : Set WiFi to OFF
4804 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
4806 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-78dBm) WPA2/PSK attempt #1
4910 : Info : WIFI : Set WiFi to STA
5018 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
5032 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:5 (-74dBm) WPA2/PSK
5033 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:5 (-74dBm) WPA2/PSK attempt #2
5037 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
20128 : Info : WIFI : Set WiFi to AP+STA
21116 : Info : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
25041 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-78dBm) WPA2/PSK attempt #3
25047 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
28236 : Info : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 3086 ms
28338 : Info : WIFI : Set WiFi to OFF
28553 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
28555 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:5 (-74dBm) WPA2/PSK
28556 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:5 (-74dBm) WPA2/PSK attempt #4
28660 : Info : WIFI : Set WiFi to STA
28768 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
28781 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-78dBm) WPA2/PSK attempt #5
28786 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
31081 : Info : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 2198 ms
31183 : Info : WIFI : Set WiFi to OFF
31397 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
31399 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:5 (-74dBm) WPA2/PSK
31401 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:5 (-74dBm) WPA2/PSK attempt #6
31504 : Info : WIFI : Set WiFi to STA
31612 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
31625 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-78dBm) WPA2/PSK attempt #7
31631 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
32627 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 988 ms
32628 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
32641 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 19704 WiFiStatus WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
34183 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1567 ms
34195 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
34197 : Info : UDP : Start listening on port 8266
34197 : Info : firstLoopConnectionsEstablished
35192 : Info : NTP : NTP replied: delay 20 mSec Accuracy increased by 0.538 seconds
35193 : Info : Time set to 1623583177.538 Time adjusted by 68754.33 msec. Wander: 19.10 msec/second
35197 : Info : Local time: 2021-06-13 11:19:37
42708 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 9991 ms
42709 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
43612 : Info : WiFi : Start network scan all channels
43614 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
45813 : Info : WiFi : Scan finished, found: 8
45816 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:8 (-71dBm) WPA2/PSK
45818 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:8 (-71dBm) WPA2/PSK attempt #8
45824 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
47824 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 8 Duration: 1986 ms
47825 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
49706 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1897 ms
49718 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
50210 : Info : NTP : NTP replied: delay 51 mSec Accuracy increased by 0.567 seconds
50212 : Info : Time set to 1623583192.567 Time adjusted by 65.74 msec. Wander: 0.02 msec/second
50215 : Info : Local time: 2021-06-13 11:19:52
58110 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
58111 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
59015 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:5 (-76dBm) WPA2/PSK attempt #9
59021 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
59326 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 5 Duration: 292 ms
59327 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
59419 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 108 ms
59432 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
60190 : Info : NTP : NTP replied: delay 30 mSec Accuracy increased by 0.534 seconds
60192 : Info : Time set to 1623583202.534 Time adjusted by 21.81 msec. Wander: 0.01 msec/second
60195 : Info : Local time: 2021-06-13 11:20:02
61713 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 18680 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
61714 : Error : WiFi : Scan not needed, good candidate present
67822 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8413 ms
67823 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
68726 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:1 (-78dBm) WPA2/PSK attempt #10
68733 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
68844 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 1 Duration: 115 ms
68845 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
70680 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1835 ms
70692 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
71181 : Info : NTP : NTP replied: delay 21 mSec Accuracy increased by 0.525 seconds
71182 : Info : Time set to 1623583213.525 Time adjusted by 26.12 msec. Wander: 0.01 msec/second
71185 : Info : Local time: 2021-06-13 11:20:13
Posted: 13 Jun 2021, 13:33
by Ath
I've recently read a review of this Linksys Velop mesh router set, and the verdict was it has good potential, but many software issues/bugs, still. Have you checked for firmware updates for your AP?
Posted: 13 Jun 2021, 13:41
by Tebogo
Ath wrote: ↑13 Jun 2021, 13:33
Yes, it has the latest firmware... 2.1.16.204145
And I do have the same problems when connecting to my Fritz!Box 7590, also with latest firmware.. 07.27
Posted: 13 Jun 2021, 13:49
by Tebogo
I have let your latest build run for a bit longer time, but it ends in the same condition..
303964 : Info : WiFi : Start network scan all channels
303968 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
306161 : Info : WiFi : Scan finished, found: 5
306164 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:8 (-71dBm) WPA2/PSK
306167 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:8 (-71dBm) WPA2/PSK attempt #18
306174 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
306455 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 8 Duration: 272 ms
306456 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
306504 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy-2) GW: 10.187.1.254 SN: 255.255.255.0 duration: 58 ms
306516 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
307477 : Info : NTP : NTP replied: delay 30 mSec Accuracy increased by 0.262 seconds
307478 : Info : Time set to 1623584466.262 Time adjusted by 20.97 msec. Wander: 0.01 msec/second
307482 : Info : Local time: 2021-06-13 11:41:06
331818 : Info : WD : Uptime 6 ConnectFailures 0 FreeMem 16504 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
361818 : Info : WD : Uptime 6 ConnectFailures 0 FreeMem 16568 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
391818 : Info : WD : Uptime 7 ConnectFailures 0 FreeMem 16568 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
421818 : Info : WD : Uptime 7 ConnectFailures 0 FreeMem 16568 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
451818 : Info : WD : Uptime 8 ConnectFailures 0 FreeMem 16568 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
481818 : Info : WD : Uptime 8 ConnectFailures 0 FreeMem 16696 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
511818 : Info : WD : Uptime 9 ConnectFailures 0 FreeMem 16696 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
541818 : Info : WD : Uptime 9 ConnectFailures 0 FreeMem 16696 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
571818 : Info : WD : Uptime 10 ConnectFailures 0 FreeMem 16696 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
601818 : Info : WD : Uptime 10 ConnectFailures 0 FreeMem 16952 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
631818 : Info : WD : Uptime 11 ConnectFailures 0 FreeMem 17368 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
661818 : Info : WD : Uptime 11 ConnectFailures 0 FreeMem 17848 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
691818 : Info : WD : Uptime 12 ConnectFailures 0 FreeMem 17848 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
When I ping it says:
PING 10.187.1.143 (10.187.1.143): 56 data bytes
ping: sendto: Host is down
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
Request timeout for icmp_seq 2
Request timeout for icmp_seq 3
Request timeout for icmp_seq 4
Request timeout for icmp_seq 5
Request timeout for icmp_seq 6
Request timeout for icmp_seq 7
Request timeout for icmp_seq 8
And it not seen over UDP:8266 by the other ESP's...
Posted: 13 Jun 2021, 14:28
by Tebogo
Oke, we are a little bit further:
The ESP with the latest build has been seen over UDP:8266 (see attached screenshot)
But it's gone again. When I restart and immediately refresh the webpage of the other ESP's it comes back till age=10
Ping responds once (@118):
ping 10.187.1.143
Request timeout for icmp_seq 9
Request timeout for icmp_seq 10
Request timeout for icmp_seq 11
Request timeout for icmp_seq 12
Request timeout for icmp_seq 13
Request timeout for icmp_seq 14
Request timeout for icmp_seq 15
Request timeout for icmp_seq 16
Request timeout for icmp_seq 17
Request timeout for icmp_seq 18
Request timeout for icmp_seq 19
Request timeout for icmp_seq 20
Request timeout for icmp_seq 21
Request timeout for icmp_seq 22
Request timeout for icmp_seq 23
Request timeout for icmp_seq 24
Request timeout for icmp_seq 25
Request timeout for icmp_seq 26
Request timeout for icmp_seq 27
Request timeout for icmp_seq 28
Request timeout for icmp_seq 29
Request timeout for icmp_seq 30
Request timeout for icmp_seq 31
Request timeout for icmp_seq 32
Request timeout for icmp_seq 33
Request timeout for icmp_seq 34
Request timeout for icmp_seq 35
Request timeout for icmp_seq 36
Request timeout for icmp_seq 37
Request timeout for icmp_seq 38
Request timeout for icmp_seq 39
Request timeout for icmp_seq 40
Request timeout for icmp_seq 41
Request timeout for icmp_seq 42
Request timeout for icmp_seq 43
Request timeout for icmp_seq 44
Request timeout for icmp_seq 45
Request timeout for icmp_seq 46
Request timeout for icmp_seq 47
Request timeout for icmp_seq 48
Request timeout for icmp_seq 49
Request timeout for icmp_seq 50
Request timeout for icmp_seq 51
Request timeout for icmp_seq 52
Request timeout for icmp_seq 53
Request timeout for icmp_seq 54
Request timeout for icmp_seq 55
Request timeout for icmp_seq 56
Request timeout for icmp_seq 57
Request timeout for icmp_seq 58
Request timeout for icmp_seq 59
Request timeout for icmp_seq 60
Request timeout for icmp_seq 61
Request timeout for icmp_seq 62
Request timeout for icmp_seq 63
Request timeout for icmp_seq 64
Request timeout for icmp_seq 65
Request timeout for icmp_seq 66
Request timeout for icmp_seq 67
Request timeout for icmp_seq 68
Request timeout for icmp_seq 69
Request timeout for icmp_seq 70
Request timeout for icmp_seq 71
Request timeout for icmp_seq 72
Request timeout for icmp_seq 73
Request timeout for icmp_seq 74
Request timeout for icmp_seq 75
Request timeout for icmp_seq 76
Request timeout for icmp_seq 77
Request timeout for icmp_seq 78
Request timeout for icmp_seq 79
Request timeout for icmp_seq 80
Request timeout for icmp_seq 81
Request timeout for icmp_seq 82
Request timeout for icmp_seq 83
Request timeout for icmp_seq 84
Request timeout for icmp_seq 85
Request timeout for icmp_seq 86
Request timeout for icmp_seq 87
Request timeout for icmp_seq 88
Request timeout for icmp_seq 89
Request timeout for icmp_seq 90
Request timeout for icmp_seq 91
Request timeout for icmp_seq 92
Request timeout for icmp_seq 93
Request timeout for icmp_seq 94
Request timeout for icmp_seq 95
Request timeout for icmp_seq 96
Request timeout for icmp_seq 97
Request timeout for icmp_seq 98
Request timeout for icmp_seq 99
Request timeout for icmp_seq 100
Request timeout for icmp_seq 101
Request timeout for icmp_seq 102
Request timeout for icmp_seq 103
Request timeout for icmp_seq 104
Request timeout for icmp_seq 105
Request timeout for icmp_seq 106
Request timeout for icmp_seq 107
Request timeout for icmp_seq 108
Request timeout for icmp_seq 109
Request timeout for icmp_seq 110
Request timeout for icmp_seq 111
Request timeout for icmp_seq 112
Request timeout for icmp_seq 113
Request timeout for icmp_seq 114
Request timeout for icmp_seq 115
Request timeout for icmp_seq 116
Request timeout for icmp_seq 117
64 bytes from 10.187.1.143: icmp_seq=118 ttl=255 time=31.087 ms
Request timeout for icmp_seq 119
Request timeout for icmp_seq 120
Request timeout for icmp_seq 121
Request timeout for icmp_seq 122
Request timeout for icmp_seq 123
Request timeout for icmp_seq 124
Request timeout for icmp_seq 125
Request timeout for icmp_seq 126
Request timeout for icmp_seq 127
Request timeout for icmp_seq 128
Request timeout for icmp_seq 129
Request timeout for icmp_seq 130
Request timeout for icmp_seq 131
Request timeout for icmp_seq 132
Request timeout for icmp_seq 133
Request timeout for icmp_seq 134
Request timeout for icmp_seq 135
Request timeout for icmp_seq 136
Request timeout for icmp_seq 137
Request timeout for icmp_seq 138
Request timeout for icmp_seq 139
Request timeout for icmp_seq 140
Request timeout for icmp_seq 141
Request timeout for icmp_seq 142
Request timeout for icmp_seq 143
Request timeout for icmp_seq 144
Request timeout for icmp_seq 145
Request timeout for icmp_seq 146
Request timeout for icmp_seq 147
Request timeout for icmp_seq 148
Request timeout for icmp_seq 149
Request timeout for icmp_seq 150
Request timeout for icmp_seq 151
Request timeout for icmp_seq 152
Request timeout for icmp_seq 153
Request timeout for icmp_seq 154
Request timeout for icmp_seq 155
Request timeout for icmp_seq 156
Request timeout for icmp_seq 157
Request timeout for icmp_seq 158
Webpage of the ESP with the latest build is never accessible.
Posted: 13 Jun 2021, 14:34
Can you try setting the IP to a fixed setting?
And if that doesn't work, can you set the subnetmask (255.255.255.0) to the same value as the gateway?
I know it doesn't make sense to do it like that, but found it as a suggestion on a Reddit thread.
Posted: 13 Jun 2021, 14:48
Aonther thing to try (more credible than the really odd suggestion on Reddit of using a complete nonsense subnet)
Can you give the command wifidisconnect after it has made a connection?
This will retry to connect to the AP, without performing a scan.
I got the feeling that maybe things might get messed up by connecting too soon after a WiFi scan.
Posted: 13 Jun 2021, 15:21
by Tebogo
TD-er wrote: ↑13 Jun 2021, 14:34
89015 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 255.255.255.0 DNS: 10.187.1.111
No solution:
78 : Info : INIT : Free RAM:32040
79 : Info : INIT : Soft Reboot #24 Last Action before Reboot: Intended Reboot: CommandReboot Last systime: 1623590804 - Restart Reason: Software/System restart
81 : Info : FS : Mounting…
106 : Info : FS : Mount successful, used 75802 bytes of 957314
192 : Info : FS : Success garbage collection
214 : Info : CRC : SecuritySettings CRC …OK
218 : Info : WiFi : Start network scan all channels
2406 : Info : WiFi : Scan finished, found: 8
2408 : Info : WiFi : Start network scan all channels
2516 : Info : INIT : Free RAM:27296
2518 : Info : INIT : I2C
2518 : Info : INIT : SPI not enabled
2638 : Info : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
2643 : Info : Webserver: start
2645 : Info : Time set to 1623590804.000
2646 : Info : Current Time Zone: STD time start: 2021-10-31 03:00:00 offset: 0 min
2649 : Info : Local time: 2021-06-13 13:26:44
3997 : Info : WD : Uptime 0 ConnectFailures 0 FreeMem 20120 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
4692 : Info : WiFi : Scan finished, found: 6
4695 : Error : WIFI : No valid wifi settings
4695 : Info : WIFI : Set WiFi to AP+STA
5685 : Info : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
11769 : Info : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
34103 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 14768 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
50973 : Info : Webserver args: 0: ‘usentp’ length: 2 1: ‘ntphost’ length: 13 2: ‘dststartweek’ length: 1 3: ‘dststartdow’ length: 1 4: ‘dststartmonth’ length: 1 5: ‘dststarthour’ length: 1 6: ‘dstendweek’ length: 1 7: ‘dstenddow’ length: 1 8: ‘dstendmonth’ length: 2 9: ‘dstendhour’ length: 1 10: ‘timezone’ length: 1 11: ‘latitude’ length: 8 12: ‘longitude’ length: 8 13: ‘syslogip’ length: 0 14: ‘syslogport’ length: 3 15: ‘syslog_log_level’ length: 1 16: ‘syslogfacility’ length: 1 17: ‘serial_log_level’ length: 1 18: ‘web_log_level’ length: 1 19: ‘useserial’ length: 2 20: ‘baudrate’ length: 6 21: ‘udpport’ length: 4 22: ‘webport’ length: 2 23: ‘ip’ length: 1 24: ‘wdi2caddress’ length: 1 25: ‘wireclockstretchlimit’ length: 1 26: ‘connection_failure_threshold’ length: 1 27: ‘max_wifi_tx_power’ length: 5 28: ‘wifi_sensitivity_margin’ length: 1 29: ‘extra_wifi_scan_loops’ length: 1 30: ‘periodical_scan_wifi’ length: 2 31: ‘edit’ length: 1 32: ‘plain’ length: 521
50979 : Info : SaveToFile: free stack: 3456
51054 : Info : FILE : Saved config.dat offset: 0 size: 1296
51055 : Info : SaveToFile: free stack after: 3456
51058 : Info : SaveToFile: free stack: 2960
51068 : Info : FILE : Saved security.dat offset: 1024 size: 128
51070 : Info : SaveToFile: free stack after: 2960
64006 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 14936 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
88722 : Info : Webserver args: 0: ‘name’ length: 8 1: ‘unit’ length: 1 2: ‘appendunittohostname’ length: 2 3: ‘password’ length: 0 4: ‘ssid’ length: 22 5: ‘key’ length: 10 6: ‘ssid2’ length: 0 7: ‘key2’ length: 0 8: ‘apkey’ length: 5 9: ‘ipblocklevel’ length: 1 10: ‘iprangelow’ length: 0 11: ‘iprangehigh’ length: 0 12: ‘espip’ length: 12 13: ‘espgateway’ length: 12 14: ‘espsubnet’ length: 13 15: ‘espdns’ length: 12 16: ‘awaketime’ length: 1 17: ‘delay’ length: 2 18: ‘plain’ length: 270
88725 : Info : SaveToFile: free stack: 3424
88820 : Info : FILE : Saved config.dat offset: 0 size: 1296
88821 : Info : SaveToFile: free stack after: 3424
88823 : Info : SaveToFile: free stack: 3264
88856 : Info : FILE : Saved security.dat offset: 0 size: 593
88857 : Info : SaveToFile: free stack after: 3264
88860 : Info : SaveToFile: free stack: 2928
88870 : Info : FILE : Saved security.dat offset: 1024 size: 128
88871 : Info : SaveToFile: free stack after: 2928
89012 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-64dBm) WPA2/PSK
89014 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-64dBm) WPA2/PSK attempt #0
89021 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
91443 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 10 Duration: 2421 ms
91444 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn.
91445 : Info : WIFI : Static IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 8 ms
91458 : Info : SaveToFile: free stack: 3216
91469 : Info : FILE : Saved security.dat offset: 1024 size: 128
91469 : Info : SaveToFile: free stack after: 3216
91472 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
91536 : Info : UDP : Start listening on port 8266
91537 : Info : firstLoopConnectionsEstablished
92472 : Info : NTP : NTP replied: delay 21 mSec Accuracy increased by 0.689 seconds
92474 : Info : Time set to 1623590904.689 Time adjusted by 10904.73 msec. Wander: 3.03 msec/second
92478 : Info : Local time: 2021-06-13 13:28:24
93984 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 13064 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
93986 : Error : WiFi : Scan not needed, good candidate present
99766 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8229 ms
99767 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
123997 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 13400 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
153991 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 13400 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
153992 : Info : WiFi : Start network scan all channels
156195 : Info : WiFi : Scan finished, found: 7
Is this what you mean:
139836 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
No solution:
78 : Info : INIT : Soft Reboot #25 Last Action before Reboot: Intended Reboot: CommandReboot Last systime: 1623591161 - Restart Reason: Software/System restart
80 : Info : FS : Mounting…
168 : Info : FS : Success garbage collection
219 : Info : FS : Success garbage collection
241 : Info : CRC : SecuritySettings CRC …OK
245 : Info : WiFi : Start network scan all channels
2433 : Info : WiFi : Scan finished, found: 8
2435 : Info : WiFi : Start network scan all channels
2543 : Info : INIT : Free RAM:27216
2545 : Info : INIT : I2C
2545 : Info : INIT : SPI not enabled
2667 : Info : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
2672 : Info : Webserver: start
2673 : Info : Time set to 1623591161.000
2675 : Info : Current Time Zone: STD time start: 2021-10-31 03:00:00 offset: 0 min
2678 : Info : Local time: 2021-06-13 13:32:41
4016 : Info : WD : Uptime 0 ConnectFailures 0 FreeMem 20304 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
4711 : Info : WiFi : Scan finished, found: 4
4714 : Error : WIFI : No valid wifi settings
4715 : Info : WIFI : Set WiFi to AP+STA
5705 : Info : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
14567 : Info : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
34034 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 13872 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
64017 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 15088 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
93213 : Info : Webserver args: 0: ‘name’ length: 8 1: ‘unit’ length: 1 2: ‘appendunittohostname’ length: 2 3: ‘password’ length: 0 4: ‘ssid’ length: 22 5: ‘key’ length: 11 6: ‘ssid2’ length: 0 7: ‘key2’ length: 0 8: ‘apkey’ length: 5 9: ‘ipblocklevel’ length: 1 10: ‘iprangelow’ length: 0 11: ‘iprangehigh’ length: 0 12: ‘espip’ length: 12 13: ‘espgateway’ length: 12 14: ‘espsubnet’ length: 12 15: ‘espdns’ length: 12 16: ‘awaketime’ length: 1 17: ‘delay’ length: 2 18: ‘plain’ length: 270
93216 : Info : SaveToFile: free stack: 3424
93289 : Info : FILE : Saved config.dat offset: 0 size: 1296
93290 : Info : SaveToFile: free stack after: 3424
93291 : Info : SaveToFile: free stack: 3264
93324 : Info : FILE : Saved security.dat offset: 0 size: 593
93325 : Info : SaveToFile: free stack after: 3264
93353 : Info : SaveToFile: free stack: 2928
93363 : Info : FILE : Saved security.dat offset: 1024 size: 128
93364 : Info : SaveToFile: free stack after: 2928
93592 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-65dBm) WPA2/PSK
93594 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-65dBm) WPA2/PSK attempt #0
93596 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
93601 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
94555 : Info : AP Mode: Client disconnected: 3C:22:FB:0F:A1:70 Connected devices: 0
94643 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 14384 WiFiStatus WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
98708 : Info : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 5004 ms
98709 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
99610 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:6 (-73dBm) WPA2/PSK attempt #1
99612 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
99618 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
102775 : Info : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 3056 ms
102877 : Info : WIFI : Set WiFi to OFF
103092 : Info : WiFi : Start network scan all channels
105279 : Info : WiFi : Scan finished, found: 8
105282 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-62dBm) WPA2/PSK
105283 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
105285 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-62dBm) WPA2/PSK attempt #2
105287 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
105292 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
111218 : Info : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 5830 ms
111219 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
112126 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:6 (-72dBm) WPA2/PSK attempt #3
112127 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
112133 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
113188 : Info : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 953 ms
113290 : Info : WIFI : Set WiFi to OFF
113504 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
113506 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:3 (-77dBm) WPA2/PSK attempt #4
113610 : Info : WIFI : Set WiFi to STA
113714 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
113720 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
113720 : Info : WIFI : Set WiFi to AP+STA
114714 : Info : WIFI : AP Mode ssid will be ESP-Easy-2 with address 192.168.4.1
116803 : Info : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 3186 ms
116905 : Info : WIFI : Set WiFi to OFF
117120 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
117121 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:9 (-82dBm) WPA2/PSK attempt #5
117225 : Info : WIFI : Set WiFi to STA
117329 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
117335 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
122441 : Info : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 5209 ms
122442 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
123339 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-83dBm) WPA2/PSK attempt #6
123340 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
123345 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
124400 : Info : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 954 ms
124502 : Info : WIFI : Set WiFi to OFF
124716 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
124718 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-62dBm) WPA2/PSK
124720 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-62dBm) WPA2/PSK attempt #7
124824 : Info : WIFI : Set WiFi to STA
124928 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
124933 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
124990 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 16736 WiFiStatus WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
130027 : Info : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 5204 ms
130028 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
130933 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:6 (-72dBm) WPA2/PSK attempt #8
130935 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
130941 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
131995 : Info : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 952 ms
132097 : Info : WIFI : Set WiFi to OFF
132312 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
132314 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:3 (-77dBm) WPA2/PSK attempt #9
132417 : Info : WIFI : Set WiFi to STA
132521 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
132527 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
137125 : Info : WIFI : Set WiFi to AP+STA
138116 : Info : WIFI : AP Mode ssid will be ESP-Easy-2 with address 192.168.4.1
138221 : Info : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 5805 ms
138222 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
139123 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:9 (-82dBm) WPA2/PSK attempt #10
139125 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
139131 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
139309 : Info : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 69 ms
139411 : Info : WIFI : Set WiFi to OFF
139626 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
139628 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-83dBm) WPA2/PSK attempt #11
139732 : Info : WIFI : Set WiFi to STA
139842 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
144947 : Info : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 5210 ms
144948 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
145845 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
145846 : Info : WiFi : Start network scan all channels
145848 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
145962 : Info : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 6219 ms
145963 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
148048 : Info : WiFi : Scan finished, found: 7
148052 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-62dBm) WPA2/PSK
148055 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-62dBm) WPA2/PSK attempt #12
148056 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
148061 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
153175 : Info : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 4999 ms
153277 : Info : WIFI : Set WiFi to OFF
153591 : Info : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 5223 ms
153592 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
153603 : Info : WiFi : Start network scan all channels
155790 : Info : WiFi : Scan finished, found: 8
155794 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-66dBm) WPA2/PSK
155795 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
155796 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-66dBm) WPA2/PSK attempt #13
155798 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
155804 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
155904 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 16608 WiFiStatus WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
159124 : Info : WIFI : Set WiFi to AP+STA
160114 : Info : WIFI : AP Mode ssid will be ESP-Easy-2 with address 192.168.4.1
161105 : Info : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 5188 ms
161106 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
161996 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:6 (-73dBm) WPA2/PSK attempt #14
161998 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
162004 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
163059 : Info : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 953 ms
163161 : Info : WIFI : Set WiFi to OFF
163376 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
163378 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:3 (-78dBm) WPA2/PSK attempt #15
163481 : Info : WIFI : Set WiFi to STA
163585 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
163591 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
168694 : Info : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 5205 ms
168695 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
169592 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:9 (-84dBm) WPA2/PSK attempt #16
169594 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
169599 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
170746 : Info : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 1046 ms
170848 : Info : WIFI : Set WiFi to OFF
171063 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
171065 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-86dBm) WPA2/PSK attempt #17
171168 : Info : WIFI : Set WiFi to STA
171273 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
171278 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
176389 : Info : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 5213 ms
176390 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
177288 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
177289 : Info : WiFi : Start network scan all channels
177291 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
177404 : Info : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 6225 ms
177405 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
179495 : Info : WiFi : Scan finished, found: 6
179498 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-66dBm) WPA2/PSK
179501 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-66dBm) WPA2/PSK attempt #18
179503 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
179507 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
182003 : Info : WIFI : Set WiFi to AP+STA
182113 : Info : WIFI : AP Mode ssid will be ESP-Easy-2 with address 192.168.4.1
184063 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 15224 WiFiStatus WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
184622 : Info : WIFI : Disconnected! Reason: ‘(2) Auth expire’ Connected for 5010 ms
184623 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
185524 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:6 (-73dBm) WPA2/PSK attempt #19
185526 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
185532 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
186957 : Info : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 1324 ms
187059 : Info : WIFI : Set WiFi to OFF
187273 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
187275 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:3 (-76dBm) WPA2/PSK attempt #20
187379 : Info : WIFI : Set WiFi to STA
187483 : Info : IP : Static IP : 10.187.1.143 GW: 10.187.1.254 SN: 10.187.1.254 DNS: 10.187.1.111
187489 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
Re: Latest versions crashes my NodeMCU
Posted: 13 Jun 2021, 15:55
by Tebogo
TD-er wrote: ↑13 Jun 2021, 14:48
No solution as well ...
297248 : Info : UDP : Start listening on port 8266
297249 : Info : firstLoopConnectionsEstablished
297318 : Info : NTP : NTP replied: delay 30 mSec Accuracy increased by 0.215 seconds
297320 : Info : Time set to 1623592257.215
297322 : Info : Current Time Zone: DST time start: 2021-03-28 02:00:00 offset: 120 min STD time start: 2021-10-31 03:00:00 offset: 60 min
297325 : Info : Local time: 2021-06-13 15:50:57
303899 : Info : WD : Uptime 5 ConnectFailures 0 FreeMem 14808 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
303900 : Error : WiFi : Scan not needed, good candidate present
305721 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 17 s
305722 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
311543 : Info : AP Mode: Client disconnected: 3C:22:FB:0F:A1:70 Connected devices: 0
311546 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-71dBm) WPA2/PSK
311548 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-71dBm) WPA2/PSK attempt #1
311554 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
311666 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 10 Duration: 116 ms
311667 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
311737 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy-2) GW: 10.187.1.254 SN: 255.255.255.0 duration: 66 ms
311749 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
312292 : Info : NTP : NTP replied: delay 30 mSec Accuracy increased by 0.193 seconds
312294 : Info : Time set to 1623592272.193 Time adjusted by 38.95 msec. Wander: 0.01 msec/second
312297 : Info : Local time: 2021-06-13 15:51:12
333899 : Info : WD : Uptime 6 ConnectFailures 0 FreeMem 16184 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
333900 : Error : WiFi : Scan not needed, good candidate present
363899 : Info : WD : Uptime 6 ConnectFailures 0 FreeMem 16184 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
363900 : Error : WiFi : Scan not needed, good candidate present
wifidisconnect
>wifidisconnect
Ok
376413 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 1 m 4 s
376414 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: DISCONNECTED
384981 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 1 m 13 s
384982 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
385890 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:6 (-75dBm) WPA2/PSK attempt #2
385897 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
387075 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 6 Duration: 1166 ms
387076 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
387145 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy-2) GW: 10.187.1.254 SN: 255.255.255.0 duration: 83 ms
387157 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
387313 : Info : NTP : NTP replied: delay 50 mSec Accuracy increased by 0.209 seconds
387314 : Info : Time set to 1623592347.209 Time adjusted by 49.57 msec. Wander: 0.01 msec/second
387318 : Info : Local time: 2021-06-13 15:52:27
393899 : Info : WD : Uptime 7 ConnectFailures 0 FreeMem 16208 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
393900 : Error : WiFi : Scan not needed, good candidate present
423898 : Info : WD : Uptime 7 ConnectFailures 0 FreeMem 16208 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
423900 : Error : WiFi : Scan not needed, good candidate present
453898 : Info : WD : Uptime 8 ConnectFailures 0 FreeMem 16208 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
453900 : Error : WiFi : Scan not needed, good candidate present
483899 : Info : WD : Uptime 8 ConnectFailures 0 FreeMem 16208 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
483900 : Error : WiFi : Scan not needed, good candidate present
513899 : Info : WD : Uptime 9 ConnectFailures 0 FreeMem 16840 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
513900 : Error : WiFi : Scan not needed, good candidate present
543898 : Info : WD : Uptime 9 ConnectFailures 0 FreeMem 16840 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
543900 : Error : WiFi : Scan not needed, good candidate present
Posted: 13 Jun 2021, 16:15
by Tebogo
I entered Debug 4. It gives you more details:
77 : Info : INIT : Free RAM:32040
78 : Info : INIT : Soft Reboot #4 Last Action before Reboot: Intended Reboot: CommandReboot Last systime: 1623593581 - Restart Reason: Software/System restart
105 : Info : FS : Mount successful, used 75802 bytes of 957314
126 : Info : CRC : SecuritySettings CRC …OK
130 : Info : WiFi : Start network scan all channels
244 : Info : INIT : Free RAM:27616
245 : Info : INIT : I2C
246 : Info : INIT : SPI not enabled
369 : Info : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
374 : Info : Webserver: start
376 : Info : Time set to 1623593581.000
377 : Info : Current Time Zone: DST time start: 2021-03-28 02:00:00 offset: 120 min STD time start: 2021-10-31 03:00:00 offset: 60 min
381 : Info : Local time: 2021-06-13 16:13:01
1719 : Info : WD : Uptime 0 ConnectFailures 0 FreeMem 21072 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
2414 : Info : WiFi : Scan finished, found: 4
2419 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:3 (-77dBm) WPA2/PSK
2421 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:3 (-77dBm) WPA2/PSK attempt #0
2511 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
3678 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 3 Duration: 1242 ms
3679 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
3716 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy-2) GW: 10.187.1.254 SN: 255.255.255.0 duration: 50 ms
3729 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
3764 : Info : firstLoopConnectionsEstablished
3767 : Info : UDP : Start listening on port 8266
4201 : Info : NTP : NTP replied: delay 21 mSec Accuracy increased by 0.780 seconds
4203 : Info : Time set to 1623593585.780 Time adjusted by 993.30 msec. Wander: 0.28 msec/second
4207 : Info : Local time: 2021-06-13 16:13:05
12135 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8369 ms
12136 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
12522 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 3 Duration: 10092 ms
12523 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
13034 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:9 (-80dBm) WPA2/PSK attempt #1
13040 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
14137 : Info : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 999 ms
14239 : Info : WIFI : Set WiFi to OFF
14553 : Info : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 1205 ms
14776 : Error : WiFi : Scan not allowed, unprocessed WiFi events: disconn
14777 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
14787 : Info : WiFi : Start network scan all channels
16974 : Info : WiFi : Scan finished, found: 6
16977 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-69dBm) WPA2/PSK
16978 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
16979 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-69dBm) WPA2/PSK attempt #2
16986 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
17972 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 10 Duration: 989 ms
17973 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
18035 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy-2) GW: 10.187.1.254 SN: 255.255.255.0 duration: 62 ms
18047 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
19042 : Info : NTP : NTP replied: delay 21 mSec Accuracy increased by 0.617 seconds
19044 : Info : Time set to 1623593600.617 Time adjusted by 22.03 msec. Wander: 0.01 msec/second
19047 : Info : Local time: 2021-06-13 16:13:20
27645 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 9573 ms
27646 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
28546 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:6 (-71dBm) WPA2/PSK attempt #3
28552 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
29391 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 6 Duration: 842 ms
29392 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
29441 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy-2) GW: 10.187.1.254 SN: 255.255.255.0 duration: 42 ms
29453 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
30072 : Info : NTP : NTP replied: delay 50 mSec Accuracy increased by 0.647 seconds
30074 : Info : Time set to 1623593611.647 Time adjusted by 55.55 msec. Wander: 0.02 msec/second
30077 : Info : Local time: 2021-06-13 16:13:31
D31716 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 18720 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
ebug 4
>Debug 4
Ok
bcn_timout,ap_probe_send_start
ap_probe_send over, rest wifi status to disassoc
state: 5 -> 0 (1)
rm 0
37798 : Debug : WIFI : Entering processDisconnect()
37900 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8408 ms
37900 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
37901 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
connected with Linksys Velop WHW03 V2, channel 6
dhcp client start…
38541 : Debug : WIFI : Entering processConnect()
38542 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 6 Duration: 9992 ms
38543 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
38799 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:3 (-79dBm) WPA2/PSK attempt #4
38804 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
38805 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: -76 status: STATION_CONNECTING
scandone
state: 5 -> 2 (b0)
state: 5 -> 0 (2)
reconnect
40937 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_WRONG_PASSWORD
40948 : Debug : WIFI : Entering processDisconnect()
41049 : Info : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 2133 ms
41151 : Info : WIFI : Set WiFi to OFFscandone
del if0
usl
mode : null
force slp enable,type: 2
fpm open,type:2 0
41366 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
41368 : Info : WIFI : Connecting Linksysfpm close 3
Velop WHW03 V2 30:23:03:AE:5D:83 Ch:9 (-81dBm) WPA2/PSK attempt #5
41472 : Info : WIFI : Set WiFi to STAmode : sta(f4:cf:a2:ed:b5:ed)
add if0
sleep enable,type: 2
41476 : Debug : WiFi : Set TX power to 0dBm sensitivity: -69dBm
41582 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
41584 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
41597 : Info : WIFI : Connscandone
ecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-82dBm) WPA2/PSK attempt #6
41602 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
connected with Linksys Velop WHW03 V2, channel 1
dhcp client start…
42825 : Debug : WIFI : Entering processConnect()
42826 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 1 Duration: 1215 ms
42827 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
ip:10.187.1.143,mask:255.255.255.0,gw:10.187.1.254
42917 : Debug : WIFI : Entering processGotIP()
42919 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy-2) GW: 10.187.1.254 SN: 255.255.255.0 duration: 99 ms
42931 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
42931 : Debug : WiFi : WiFi services initialized
43020 : Debug More : NTP : NTP host ntp.xs4all.nl (194.109.6.2) queried
43053 : Info : NTP : NTP replied: delay 31 mSec Accuracy increased by 0.632 seconds
43054 : Info : Time set to 1623593624.632 Time adjusted by 40.05 msec. Wander: 0.01 msec/second
43057 : Info : Local time: 2021-06-13 16:13:44
state: 5 -> 0 (1)
rm 0
51165 : Debug : WIFI : Entering processDisconnect()
51266 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8351 ms
51267 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
51268 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_IDLE
52173 : Info : WiFi : Start network scan all channels
52174 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
scandone
54379 : Info : WiFi : Scan finished, found: 7
54380 : Debug : WiFi : Scan result: #Hidden# 36:23:03:13:49:8D Ch:1 (-87dBm) WPA2/PSK
54382 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:3 (-80dBm) WPA2/PSK
54383 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:6 (-72dBm) WPA2/PSK
54384 : Debug : WiFi : Scan result: #Hidden# 36:23:03:39:C3:A3 Ch:6 (-73dBm) WPA2/PSK
54385 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-87dBm) WPA2/PSK
54386 : Debug : WiFi : Scan result: FRITZ!Box 7490 08:96:D7:84:7F:81 Ch:8 (-78dBm) WPA2/PSK
54388 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-69dBm) WPA2/PSK
54389 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-69dBm) WPA2/PSK
54393 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-69dBm) WPA2/PSK attempt #7
54399 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
54400 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 8
cnt
connected with Linksys Velop WHW03 V2, channel 10
dhcp client start…
55499 : Debug : WIFI : Entering processConnect()
55501 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 10 Duration: 1101 ms
55502 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
57489 : Debug : WIFI : Entering processGotIP()
57491 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy-2) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1990 ms
57503 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
57504 : Debug : WiFi : WiFi services initialized
58020 : Debug More : NTP : NTP host ntp.xs4all.nl (194.109.6.2) queried
58042 : Info : NTP : NTP replied: delay 20 mSec Accuracy increased by 0.616 seconds
58044 : Info : Time set to 1623593639.616 Time adjusted by 20.14 msec. Wander: 0.01 msec/second
58047 : Info : Local time: 2021-06-13 16:13:59
61716 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 18368 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
61718 : Debug More : UDP : Send Sysinfo message
62606 : Debug : LoopStats: shortestLoop: 214 longestLoop: 2961483 avgLoopDuration: 1033.57 loopCounterMax: 140186 loopCounterLast: 28902
62607 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 62222/3562/6/62.92
pm open,type:2 0
state: 5 -> 0 (1)
rm 0
pm close 7
65839 : Debug : WIFI : Entering processDisconnect()
65940 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
65941 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
65942 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_IDLE
66847 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:6 (-72dBm) WPA2/PSK attempt #8
66853 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
66855 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
dhcp client start…
67199 : Debug : WIFI : Entering processConnect()
67200 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 6 Duration: 333 ms
67201 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
67248 : Debug : WIFI : Entering processGotIP()
67249 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy-2) GW: 10.187.1.254 SN: 255.255.255.0 duration: 58 ms
67261 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
67262 : Debug : WiFi : WiFi services initialized
68020 : Debug More : NTP : NTP host ntp.xs4all.nl (194.109.6.2) queried
68042 : Info : NTP : NTP replied: delay 21 mSec Accuracy increased by 0.621 seconds
68044 : Info : Time set to 1623593649.621 Time adjusted by 30.44 msec. Wander: 0.01 msec/second
68047 : Info : Local time: 2021-06-13 16:14:09
Maybe this helps?
Posted: 13 Jun 2021, 19:25
I really don't understand what is happening here.
- It does connect
- It does get an IP
- It can perform DNS lookup
- It does receive NTP answer.
But why doesn't it reply to pings?
Why does it get disconnected after 10 seconds (or less)
I absolutely have no clue.
Posted: 13 Jun 2021, 20:07
by Tebogo
I know, it's a strange thing, but I'm not the first who already experienced this. In this Topic, you also already worked on it.
TD-er wrote: ↑27 Dec 2020, 17:09
I think we need a bit more info.
How often does this occur?
What have you tried to mitigate this issue?
- Switch to B/G Wifi
- Fix channel on Access point (preferred to use ch 1, 6 or 11)
- Disable 'Eco' mode
- Use access point exclusively for ESP nodes (not shared with other devices)
- Try other orientation of the ESP to try and match antenna polarity with antenna of access point
- Make sure to use proper power supply and cabling
- Add extra capacitor over the 3v3 line and GND
- Make sure your ESP node does have a proper 3v3 voltage regulator (lots of Wemos D1 mini nodes sold currently have a regulator only capable of 150 mA)
A site where Grovkillen has responded:
https://bleepcoder.com/espeasy/37805750 ... ct-to-wifi
And here:
https://ask.csdn.net/questions/6241977
It must be something in later ESPEasy-build, releated to these ESP's. They are solded a lot. If we find what it is, you help a lot of people.
Would a network sniffer give us more information?
Posted: 14 Jun 2021, 12:17
I browsed through your (debug) logs once more and noticed you have reported states of "connecting" which I normally don't see.
Also the 4-way handshake does seem to timeout every once in a while.
So I guess your AP may need some more time to connect, or the ESP is not receiving all replies from the AP.
Also the disconnects do seem a bit too regular (8 - 10 seconds) where the used timeout in ESPEasy is 10 seconds for a lot of processes regarding handling the WiFi connection.
I did tweak this handling a bit more, but I got the feeling there is something going on in your setup regarding the interval between WiFi scanning and first connecting.
So here is a first test build to at least be a bit more forgiving on "connecting" states:
https://www.dropbox.com/s/vu9f8c1lz2oma ... M.bin?dl=0
I will try to have a look at what to do when the first connect attempt after scanning is failing.
Right now I do move on to the next one, but maybe we should wait for a few seconds and retry that one.
Also make sure to disable periodical WiFi scan.
I think I will remove that setting as it does seem to cause other issues too.
Posted: 14 Jun 2021, 21:33
by Tebogo
It does not solve the problem. What I did:
1. flash and erase with 4Mb blank bin file. Disconnect and wait 5 min. Read that somewhere as a possible solution
2. flash with your latest build. Disconnect and wait 5 min.
3.(@20976) boot, and tried to connect my iPad with AP ESP-Easy. Didn't wanted to connect ;-(
4. entered in Terminal debug 4
5. (@91579) connect my MacBook with the AP ESP-Easy.
6. open browser, open 192.168.4.1/advanced, and disable periodical WiFi scan.
7. (@147442) configured NTP and "Submit"
8. changed to 192.168.4.1/setup, and selected my best AP, and entered Wifi-Key
9. no connection, tried again.
10. (@328794) changed to 192/168.4.1/config. checked SSID and entered again my Wifi-key.
11. (@349488)After still no connection, hit in 192.168.4.1/tools the REBOOT -button
12.waited till (@46349)
Free RAM:32184
284 : Info : INIT : Cold Boot - Restart Reason: External System
286 : Info : FS : Mounting…
6482 : Info : FS : Mount successful, used 0 bytes of 957314
RESET: Resetting factory defaults… using default settings
RESET: Warm boot, reset count: 0
RESET: formatting…
RESET: formatting done…
15681 : Info : SaveToFile: free stack: 3504
15740 : Info : FILE : Saved config.dat offset: 28672 size: 820
15741 : Info : SaveToFile: free stack after: 3504
15742 : Info : SaveToFile: free stack: 3568
15812 : Info : FILE : Saved config.dat offset: 0 size: 1296
15813 : Info : SaveToFile: free stack after: 3568
15814 : Info : SaveToFile: free stack: 3408
15847 : Info : FILE : Saved security.dat offset: 0 size: 593
15847 : Info : SaveToFile: free stack after: 3408
15850 : Info : SaveToFile: free stack: 3072
15860 : Info : FILE : Saved security.dat offset: 1024 size: 128
15860 : Info : SaveToFile: free stack after: 3072
RESET: Successful, rebooting. (you might need to press the reset button if you’ve just flashed the firmware)
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x4010f000, len 3584, room 16
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
ªU75 : Info :
INIT : Booting version: ‘bugfix/wifi_not_reconnect_56c4ca1’ (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
76 : Info : INIT : Free RAM:32184
77 : Info : INIT : Soft Reboot #1 Last Action before Reboot: Intended Reboot: ResetFactory Last systime: 16 - Restart Reason: Software/System restart
79 : Info : FS : Mounting…
104 : Info : FS : Mount successful, used 75802 bytes of 957314
124 : Info : CRC : SecuritySettings CRC …OK
128 : Info : WiFi : Start network scan all channels
2318 : Info : WiFi : Scan finished, found: 8
2321 : Info : WiFi : Start network scan all channels
2430 : Info : INIT : Free RAM:27576
2431 : Info : INIT : I2C
2431 : Info : INIT : SPI not enabled
2532 : Info : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
2538 : Info : Webserver: start
2539 : Info : Time set to 16.000 Time adjusted by 13462.00 msec. Wander: 3.74 msec/second
2541 : Info : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
2543 : Info : Local time: 1970-01-01 00:00:16
3888 : Info : WD : Uptime 0 ConnectFailures 0 FreeMem 20448 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
4584 : Info : WiFi : Scan finished, found: 5
4587 : Error : WIFI : No valid wifi settings
4588 : Info : WIFI : Set WiFi to AP+STA
5626 : Info : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
20976 : Info : AP Mode: Client connected: EE:F2:52:C5:27:92 Connected devices: 1
33889 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 17080 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
deb63886 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 17000 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
ug 4
>debug 4
Ok
add 2
aid 2
station: 3c:22:fb:0f:a1:70 join, AID = 2
91579 : Info : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 2
93887 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 15920 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
station: ee:f2:52:c5:27:92 leave, AID = 1
rm 1
94763 : Info : AP Mode: Client disconnected: EE:F2:52:C5:27:92 Connected devices: 1
94776 : Debug : LoopStats: shortestLoop: 10308 longestLoop: 1053884 avgLoopDuration: 10874.39 loopCounterMax: 2910 loopCounterLast: 2756
94777 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 8381/5569/6/31.89
123880 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 14720 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
128650 : Debug : LoopStats: shortestLoop: 10308 longestLoop: 4298567 avgLoopDuration: 15081.51 loopCounterMax: 2910 loopCounterLast: 2244
128651 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 2241/1500/6/23.42
147442 : Info : Webserver args: 0: ‘usentp’ length: 2 1: ‘ntphost’ length: 13 2: ‘dststartweek’ length: 1 3: ‘dststartdow’ length: 1 4: ‘dststartmonth’ length: 1 5: ‘dststarthour’ length: 1 6: ‘dstendweek’ length: 1 7: ‘dstenddow’ length: 1 8: ‘dstendmonth’ length: 2 9: ‘dstendhour’ length: 1 10: ‘timezone’ length: 1 11: ‘latitude’ length: 8 12: ‘longitude’ length: 8 13: ‘syslogip’ length: 0 14: ‘syslogport’ length: 3 15: ‘syslog_log_level’ length: 1 16: ‘syslogfacility’ length: 1 17: ‘serial_log_level’ length: 1 18: ‘web_log_level’ length: 1 19: ‘useserial’ length: 2 20: ‘baudrate’ length: 6 21: ‘udpport’ length: 1 22: ‘webport’ length: 2 23: ‘ip’ length: 1 24: ‘wdi2caddress’ length: 1 25: ‘wireclockstretchlimit’ length: 1 26: ‘connection_failure_threshold’ length: 1 27: ‘max_wifi_tx_power’ length: 5 28: ‘wifi_sensitivity_margin’ length: 1 29: ‘extra_wifi_scan_loops’ length: 1 30: ‘edit’ length: 1 31: ‘plain’ length: 494
147449 : Info : SaveToFile: free stack: 3456
147525 : Info : FILE : Saved config.dat offset: 0 size: 1296
147526 : Info : SaveToFile: free stack after: 3456
147528 : Info : SaveToFile: free stack: 2960
147538 : Info : FILE : Saved security.dat offset: 1024 size: 128
147540 : Info : SaveToFile: free stack after: 2960
147542 : Debug : WiFi : Set TX power to 0dBm sensitivity: -69dBm
153889 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 13656 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
154772 : Debug : LoopStats: shortestLoop: 10308 longestLoop: 4298567 avgLoopDuration: 11209.75 loopCounterMax: 2910 loopCounterLast: 2328
154773 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 2327/1549/6/33.26
159743 : Info : WiFi : Start network scan all channelsscandone
161930 : Info : WiFi : Scan finished, found: 7
161932 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:3 (-70dBm) WPA2/PSK
161933 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-72dBm) WPA2/PSK
161934 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:6 (-77dBm) WPA2/PSK
161935 : Debug : WiFi : Scan result: Broom 18:83:BF:BC:75:8A Ch:8 (-91dBm) WPA2/PSK
161936 : Debug : WiFi : Scan result: #Hidden# 36:23:03:13:49:8D Ch:1 (-71dBm) WPA2/PSK
161938 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-62dBm) WPA2/PSK
161939 : Debug : WiFi : Scan result: #Hidden# 36:23:03:39:C4:5C Ch:10 (-59dBm) WPA2/PSK
183881 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 15048 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
184776 : Debug : LoopStats: shortestLoop: 10308 longestLoop: 4298567 avgLoopDuration: 12887.13 loopCounterMax: 2910 loopCounterLast: 2326
184777 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 2325/1541/6/27.11
185362 : Info : SaveToFile: free stack: 3456
185431 : Info : FILE : Saved config.dat offset: 0 size: 1296
185432 : Info : SaveToFile: free stack after: 3456
185433 : Info : SaveToFile: free stack: 3296
185466 : Info : FILE : Saved security.dat offset: 0 size: 593
185467 : Info : SaveToFile: free stack after: 3296
185469 : Info : SaveToFile: free stack: 2960
185479 : Info : FILE : Saved security.dat offset: 1024 size: 128
185480 : Info : SaveToFile: free stack after: 2960
185482 : Info : WIFI : Credentials Changed, retry connection. SSID: Linksys Velop WHW03 V2
185484 : Info : WiFi : Best AP candscandone
switch to channel 10
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 3
cnt
dhcp client start…
185486 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-62dBm) WPA2/PSK attempt #0
185489 : Debug : WiFi : Set TX power to 13dBm sensitivity: -69dBm RSSI: -62dBm
185493 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
190682 : Debug : WIFI : Entering processConnect()
190684 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 10 Duration: 3232 ms
190685 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
190721 : Debug : WIFI : Entering processGotIP()
190723 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 2000 ms
190736 : Info : SaveToFile: free stack: 3216
190747 : Info : FILE : Saved security.dat offset: 1024 size: 128
190748 : Info : SaveToFile: free stack after: 3216
190751 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
190752 : Debug : WiFi : WiFi services initialized
190754 : Info : firstLoopConnectionsEstablished
190770 : Debug More : NTP : NTP host ntp.xs4all.nl (194.109.6.2) queried
190793 : Info : NTP : NTP replied: delay 21 mSec Accuracy increased by 0.329 seconds
190795 : Info : Time set to 1623697347.329
190797 : Info : Current Time Zone: STD time start: 2021-10-31 03:00:00 offset: 0 min
190800 : Info : Local time: 2021-06-14 19:02:27
state: 5 -> 0 (1)
rm 0
199058 : Debug : WIFI : Entering processDisconnect()
199160 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
199160 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
199161 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_IDLE
213894 : Info : WD : Uptime 4 ConnectFailures 0 FreeMem 14536 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
214786 : Debug : LoopStats: shortestLoop: 729 longestLoop: 5402515 avgLoopDuration: 2546.01 loopCounterMax: 41152 loopCounterLast: 11748
214787 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 11747/1558/6/41.27
216313 : Info : WiFi : Start network scan all channelsscandone
218499 : Info : WiFi : Scan finished, found: 8
218501 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-71dBm) WPA2/PSK
218502 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:3 (-70dBm) WPA2/PSK
218503 : Debug : WiFi : Scan result: #Hidden# 36:23:03:39:CE:ED Ch:3 (-70dBm) WPA2/PSK
218505 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-60dBm) WPA2/PSK
218506 : Debug : WiFi : Scan result: #Hidden# 36:23:03:39:C3:A3 Ch:6 (-77dBm) WPA2/PSK
218507 : Debug : WiFi : Scan result: Broom 18:83:BF:BC:75:8A Ch:8 (-90dBm) WPA2/PSK
218508 : Debug : WiFi : Scan result: #Hidden# 36:23:03:39:C4:5C Ch:10 (-58dBm) WPA2/PSK
218510 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:9 (-74dBm) WPA2/PSK
235245 : Info : SaveToFile: free stack: 3456
235342 : Info : FILE : Saved config.dat offset: 0 size: 1296
235343 : Info : SaveToFile: free stack after: 3456
235345 : Info : SaveToFile: free stack: 2960
235355 : Info : FILE : Saved security.dat offset: 1024 size: 128
235356 : Info : SaveToFile: free stack after: 2960
235358 : Debug : WiFi : Set TX power to 0dBm sensitivity: -69dBm
235359 : Info : WIFI : Credentials Changed, retry connection. SSID: Linksys Velop WHW03 V2
235362scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 3
cnt
dhcp client start…
: Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-60dBm) WPA2/PSK
235363 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-60dBm) WPA2/PSK attempt #0
235366 : Debug : WiFi : Set TX power to 11dBm sensitivity: -69dBm RSSI: -60dBm
235370 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
236450 : Debug : WIFI : Entering processConnect()
236452 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 10 Duration: 1003 ms
236453 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
238408 : Debug : WIFI : Entering processGotIP()
238409 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 2032 ms
238421 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
238422 : Debug : WiFi : WiFi services initialized
238978 : Debug More : NTP : NTP host ntp.xs4all.nl (194.109.6.2) queried
239011 : Info : NTP : NTP replied: delay 30 mSec Accuracy increased by 0.551 seconds
239013 : Info : Time set to 1623697395.551 Time adjusted by 41.33 msec. Wander: 0.01 msec/second
239016 : Info : Local time: 2021-06-14 19:03:15
243880 : Info : WD : Uptime 4 ConnectFailures 0 FreeMem 14680 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
244769 : Debug : LoopStats: shortestLoop: 717 longestLoop: 5402515 avgLoopDuration: 3126.42 loopCounterMax: 41841 loopCounterLast: 9567
244769 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 9565/1646/6/52.54
state: 5 -> 0 (1)
rm 0
247494 : Debug : WIFI : Entering processDisconnect()
247595 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 11 s
247596 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
247597 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_IDLE
260752 : Info : WiFi : Start network scan all channelsscandone
262939 : Info : WiFi : Scan finished, found: 8
262940 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-70dBm) WPA2/PSK
262941 : Debug : WiFi : Scan result: #Hidden# 36:23:03:13:49:8D Ch:1 (-71dBm) WPA2/PSK
262943 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:3 (-71dBm) WPA2/PSK
262944 : Debug : WiFi : Scan result: #Hidden# 36:23:03:39:CE:ED Ch:3 (-69dBm) WPA2/PSK
262945 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-58dBm) WPA2/PSK
262947 : Debug : WiFi : Scan result: #Hidden# 36:23:03:39:C3:A3 Ch:6 (-76dBm) WPA2/PSK
262948 : Debug : WiFi : Scan result: #Hidden# 36:23:03:39:C4:5C Ch:10 (-59dBm) WPA2/PSK
262949 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:9 (-75dBm) WPA2/PSK
262951 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-58dBm) WPA2/PSK
273887 : Info : WD : Uptime 5 ConnectFailures 0 FreeMem 15104 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
274775 : Debug : LoopStats: shortestLoop: 717 longestLoop: 5402515 avgLoopDuration: 5408.86 loopCounterMax: 41841 loopCounterLast: 5537
274776 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 5536/1661/6/33.91
277796 : Info : SaveToFile: free stack: 3456
277866 : Info : FILE : Saved config.dat offset: 0 size: 1296
277867 : Info : SaveToFile: free stack after: 3456
277869 : Info : SaveToFile: free stack: 2960
277879 : Info : FILE : Saved security.dat offset: 1024 size: 128
277879 : Info : SaveToFile: free stack after: 2960
277881 : Debug : WiFi : Set TX power to 0dBm sensitivity: -69dBm
277882 : Info : WIFI : Credentials Changed, retry connection. SSID: Linksys Velop WHW03 V2
277885 :scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 3
cnt
277887 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-58dBm) WPA2/PSK attempt #0
277889 : Debug : WiFi : Set TX power to 9dBm sensitivity: -69dBm RSSI: -58dBm
277894 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
278922 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
dhcp client start…
279920 : Debug : WIFI : Entering processConnect()
279922 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 10 Duration: 2032 ms
279922 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
279969 : Debug : WIFI : Entering processGotIP()
279971 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 46 ms
279982 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
279983 : Debug : WiFi : WiFi services initialized
280561 : Debug More : NTP : NTP host ntp.xs4all.nl (194.109.6.2) queried
280594 : Info : NTP : NTP replied: delay 30 mSec Accuracy increased by 0.134 seconds
280595 : Info : Time set to 1623697437.134 Time adjusted by 35.51 msec. Wander: 0.01 msec/second
280598 : Info : Local time: 2021-06-14 19:03:57
state: 5 -> 0 (1)
rm 0
288044 : Debug : WIFI : Entering processDisconnect()
288145 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8123 ms
288146 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
288147 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_IDLE
288372 : Debug : HTML : Request file /wpad.dat
288400 : Debug : HTML : Request file /wpad.dat
301792 : Info : WiFi : Start network scan all channelsscandone
303979 : Info : WiFi : Scan finished, found: 6
303981 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-60dBm) WPA2/PSK
303982 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:3 (-70dBm) WPA2/PSK
303983 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:6 (-77dBm) WPA2/PSK
303985 : Debug : WiFi : Scan result: #Hidden# 36:23:03:39:C4:5C Ch:10 (-61dBm) WPA2/PSK
303986 : Debug : WiFi : Scan result: Broom 18:83:BF:BC:75:8A Ch:8 (-94dBm) WPA2/PSK
303987 : Debug : WiFi : Scan result: #Hidden# 36:23:03:AE:5D:83 Ch:9 (-74dBm) WPA2/PSK
303989 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-60dBm) WPA2/PSK
304535 : Info : WD : Uptime 5 ConnectFailures 0 FreeMem 15232 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
304779 : Debug : LoopStats: shortestLoop: 705 longestLoop: 5402515 avgLoopDuration: 2593.50 loopCounterMax: 42553 loopCounterLast: 11531
304779 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 11527/1640/6/50.34
308672 : Debug : HTML : Request file /index.htm.gz
308700 : Debug : HTML : Request file /index.htm
309680 : Debug : HTML : Request file /proxy-safebrowsing.googleapis.com:443
309681 : Debug : HTML : Request file /proxy-safebrowsing.googleapis.com:443
328794 : Info : Webserver args: 0: ‘name’ length: 8 1: ‘unit’ length: 1 2: ‘appendunittohostname’ length: 2 3: ‘password’ length: 0 4: ‘ssid’ length: 22 5: ‘key’ length: 10 6: ‘ssid2’ length: 0 7: ‘key2’ length: 0 8: ‘apkey’ length: 5 9: ‘ipblocklevel’ length: 1 10: ‘iprangelow’ length: 0 11: ‘iprangehigh’ length: 0 12: ‘espip’ length: 0 13: ‘espgateway’ length: 0 14: ‘espsubnet’ length: 0 15: ‘espdns’ length: 0 16: ‘awaketime’ length: 1 17: ‘delay’ length: 2 18: ‘plain’ length: 221
328797 : Info : SaveToFile: free stack: 3424
328867 : Info : FILE : Saved config.dat offset: 0 size: 1296
328869 : Info : SaveToFile: free stack after: 3424
328870 : Info : SaveToFile: free stack: 3264
328903 : Info : FILE : Saved security.dat offset: 0 size: 593
328904 : Info : SaveToFile: free stack after: 3264
328907 : Info : SaveToFile: free stack: 2928
328917 : Info : FILE : Saved security.dat offset: 1024 size: 128
328918 : Info : SaveToFile: free stack after: 2928
328920 : Debug : WiFi : Set TX power to 0dBm sensitivity: -69dBm
329092 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-60dBm) WPA2/PSK
329094 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-60dBm) WPA2/PSK attempt #0
329097 : Debug : WiFi : Set TX power to 11dBm sensitivity: -69dBm RSSI: -60dBm
329102 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
329103 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 3
cnt
dhcp client start…
330831 : Debug : WIFI : Entering processConnect()
330832 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 10 Duration: 1734 ms
330833 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
332426 : Debug : WIFI : Entering processGotIP()
332428 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1594 ms
332439 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
332440 : Debug : WiFi : WiFi services initialized
332562 : Debug More : NTP : NTP host ntp.xs4all.nl (194.109.6.2) queried
332605 : Info : NTP : NTP replied: delay 40 mSec Accuracy increased by 0.137 seconds
332607 : Info : Time set to 1623697489.137 Time adjusted by 38.45 msec. Wander: 0.01 msec/second
332610 : Info : Local time: 2021-06-14 19:04:49
333879 : Info : WD : Uptime 6 ConnectFailures 0 FreeMem 14032 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
334768 : Debug : LoopStats: shortestLoop: 705 longestLoop: 5402515 avgLoopDuration: 5885.89 loopCounterMax: 42553 loopCounterLast: 5089
334769 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 5085/1699/6/34.08
state: 5 -> 0 (1)
rm 0
341087 : Debug : WIFI : Entering processDisconnect()
341188 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
341189 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
341190 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_IDLE
349335 : Debug : HTML : Request file /index.htm.gz
349362 : Debug : HTML : Request file /index.htm
349488 : Info : Webserver args: 0: ‘cmd’ length: 6
349488 : Info : : Rebooting…
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
ªU74 : Info :
77 : Info : INIT : Soft Reboot #2 Last Action before Reboot: Intended Reboot: CommandReboot Last systime: 1623697506 - Restart Reason: Software/System restart
153 : Info : FS : Success garbage collection
203 : Info : FS : Success garbage collection
269 : Info : FS : Success garbage collection
281 : Info : CRC : SecuritySettings CRC …OK
285 : Info : WiFi : Start network scan all channels
398 : Info : INIT : Free RAM:28112
399 : Info : INIT : I2C
400 : Info : INIT : SPI not enabled
499 : Info : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
505 : Info : Webserver: start
506 : Info : Time set to 1623697506.000
508 : Info : Current Time Zone: STD time start: 2021-10-31 03:00:00 offset: 0 min
510 : Info : Local time: 2021-06-14 19:05:06
1851 : Info : WD : Uptime 0 ConnectFailures 0 FreeMem 21128 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
scandone
2550 : Info : WiFi : Scan finished, found: 5
2551 : Debug : WiFi : Scan result: #Hidden# 36:23:03:39:C3:A3 Ch:6 (-77dBm) WPA2/PSK
2552 : Debug : WiFi : Scan result: Broom 18:83:BF:BC:75:8A Ch:8 (-91dBm) WPA2/PSK
2553 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-69dBm) WPA2/PSK
2555 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-58dBm) WPA2/PSK
2556 : Debug : WiFi : Scan result: #Hidden# 36:23:03:13:49:8D Ch:1 (-69dBm) WPA2/PSK
2560 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-58dBm) WPA2/PSK
2562 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-58dBm) WPA2/PSK attempt #0
2565 : Debug : WiFi : Set TX power to 9dBm sensitivity: -69dBm RSSI: -58dBm
2568 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
2570 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 3
cnt
dhcp client start…
3659 : Debug : LoopStats: shortestLoop: 10335 longestLoop: 900285 avgLoopDuration: 16098.03 loopCounterMax: 2902 loopCounterLast: 193
3660 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 191/135/6/16.21
3671 : Debug : WIFI : Entering processConnect()
3672 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 10 Duration: 1092 ms
3673 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
5700 : Debug : WIFI : Entering processGotIP()
5701 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 2037 ms
5713 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
5714 : Debug : WiFi : WiFi services initialized
5716 : Info : firstLoopConnectionsEstablished
6303 : Debug More : NTP : NTP host ntp.xs4all.nl (194.109.6.2) queried
6326 : Info : NTP : NTP replied: delay 20 mSec Accuracy increased by 0.554 seconds
6327 : Info : Time set to 1623697512.554 Time adjusted by 770.75 msec. Wander: 0.21 msec/second
6330 : Info : Local time: 2021-06-14 19:05:12
pm open,type:2 0
state: 5 -> 0 (1)
rm 0
pm close 7
14132 : Debug : WIFI : Entering processDisconnect()
14233 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
14234 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
14235 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 3
cnt
dhcp client start…
15097 : Debug : WIFI : Entering processConnect()
15099 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 10 Duration: 12526 ms
15099 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
15132 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-69dBm) WPA2/PSK attempt #1
15138 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
15139 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: -62 status: STATION_CONNECTING
scandone
state: 5 -> 2 (b0)
state: 5 -> 0 (2)
reconnect
17362 : Debug : WIFI : Entering processDisconnect()
17463 : Info : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 2227 ms
17565 : Info : WIFI : Set WiFi to OFFscandone
del if0
usl
mode : null
fpm open,type:2 0
17781 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
17783 : Info : WiFi : Best AP candidate: Linksys Velop WHW0fpm close 3
17784 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-58dBmode : sta(f4:cf:a2:ed:b5:ed)
add if0
17888 : Info : WIFI : Set WiFi to STA
17895 : Debug : WiFi : Set TX power to 0dBm sensitivity: -69dBm
17997 : Debug : WiFi : Set TX power to 9dBm sensitivity: -69dBm RSSI: -58dBm
18001 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
18015 : Info : WIFI : Conscandone
necting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-69dBm) WPA2/PSK attempt #3
18021 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
dhcp client start…
19203 : Debug : WIFI : Entering processConnect()
19204 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 1 Duration: 1169 ms
19205 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
21050 : Debug : WIFI : Entering processGotIP()
21051 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1858 ms
21063 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
21064 : Debug : WiFi : WiFi services initialized
21291 : Debug More : NTP : NTP host ntp.xs4all.nl (194.109.6.2) queried
21344 : Info : NTP : NTP replied: delay 51 mSec Accuracy increased by 0.581 seconds
21346 : Info : Time set to 1623697527.581 Time adjusted by 64.95 msec. Wander: 0.02 msec/second
21349 : Info : Local time: 2021-06-14 19:05:27
pm open,type:2 0
state: 5 -> 0 (1)
rm 0
pm close 7
29442 : Debug : WIFI : Entering processDisconnect()
29544 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
29544 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
29545 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_IDLE
30454 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-58dBm) WPA2/PSK
30455 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-58dBm) WPA2/PSK attempt #4
30460 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
30461 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 3
cnt
dhcp client start…
31468 : Debug : WIFI : Entering processConnect()
31469 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 10 Duration: 999 ms
31470 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
31856 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 19744 WiFiStatus WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
32749 : Debug : LoopStats: shortestLoop: 250 longestLoop: 905601 avgLoopDuration: 1261.38 loopCounterMax: 120000 loopCounterLast: 22925
32750 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 22920/1697/6/59.32
33039 : Debug : WIFI : Entering processGotIP()
33040 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1576 ms
33052 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
33053 : Debug : WiFi : WiFi services initialized
33291 : Debug More : NTP : NTP host ntp.xs4all.nl (194.109.6.2) queried
33313 : Info : NTP : NTP replied: delay 20 mSec Accuracy increased by 0.543 seconds
33315 : Info : Time set to 1623697539.543 Time adjusted by 18.80 msec. Wander: 0.01 msec/second
33318 : Info : Local time: 2021-06-14 19:05:39
pm open,type:2 0
state: 5 -> 0 (1)
rm 0
pm close 7
41471 : Debug : WIFI : Entering processDisconnect()
41572 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
41572 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
41573 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_IDLE
42472 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-69dBm) WPA2/PSK attempt #5
42478 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
42480 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
dhcp client start…
43659 : Debug : WIFI : Entering processConnect()
43660 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 1 Duration: 1183 ms
43661 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
45521 : Debug : WIFI : Entering processGotIP()
45523 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1862 ms
45535 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
45536 : Debug : WiFi : WiFi services initialized
46291 : Debug More : NTP : NTP host ntp.xs4all.nl (194.109.6.2) queried
46344 : Info : NTP : NTP replied: delay 51 mSec Accuracy increased by 0.580 seconds
46346 : Info : Time set to 1623697552.580 Time adjusted by 62.19 msec. Wander: 0.02 msec/second
46349 : Info : Local time: 2021-06-14 19:05:52
Hope it helps to kill this bug...
Posted: 14 Jun 2021, 21:40
Will have a look at the logs in a minute, but I wonder if the iPad was able to connect before to the ESPEasy AP.
I don't have any apple stuff other than what's in the fruit basket and maybe some old Beatles records.
One other thing that came to mind while I was thinking about this issue....
Do you have the option to setup some small network using 192.168.xxx range?
This really strange suggestion from Reddit keeps going through my head, why it would ever help to set the subnetmask to the same address as the gateway. (or maybe 10.187.1.0 ???)
So maybe it hold some truth, but then in some kind of bug in calculating a subnet.
Posted: 14 Jun 2021, 21:52
One other thing...
What can you configure in your access point?
Do you have a field for Beacon Interval and/or DTIM?
If you do, can you please tell me what those values are?
Can you, from the serial port, start the access point? ("WifiAPMode")
And maybe also connect to it using your phone or something.
The AP will be closed again after 60 seconds if not used, which is even longer than the 10 sec disconnect you're seeing.
The idea behind this is that when running in AP mode, the WiFi radio is always on.
So if the Beacon interval is not 100 (102.4 msec), it may still receive the beacon when AP mode is also on.
A mismatch in Beacon interval and what the ESP expects may also explain why you cannot get any IP traffic (e.g. a ping, or UDP traffic) as the WiFi station (the ESP connected to an AP) can only react on a beacon signal from the AP.
As soon as there is active communication, the WiFi radio will be on all the time, so it can react faster on pings.
This is also the reason why the first ping to a WiFi connected computer/ESP/etc. after some time of inactivity always takes longer to get a reply.
On average this delay is half the beacon interval (thus 50 msec) and if the DTIM is set > 1 it may take a multiple of the beacon interval.
Posted: 14 Jun 2021, 22:05
by Tebogo
TD-er wrote: ↑14 Jun 2021, 21:40
Yes, normally the iPad does connect. After connecting It opens automatically the webpage 192.168.4.1/setup. You select your wifi, enter the password and it connects.
I already did test that with my Fritz!Box. Didn't resolve the problem...
Posted: 14 Jun 2021, 22:26
by Tebogo
TD-er wrote: ↑14 Jun 2021, 21:52
One other thing...
Nothing special, see pictures:
Posted: 14 Jun 2021, 22:28
by Tebogo
You mean, connect to iPhone/iPad that is set as Hotspot?
Posted: 14 Jun 2021, 22:51
by Tebogo
Entered @146161 the command WifiAPMode. no success...
111583 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
111585 : Info : WIFI : Connecting Linksfpm close 3
ys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:9 (-75dBm) WPA2/PSK attempt #15
111688 : Info : WIFI : Set WiFi to STAmode : sta(f4:cf:a2:ed:b5:ed)
add if0
111693 : Debug : WiFi : Set TX power to 0dBm sensitivity: -69dBm
111799 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
111813 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:3 (-93dBm) WPA2/PSK attempt #16scandone
111818 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
ap_loss
scandone
114008 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
114020 : Debug : WIFI : Entering processDisconnect()
114121 : Info : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 2194 ms
114223 : Info : WIFI : Set WiFi to OFFdel if0
usl
mode : null
fpm open,type:2 0
114437 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
114440 : Info : WiFi : Best AP candidate: Linksys Velop WHW03fpm close 3
V2 30:23:03:13:49:8D Ch:1 (-66dBm) WPA2/PSK
114441 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-66dBm)mode : sta(f4:cf:a2:ed:b5:ed)
add if0
WPA2/PSK attempt #17
114545 : Info : WIFI : Set WiFi to STA
114653 : Debug : WiFi : Set TX power to 17dBm sensitivity: -69dBm RSSI: -66dBm
114658 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
114659 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATIONscandone
_CONNECTING
114672 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-73dBm) WPA2/PSK attempt #18
114677 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 3
cnt
dhcp client start…
115850 : Debug : WIFI : Entering processConnect()
115852 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 10 Duration: 1176 ms
115852 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
115900 : Debug : WIFI : Entering processGotIP()
115902 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 50 ms
115914 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
115914 : Debug : WiFi : WiFi services initialized
116473 : Debug More : NTP : NTP host ntp.xs4all.nl (194.109.6.2) queried
116496 : Info : NTP : NTP replied: delay 20 mSec Accuracy increased by 0.347 seconds
116497 : Info : Time set to 1623703597.347 Time adjusted by 26.40 msec. Wander: 0.01 msec/second
116500 : Info : Local time: 2021-06-14 20:46:37
121698 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 18744 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
122586 : Debug : LoopStats: shortestLoop: 250 longestLoop: 2975561 avgLoopDuration: 1182.55 loopCounterMax: 120000 loopCounterLast: 25184
122587 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 25174/1752/6/59.96
pm open,type:2 0
WifiAPMode
>WifiAPMode
146161 : Debug : Command: WifiAPMode
146162 : Debug : WifiAPMode
146162 : Debug : Par1: 0 Par2: 0 Par3: 0 Par4: 0 Par5: 0
146163 : Info : Wmode : sta(f4:cf:a2:ed:b5:ed) + softAP(f6:cf:a2:ed:b5:ed)
add if1
pm close 7
dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
bcn 100
bcn 0
del if1
pm open,type:2 0
add if1
pm close 7
bcn 100
147164 : Info : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
Ok
151698 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 16280 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
152586 : Debug : LoopStats: shortestLoop: 250 longestLoop: 2975561 avgLoopDuration: 786.50 loopCounterMax: 120000 loopCounterLast: 37728
152587 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 37727/2064/6/89.33
state: 5 -> 0 (1)
rm 0
155672 : Debug : WIFI : Entering processDisconnect()
155773 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 39 s
155774 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
155775 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_IDLE
156675 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:6 (-75dBm) WPA2/PSK attempt #19
156682 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
156683 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
dhcp client start…
157443 : Debug : WIFI : Entering processConnect()
157445 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 6 Duration: 761 ms
157445 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
159241 : Debug : WIFI : Entering processGotIP()
159242 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 1802 ms
159255 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
159255 : Debug : WiFi : WiFi services initialized
159473 : Debug More : NTP : NTP host ntp.xs4all.nl (194.109.6.2) queried
159506 : Info : NTP : NTP replied: delay 30 mSec Accuracy increased by 0.356 seconds
159508 : Info : Time set to 1623703640.356 Time adjusted by 34.10 msec. Wander: 0.01 msec/second
159511 : Info : Local time: 2021-06-14 20:47:20
state: 5 -> 0 (1)
rm 0
167743 : Debug : WIFI : Entering processDisconnect()
167844 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
167845 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
167845 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_IDLE
168749 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:9 (-75dBm) WPA2/PSK attempt #20
168756 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
168757 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
170953 : Debug : WIFI : Entering processDisconnect()
171054 : Info : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 2196 ms
171156 : Info : WIFI : Set WiFi to OFFbcn 0
del if1
del if0
usl
mode : null
fpm open,type:2 0
171370 : Info : WiFi : Start network scan all channelsfpm close 3
add if0
scandone
173559 : Info : WiFi : Scan finished, found: 6
173560 : Debug : WiFi : Scan result: TP-LINK_4A2C7A 14:CC:20:4A:2C:7A Ch:1 (-93dBm) WPA/WPA2/PSK
173562 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:6 (-75dBm) WPA2/PSK
173563 : Debug : WiFi : Scan result: #Hidden# 36:23:03:39:C3:A3 Ch:6 (-76dBm) WPA2/PSK
173564 : Debug : WiFi : Scan result: #Hidden# 36:23:03:AE:5D:83 Ch:9 (-75dBm) WPA2/PSK
173565 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-73dBm) WPA2/PSK
173566 : Debug : WiFi : Scan result: #Hidden# 36:23:03:39:C4:5C Ch:10 (-73dBm) WPA2/PSK
173568 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-66dBm) WPA2/PSK
173569 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
173571 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-66dBm) WPA2/PSK attempt #21
173576 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
dhcp client start…
175655 : Debug : WIFI : Entering processConnect()
175656 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 1 Duration: 2065 ms
175657 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
175728 : Debug : WIFI : Entering processGotIP()
175729 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 89 ms
175741 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
175742 : Debug : WiFi : WiFi services initialized
176655 : Debug More : NTP : NTP host ntp.xs4all.nl (194.109.6.2) queried
176708 : Info : NTP : NTP replied: delay 51 mSec Accuracy increased by 0.558 seconds
176709 : Info : Time set to 1623703657.558 Time adjusted by 56.46 msec. Wander: 0.02 msec/second
176713 : Info : Local time: 2021-06-14 20:47:37
181698 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 18560 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
182586 : Debug : LoopStats: shortestLoop: 250 longestLoop: 2975561 avgLoopDuration: 1237.40 loopCounterMax: 120000 loopCounterLast: 24081
182587 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 24073/1711/6/58.24
state: 5 -> 0 (1)
rm 0
184019 : Debug : WIFI : Entering processDisconnect()
184120 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8380 ms
184121 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
184122 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_IDLE
185020 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:10 (-73dBm) WPA2/PSK attempt #22
185026 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
185028 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 3
cnt
dhcp client start…
186210 : Debug : WIFI : Entering processConnect()
186211 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C4:5C) Ch: 10 Duration: 1176 ms
186212 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
188216 : Debug : WIFI : Entering processGotIP()
188218 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 2018 ms
188230 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
188230 : Debug : WiFi : WiFi services initialized
188655 : Debug More : NTP : NTP host ntp.xs4all.nl (194.109.6.2) queried
188748 : Info : NTP : NTP replied: delay 91 mSec Accuracy increased by 0.616 seconds
188749 : Info : Time set to 1623703669.616 Time adjusted by 114.32 msec. Wander: 0.03 msec/second
188752 : Info : Local time: 2021-06-14 20:47:49
pm open,type:2 0
state: 5 -> 0 (1)
rm 0
pm close 7
196456 : Debug : WIFI : Entering processDisconnect()
196557 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
196558 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
196558 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_IDLE
197457 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:9 (-75dBm) WPA2/PSK attempt #23
197464 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
197465 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 4
cnt
connected with Linksys Velop WHW03 V2, channel 9
dhcp client start…
197726 : Debug : WIFI : Entering processConnect()
197728 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 9 Duration: 268 ms
197728 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
197775 : Debug : WIFI : Entering processGotIP()
197777 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 48 ms
197789 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
197790 : Debug : WiFi : WiFi services initialized
198655 : Debug More : NTP : NTP host ntp.xs4all.nl (194.109.6.2) queried
198687 : Info : NTP : NTP replied: delay 31 mSec Accuracy increased by 0.543 seconds
198689 : Info : Time set to 1623703679.543 Time adjusted by 23.09 msec. Wander: 0.01 msec/second
198692 : Info : Local time: 2021-06-14 20:47:59
Re: Latest versions crashes my NodeMCU
Posted: 14 Jun 2021, 23:18
by Tebogo
Tebogo wrote: ↑14 Jun 2021, 22:28
Tried that, I see on my iPhone that de ESP stays connected to the iPhone hotspot, but have the same problems...
@206822 I also set WifiAPMode again...
>reset
RESET: Warm boot, reset count: 1
RESET: formatting…
273648 : Info : SaveToFile: free stack: 3232
273708 : Info : FILE : Saved config.dat offset: 28672 size: 820
273709 : Info : SaveToFile: free stack after: 3232
273709 : Info : SaveToFile: free stack: 3296
273780 : Info : FILE : Saved config.dat offset: 0 size: 1296
273781 : Info : SaveToFile: free stack after: 3296
273782 : Info : SaveToFile: free stack: 3136
273815 : Info : FILE : Saved security.dat offset: 0 size: 593
273815 : Info : SaveToFile: free stack after: 3136
273818 : Info : SaveToFile: free stack: 2800
273828 : Info : FILE : Saved security.dat offset: 1024 size: 128
273829 : Info : SaveToFile: free stack after: 2800
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
ªU75 : Info :
77 : Info : INIT : Soft Reboot #2 Last Action before Reboot: Intended Reboot: ResetFactory Last systime: 1623704918 - Restart Reason: Software/System restart
2318 : Info : WiFi : Scan finished, found: 9
2429 : Info : INIT : Free RAM:27440
2533 : Info : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
2539 : Info : Webserver: start
2540 : Info : Time set to 1623704918.000
2541 : Info : Current Time Zone: STD time start: 2021-10-31 03:00:00 offset: 0 min
2544 : Info : Local time: 2021-06-14 21:08:38
3885 : Info : WD : Uptime 0 ConnectFailures 0 FreeMem 20360 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
4582 : Info : WiFi : Scan finished, found: 5
4585 : Error : WIFI : No valid wifi settings
4586 : Info : WIFI : Set WiFi to AP+STA
5576 : Info : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
13575 : Info : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
43253 : Info : AP Mode: Client disconnected: 3C:22:FB:0F:A1:70 Connected devices: 1
43254 : Info : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
43323 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 15504 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
debug 4
>debug 4
Ok
63897 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 15736 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
64781 : Debug : LoopStats: shortestLoop: 10311 longestLoop: 1003637 avgLoopDuration: 11706.40 loopCounterMax: 2909 loopCounterLast: 1830
64782 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 2822/1882/6/29.57
station: 3c:22:fb:0f:a1:70 leave, AID = 1
rm 1
85361 : Info : AP Mode: Client disconnected: 3C:22:FB:0F:A1:70 Connected devices: 0
add 1
aid 1
station: 3c:22:fb:0f:a1:70 join, AID = 1
91612 : Info : AP Mode: Client connected: 3C:22:FB:0F:A1:70 Connected devices: 1
101622 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 14320 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
101634 : Debug : LoopStats: shortestLoop: 10311 longestLoop: 9122627 avgLoopDuration: 14485.71 loopCounterMax: 2909 loopCounterLast: 2542
101635 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 2541/1694/6/23.79
122453 : Info : SaveToFile: free stack: 3456
122526 : Info : FILE : Saved config.dat offset: 0 size: 1296
122526 : Info : SaveToFile: free stack after: 3456
122527 : Info : SaveToFile: free stack: 3296
122560 : Info : FILE : Saved security.dat offset: 0 size: 593
122561 : Info : SaveToFile: free stack after: 3296
122563 : Info : SaveToFile: free stack: 2960
122573 : Info : FILE : Saved security.dat offset: 1024 size: 128
122574 : Info : SaveToFile: free stack after: 2960
122575 : Debug : WiFi : Set TX power to 0dBm sensitivity: -69dBm
122576 : Info : WIFI : Credentials Changed, retry connection. SSID: iPhoneGulikP
122579 : Info : WiFi : Best AP candidate: iPhoneGulikP 22:B3:86:22:B4:E1 Ch:6 (-32dBm) WPA2/PSK
122580 : Info : WIFI : Connecting iPhoneGulikP 22:B3:86:22:B4:E1 Ch:6 (-32dBm) WPA2/PSK attempt #0
122585 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
122684 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
123908 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 15280 WiFiStatus WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
scandone
124784 : Debug : WIFI : Entering processDisconnect()
124885 : Info : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 2202 ms
124987 : Info : WIFI : Set WiFi to OFFstation: 3c:22:fb:0f:a1:70 leave, AID = 1
rm 1
bcn 0
del if1
del if0
usl
mode : null
force slp enable,type: 2
fpm open,type:2 0
125203 : Info : WiFi : Start network scan all channelsfpm close 3
add if0
scandone
127392 : Info : WiFi : Scan finished, found: 7
127394 : Debug : WiFi : Scan result: TP-LINK_4A2C7A 14:CC:20:4A:2C:7A Ch:1 (-94dBm) WPA/WPA2/PSK
127395 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:1 (-72dBm) WPA2/PSK
127396 : Debug : WiFi : Scan result: #Hidden# 36:23:03:13:49:8D Ch:1 (-71dBm) WPA2/PSK
127397 : Debug : WiFi : Scan result: iPhoneGulikP EE:3D:5F:19:08:58 Ch:6 (-28dBm) WPA2/PSK
127399 : Debug : WiFi : Scan result: #Hidden# 36:23:03:39:C3:A3 Ch:6 (-72dBm) WPA2/PSK
127400 : Debug : WiFi : Scan result: #Hidden# 36:23:03:AE:5D:83 Ch:9 (-86dBm) WPA2/PSK
127401 : Debug : WiFi : Scan result: #Hidden# 36:23:03:39:C4:5C Ch:10 (-82dBm) WPA2/PSK
127403 : Info : WiFi : Best AP candidate:scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
127404 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
127406 : Info : WIFI : Connecting iPhoneGulikP EE:3D:5F:19:08:58 Ch:6 (-28dBm) WPA2/PSK attempt #1
127410 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
127444 : Debug : LoopStats: shortestLoop: 10311 longestLoop: 9122627 avgLoopDuration: 23089.93 loopCounterMax: 2909 loopCounterLast: 1116
127445 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 1108/772/6/38.01
pm open,type:2 0
state: 5 -> 0 (2)
rm 0
pm close 7
138366 : Debug : WIFI : Entering processDisconnect()
138467 : Info : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 10 s
138468 : Info : WIFI : Arduino wifi status: WL_CONNECT_FAILED 4 ESPeasy internal wifi status: DISCONNECTED
138469 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_WRONG_PASSWORD
139367 : Info : WIFI : Connecting iPhoneGulikP 22:B3:86:22:B4:E1 Ch:6 (-32dBm) WPA2/PSK attempt #2
139372 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
139373 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
141572 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
141584 : Debug : WIFI : Entering processDisconnect()
141685 : Info : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 2195 ms
141786 : Info : WIFI : Set WiFi to OFFdel if0
usl
mode : null
fpm open,type:2 0
142001 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
142003 : Info : WiFi : Best AP candidate: iPhoneGulikP EE:3Dfpm close 3
142005 : Info : WIFI : Connecting iPhoneGulikP EE:3D:5F:19:08:58 Ch:6 (-28dBm) WPA2/PSK attempt #mode : sta(f4:cf:a2:ed:b5:ed)
add if0
sleep enable,type: 2
3
142108 : Info : WIFI : Set WiFi to STA
142219 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
142221 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
state: 0 -> 2 (b0)
143162 : Info : WIFI : Set WiFi to AP+STAmode : sta(f4:cf:a2:ed:b5:ed) + softAP(f6:cf:a2:ed:b5:ed)
add if1
bcn 100
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
143272 : Info : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
state: 5 -> 0 (2)
rm 0
153189 : Debug : WIFI : Entering processDisconnect()
153290 : Info : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 11 s
153291 : Info : WIFI : Arduino wifi status: WL_CONNECT_FAILED 4 ESPeasy internal wifi status: DISCONNECTED
153292 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_WRONG_PASSWORD
153890 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 16272 WiFiStatus WL_CONNECT_FAILED 4 ESPeasy internal wifi status: DISCONNECTED
153891 : Info : WiFi : Start network scan all channels
153895 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_IDLE
154775 : Debug : LoopStats: shortestLoop: 10305 longestLoop: 9122627 avgLoopDuration: 16038.52 loopCounterMax: 2911 loopCounterLast: 1703
154776 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 1677/1305/6/14.13
scandone
156093 : Info : WiFi : Scan finished, found: 4
156094 : Debug : WiFi : Scan result: #Hidden# 36:23:03:39:C3:A3 Ch:6 (-71dBm) WPA2/PSK
156096 : Debug : WiFi : Scan result: iPhoneGulikP EE:3D:5F:19:08:58 Ch:6 (-44dBm) WPA2/PSK
156097 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:6 (-71dBm) WPA2/PSK
156098 : Debug : WiFi : Scan result: #Hidden# 36:23:03:AE:5D:83 Ch:9 (-84dBm) WPA2/PSK
156099 : Info : WiFi : Best AP candidate: iPhoneGulikP 22:B3:86:22:B4:E1 Ch:6 (-32dBm) WPA2/PSK
156103 : Info : WIFI : Connecting iPhoneGulikP 22:B3:86:22:B4:E1 Ch:6 (-32dBm) WPA2/PSK attempt #4
156108 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
156110 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
158308 : Debug : WIFI : Entering processDisconnect()
158409 : Info : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 2195 ms
158511 : Info : WIFI : Set WiFi to OFFbcn 0
del if1
del if0
usl
mode : null
fpm open,type:2 0
158726 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
158728 : Info : WIFI : Connecting iPhonefpm close 3
GulikP EE:3D:5F:19:08:58 Ch:6 (-44dBm) WPA2/PSK attempt #5
158832 : Info : WIFI : Set WiFi to STAmode : sta(f4:cf:a2:ed:b5:ed)
add if0
158940 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
pm open,type:2 0
state: 5 -> 0 (2)
rm 0
pm close 7
169899 : Debug : WIFI : Entering processDisconnect()
170000 : Info : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 11 s
170001 : Info : WIFI : Arduino wifi status: WL_CONNECT_FAILED 4 ESPeasy internal wifi status: DISCONNECTED
170002 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_WRONG_PASSWORD
170900 : Info : WiFi : Best AP candidate: iPhoneGulikP 22:B3:86:22:B4:E1 Ch:6 (-32dBm) WPA2/PSK
170902 : Info : WIFI : Connecting iPhoneGulikP 22:B3:86:22:B4:E1 Ch:6 (-32dBm) WPA2/PSK attempt #6
170907 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
170909 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
173099 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
173111 : Debug : WIFI : Entering processDisconnect()
173212 : Info : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 2196 ms
173313 : Info : WIFI : Set WiFi to OFFdel if0
usl
mode : null
fpm open,type:2 0
173528 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
173530 : Info : WIFI : Connecting iPhonfpm close 3
eGulikP EE:3D:5F:19:08:58 Ch:6 (-44dBm) WPA2/PSK attempt #7
173634 : Info : WIFI : Set WiFi to STAmode : sta(f4:cf:a2:ed:b5:ed)
add if0
173742 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
173743 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
176111 : Info : WIFI : Set WiFi to AP+STAmode : sta(f4:cf:a2:ed:b5:ed) + softAP(f6:cf:a2:ed:b5:ed)
add if1
bcn 100
bcn 0
del if1
pm open,type:2 0
add if1
pm close 7
bcn 100
177104 : Info : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
183895 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 16528 WiFiStatus WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
184774 : Debug : LoopStats: shortestLoop: 10305 longestLoop: 9122627 avgLoopDuration: 13817.79 loopCounterMax: 2911 loopCounterLast: 2169
184775 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 2156/1505/6/22.55
state: 5 -> 0 (2)
rm 0
184821 : Debug : WIFI : Entering processDisconnect()
184922 : Info : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 11 s
184923 : Info : WIFI : Arduino wifi status: WL_CONNECT_FAILED 4 ESPeasy internal wifi status: DISCONNECTED
184924 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_WRONG_PASSWORD
185826 : Info : WiFi : Best AP candidate: iPhoneGulikP 22:B3:86:22:B4:E1 Ch:6 (-32dBm) WPA2/PSK
185828 : Info : WIFI : Connecting iPhoneGulikP 22:B3:86:22:B4:E1 Ch:6 (-32dBm) WPA2/PSK attempt #8
185833 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
185835 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
188032 : Debug : WIFI : Entering processDisconnect()
188133 : Info : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 2196 ms
188235 : Info : WIFI : Set WiFi to OFFbcn 0
del if1
del if0
usl
mode : null
fpm open,type:2 0
188450 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
188452 : Info : WIFI : Connecting iPhonefpm close 3
GulikP EE:3D:5F:19:08:58 Ch:6 (-44dBm) WPA2/PSK attempt #9
188556 : Info : WIFI : Set WiFi to STAmode : sta(f4:cf:a2:ed:b5:ed)
add if0
188664 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
connected with iPhoneGulikP, channel 6
dhcp client start…
190118 : Debug : WIFI : Entering processConnect()
190119 : Info : WIFI : Connected! AP: iPhoneGulikP (EE:3D:5F:19:08:58) Ch: 6 Duration: 1663 ms
190120 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
bcn_timout,ap_probe_send_start
ap_probe_send over, rest wifi status to disassoc
state: 5 -> 0 (1)
rm 0
198601 : Debug : WIFI : Entering processDisconnect()
198702 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 8484 ms
198703 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
198704 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_IDLE
199605 : Info : WiFi : Best AP candidate: iPhoneGulikP 22:B3:86:22:B4:E1 Ch:6 (-32dBm) WPA2/PSK
199607 : Info : WIFI : Connecting iPhoneGulikP 22:B3:86:22:B4:E1 Ch:6 (-32dBm) WPA2/PSK attempt #10
199612 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
199613 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
201803 : Debug : WIFI : Entering processDisconnect()
201904 : Info : WIFI : Disconnected! Reason: ‘(201) No AP found’ Connected for 2195 ms
202006 : Info : WIFI : Set WiFi to OFFdel if0
usl
mode : null
fpm open,type:2 0
202221 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
202223 : Info : WIFI : Connecting iPhonfpm close 3
eGulikP EE:3D:5F:19:08:58 Ch:6 (-44dBm) WPA2/PSK attempt #11
202326 : Info : WIFI : Set WiFi to STAmode : sta(f4:cf:a2:ed:b5:ed)
add if0
202434 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
dhcp client start…
203447 : Debug : WIFI : Entering processConnect()
203448 : Info : WIFI : Connected! AP: iPhoneGulikP (EE:3D:5F:19:08:58) Ch: 6 Duration: 1221 ms
203449 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
Wifi205828 : Info : WIFI : Set WiFi to AP+STAmode : sta(f4:cf:a2:ed:b5:ed) + softAP(f6:cf:a2:ed:b5:ed)
add if1
bcn 100
APbcn 0
del if1
pm open,type:2 0
add if1
pm close 7
bcn 100
206822 : Info : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
Mode
>WifiMode
209004 : Debug : Command: WifiMode
209005 : Debug : WifiMode
209005 : Debug : Par1: 0 Par2: 0 Par3: 0 Par4: 0 Par5: 0
WiFi Mode:AP+STA
Ok
213879 : Info : WD : Uptime 4 ConnectFailures 0 FreeMem 16064 WiFiStatus WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
214770 : Debug : LoopStats: shortestLoop: 257 longestLoop: 9122627 avgLoopDuration: 443.43 loopCounterMax: 116731 loopCounterLast: 66988
214770 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 66975/1507/6/61.58
state: 5 -> 0 (1)
rm 0
215329 : Debug : WIFI : Entering processDisconnect()
215430 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 11 s
215431 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
215432 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_IDLE
216335 : Info : WiFi : Start network scan all channels
216339 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
216340 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_IDLE
scandone
218537 : Info : WiFi : Scan finished, found: 4
218539 : Debug : WiFi : Scan result: iPhoneGulikP EE:3D:5F:19:08:58 Ch:6 (-27dBm) WPA2/PSK
218540 : Debug : WiFi : Scan result: #Hidden# 36:23:03:AE:5D:83 Ch:9 (-80dBm) WPA2/PSK
218541 : Debug : WiFi : Scan result: #Hidden# 36:23:03:39:C3:A3 Ch:6 (-72dBm) WPA2/PSK
218542 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:6 (-72dBm) WPA2/PSK
218544 : Info : WiFi : Best AP candidate: iPhoneGulikP EE:3D:5F:19:08:58 Ch:6 (-27dBm) WPA2/PSK
218547 : Info : WIFI : Connecting iPhoneGulikP EE:3D:5F:19:08:58 Ch:6 (-27dBm) WPA2/PSK attempt #12
218552 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internalscandone
state: 0 -> 2 (b0)
218553 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTstate: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
ING
dhcp client start…
218701 : Debug : WIFI : Entering processConnect()
218702 : Info : WIFI : Connected! AP: iPhoneGulikP (EE:3D:5F:19:08:58) Ch: 6 Duration: 140 ms
218703 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
ip:172.20.10.8,mask:255.255.255.240,gw:172.20.10.1
218739 : Debug : WIFI : Entering processGotIP()
218740 : Info : WIFI : DHCP IP: 172.20.10.8 (ESP-Easy) GW: 172.20.10.1 SN: 255.255.255.240 duration: 49 ms
218743 : Info : SaveToFile: free stack: 3216
218754 : Info : FILE : Saved security.dat offset: 1024 size: 128
218755 : Info : SaveToFile: free stack after: 3216
218757 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
218758 : Debug : WiFi : WiFi services initialized
218789 : Info : firstLoopConnectionsEstablished
243880 : Info : WD : Uptime 4 ConnectFailures 0 FreeMem 16520 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
243881 : Error : WiFi : Scan not needed, good candidate present
244769 : Debug : LoopStats: shortestLoop: 257 longestLoop: 9122627 avgLoopDuration: 823.26 loopCounterMax: 116731 loopCounterLast: 36085
244770 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 36085/2082/6/82.12
273880 : Info : WD : Uptime 5 ConnectFailures 0 FreeMem 16520 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
273881 : Error : WiFi : Scan not needed, good candidate present
274770 : Debug : LoopStats: shortestLoop: 257 longestLoop: 9122627 avgLoopDuration: 764.08 loopCounterMax: 116731 loopCounterLast: 38842
274771 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 38842/2132/6/88.92
303880 : Info : WD : Uptime 5 ConnectFailures 0 FreeMem 16520 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
303881 : Error : WiFi : Scan not needed, good candidate present
304769 : Debug : LoopStats: shortestLoop: 257 longestLoop: 9122627 avgLoopDuration: 766.28 loopCounterMax: 116731 loopCounterLast: 38732
304770 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 38732/2132/6/88.85
Posted: 14 Jun 2021, 23:22
Nope, I meant to start the AP mode on the ESP, while it is connected to the Linksys. (or your iPhone...)
Posted: 14 Jun 2021, 23:23
by Tebogo
TD-er wrote: ↑14 Jun 2021, 23:22
Oke, did that
Posted: 15 Jun 2021, 10:30
by Tebogo
I found one setting (security WPA2 Personal --> WPA2/WPA-mixed Personal) which I tried. Makes no difference...
See @12398
INIT : Booting version: mega-20210503 (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
76 : Info : INIT : Free RAM:33928
77 : Info : INIT : Warm boot #6 Last Action before Reboot: Background Task Last systime: 6452 - Restart Reason: External System
79 : Info : FS : Mounting…
104 : Info : FS : Mount successful, used 75802 bytes of 957314
125 : Info : CRC : SecuritySettings CRC …OK
128 : Info : WiFi : Start network scan all channels
241 : Info : INIT : Free RAM:29328
243 : Info : INIT : I2C
243 : Info : INIT : SPI not enabled
331 : Info : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
337 : Info : Webserver: start
339 : Info : Time set to 6452.000 Time adjusted by 6451662.00 msec. Wander: 1792.13 msec/second
340 : Info : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
342 : Info : Local time: 1970-01-01 01:47:32
1685 : Info : WD : Uptime 0 ConnectFailures 0 FreeMem 22208 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
1686 : Info : WiFi : Start network scan all channels
2382 : Info : WiFi : Scan finished, found: 5
2385 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:8 (-63dBm) WPA/WPA2/PSK
2387 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:1 (RTC) WPA/WPA2/PSK attempt #0
2391 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
3442 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 1 Duration: 1041 ms
3443 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
12398 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:5 (-76dBm) WPA/WPA2/PSK attempt #1
12403 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
15563 : Info : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 3059 ms
15667 : Info : WIFI : Set WiFi to OFF
15981 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3167 ms
16283 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3582 ms
16585 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3885 ms
16887 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4187 ms
17190 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4489 ms
17492 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4791 ms
17794 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 5094 ms
17795 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
17805 : Info : WiFi : Start network scan all channels
19992 : Info : WiFi : Scan finished, found: 9
19995 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:8 (-63dBm) WPA/WPA2/PSK
19996 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
20007 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
20018 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
20028 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
20039 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
20050 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
20061 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
20073 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:2 (-69dBm) WPA/WPA2/PSK attempt #2
20078 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
21021 : Info : WIFI : Set WiFi to AP+STA
22059 : Info : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
22066 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 2 Duration: 1051 ms
22067 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
22067 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 938 ms
22069 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
22069 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
22123 : Info : firstLoopConnectionsEstablished
30730 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 9503 ms
30731 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
30854 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 2 Duration: 10772 ms
30855 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
31630 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:11 (-70dBm) WPA/WPA2/PSK attempt #3
31635 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
31691 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 18064 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
debu33198 : Info : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1461 msg
33300 : Info : WIFI : Set WiFi to OFF
33614 : Info : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 1567 ms4
33917 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 1984 ms
34219 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2286 ms
34521 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2588 ms
34824 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2891 ms
35126 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3193 ms
35428 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3495 ms
35730 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3797 ms
36033 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4100 ms
36335 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4402 ms
36637 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4704 ms
36940 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 5006 ms
36940 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
36951 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
36962 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
36972 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
36983 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
36994 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
37005 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
37015 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
37026 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
37037 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
37048 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
37058 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
37069 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
>debug 4
Ok
37086 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: Unknown
37640 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:1 (-72dBm) WPA/WPA2/PSK attempt #4fpm close 3
37744 : Info : WIFI : Set WiFi to STAmode : sta(f4:cf:a2:ed:b5:ed)
add if0
37748 : Debug : WiFi : Set TX power to 0dBm sensitivity: -69dBm
37904 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
37905 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 2
cnt
connected with Linksys Velop WHW03 V2, channel 1
dhcp client start…
39747 : Debug : WIFI : Entering processConnect()
39748 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 1 Duration: 2099 ms
39749 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
ip:10.187.1.143,mask:255.255.255.0,gw:10.187.1.254
41770 : Debug : WIFI : Entering processGotIP()
41771 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 2027 ms
41772 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
41773 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
41774 : Debug : WiFi : WiFi services initialized
pm open,type:2 0
state: 5 -> 0 (1)
rm 0
pm close 7
50331 : Debug : WIFI : Entering processDisconnect()scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 2
cnt
50433 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
50434 : Info : WIFI : Arduino wifi status: WL_DISCONNECTE
dhcp client start…
50434 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: -75 status: STATION_CONNECTING
50448 : Debug : WIFI : Entering processConnect()
50450 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:AE:5D:83) Ch: 1 Duration: 12804 ms
50450 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
51332 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:5 (-75dBm) WPA/WPA2/PSK attempt #5
51336 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
51337 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: -76 status: STATION_CONNECTING
scandone
state: 5 -> 2 (b0)
state: 5 -> 2 (6c0)
52782 : Debug : WIFI : Entering processDisconnect()
52883 : Info : WIFI : Disconnected! Reason: ‘(6) Not authed’ Connected for 1448 msstate: 2 -> 0 (0)
52985 : Info : WIFI : Set WiFi to OFFdel if0
usl
mode : null
fpm open,type:2 0
53199 : Debug : WIFI : Entering processDisconnect()
53299 : Info : WIFI : Disconnected! Reason: ‘(202) Auth fail’ Connected for 1551 ms
53501 : Debug : WIFI : Entering processDisconnect()
53602 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 1967 ms
53804 : Debug : WIFI : Entering processDisconnect()
53905 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2270 ms
54107 : Debug : WIFI : Entering processDisconnect()
54207 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2572 ms
54409 : Debug : WIFI : Entering processDisconnect()
54510 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2875 ms
54712 : Debug : WIFI : Entering processDisconnect()
54812 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3177 ms
55014 : Debug : WIFI : Entering processDisconnect()
55115 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3480 ms
55317 : Debug : WIFI : Entering processDisconnect()
55417 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3782 ms
55619 : Debug : WIFI : Entering processDisconnect()
55720 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4085 ms
55922 : Debug : WIFI : Entering processDisconnect()
56023 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4388 ms
56225 : Debug : WIFI : Entering processDisconnect()
56325 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4690 ms
56527 : Debug : WIFI : Entering processDisconnect()
56628 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4993 ms
56830 : Debug : WIFI : Entering processDisconnect()
56930 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 5295 ms
56931 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
56931 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 statfpm close 3
add if0
scandone
us: Unknown
56942 : Info : WiFi : Start network scan all channels
59130 : Info : WiFi : Scan finished, found: 7
59131 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:1 (-70dBm) WPA/WPA2/PSK
59132 : Debug : WiFi : Scan result: #Hidden# 36:23:03:AE:5D:83 Ch:1 (-70dBm) WPA2/PSK
59133 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:5 (-77dBm) WPA/WPA2/PSK
59134 : Debug : WiFi : Scan result: #Hidden# 36:23:03:39:C3:A3 Ch:5 (-77dBm) WPA2/PSK
59136 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:8 (-60dBm) WPA/WPA2/PSK
59137 : Debug : WiFi : Scan result: #Hidden# 36:23:03:39:C4:5C Ch:8 (-61dBm) WPA2/PSK
59138 : Debug : WiFi : Scan result: Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:11 (-70dBm) WPA/WPA2/PSK
59140 : Info : WiFi : Best AP candidate: Linksys Velop WHW03 V2 30:23:03:39:C4:5C Ch:8 (-60dBm) WPA/WPA2/PSK
59141 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
59142 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_IDLE
59153 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
59164 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
59175 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
59186 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
59197 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
59208 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
59219 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
59231 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
59242 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
59253 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
59264 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
59275 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
59288 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:CE:ED Ch:2 (-69dBm) WPA/WPA2/PSK attempt #6
59294 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
59295 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
connected with Linksys Velop WHW03 V2, channel 2
dhcp client start…
60382 : Debug : WIFI : Entering processConnect()
60383 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 2 Duration: 1093 ms
60384 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
61686 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 20248 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: Conn.
62387 : Debug : WIFI : Entering processGotIP()
62389 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 2000 ms
62390 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
62391 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
62391 : Debug : WiFi : WiFi services initialized
62567 : Debug : LoopStats: shortestLoop: 198 longestLoop: 6514901 avgLoopDuration: 1160.07 loopCounterMax: 151515 loopCounterLast: 25680
62567 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 50781/2496/6/35.02
pm open,type:2 0
state: 5 -> 0 (1)
rm 0
pm close 7
70758 : Debug : WIFI : Entering processDisconnect()
70860 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 10 s
70861 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
70861 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
dhcp client start…
70964 : Debug : WIFI : Entering processConnect()
70965 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:CE:ED) Ch: 2 Duration: 11674 ms
70966 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
71759 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:AE:5D:83 Ch:1 (-70dBm) WPA/WPA2/PSK attempt #7
71764 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
71765 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: -76 status: STATION_CONNECTING
scandone
state: 5 -> 2 (b0)
state: 5 -> 0 (2)
reconnect
73712 : Debug : WIFI : Entering processDisconnect()scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add mismatch
aid 2
cnt
dhcp client start…
73814 : Info : WIFI : Disconnected! Reason: ‘(204) Handshake timeout’ Connected for 1949 msstate: 5 -> 0 (0)
rm 0
73916 : Info : WIFI : Set WiFi to OFFdel if0
usl
mode : null
fpm open,type:2 0
74130 : Debug : WIFI : Entering processDisconnect()
74231 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4 ms
74433 : Debug : WIFI : Entering processDisconnect()
74534 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 421 ms
74736 : Debug : WIFI : Entering processDisconnect()
74836 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 723 ms
75038 : Debug : WIFI : Entering processDisconnect()
75139 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 1026 ms
75341 : Debug : WIFI : Entering processDisconnect()
75441 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 1328 ms
75643 : Debug : WIFI : Entering processDisconnect()
75744 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 1631 ms
75946 : Debug : WIFI : Entering processDisconnect()
76047 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 1934 ms
76249 : Debug : WIFI : Entering processDisconnect()
76349 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2236 ms
76551 : Debug : WIFI : Entering processDisconnect()
76652 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2539 ms
76854 : Debug : WIFI : Entering processDisconnect()
76954 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 2841 ms
77156 : Debug : WIFI : Entering processDisconnect()
77257 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3144 msW
77459 : Debug : WIFI : Entering processDisconnect()
77559 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3446 ms
77761 : Debug : WIFI : Entering processDisconnect()i
77862 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 3749 ms
78064 : Debug : WIFI : Entering processDisconnect()f
78165 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4052 ms
78367 : Debug : WIFI : Entering processDisconnect()
78467 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4354 msi
78669 : Debug : WIFI : Entering processDisconnect()
78770 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4657 ms
78972 : Debug : WIFI : Entering processDisconnect()
79072 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 4959 msA
79274 : Debug : WIFI : Entering processDisconnect()
79375 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 5262 ms
79375 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79376 : Debug : WIFI : Entering processConnect()
79378 : Info : Reset WiFi.
79379 : Info : WiFi : WiFiConnected() out of sync: DISCONNECTED RSSI: 31 status: UnPknown
79380 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: Unknown
79393 : Debug : WIFI : Entering processDisconnect()
79495 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 1 m 19 s
79496 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79508 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79519 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79530 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79541 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79552 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79563 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79574 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79584 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79595 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79606 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79617 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79627 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79638 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79649 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79659 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79670 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79681 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
79692 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
Mo80385 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:13:49:8D Ch:11 (-70dBm) WPA/WPA2/PSK attempt #8fpm close 3
80488 : Info : WIFI : Set WiFi to STAmode : sta(f4:cf:a2:ed:b5:ed)
add if0
80647 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
80649 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
destate: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 2
cnt
connected with Linksys Velop WHW03 V2, channel 11
dhcp client start…
81634 : Debug : WIFI : Entering processConnect()
81636 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:13:49:8D) Ch: 11 Duration: 1249 ms
81636 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
81684 : Debug : WIFI : Entering processGotIP()
81685 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 42 ms
81686 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
81687 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
81688 : Debug : WiFi : WiFi services initialized
>Mode
82217 : Debug : Command: Mode
82217 : Debug : Mode
82218 : Debug : Par1: 0 Par2: 0 Par3: 0 Par4: 0 Par5: 0
82219 : Info : Command unknown: Mode
Wifipm open,type:2 0
91677 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 19584 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
AP92566 : Debug : LoopStats: shortestLoop: 198 longestLoop: 6514901 avgLoopDuration: 606.79 loopCounterMax: 151515 loopCounterLast: 49040
92567 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 49036/1507/6/63.42
mode
>WifiAPmode
93753 : Debug : Command: WifiAPmode
93754 : Debug : WifiAPmode
93754 : Debug : Par1: 0 Par2: 0 Par3: 0 Par4: 0 Par5: 0
93755 : Info : WImode : sta(f4:cf:a2:ed:b5:ed) + softAP(f6:cf:a2:ed:b5:ed)
add if1
pm close 7
bcn 100
bcn 0
del if1
pm open,type:2 0
add if1
pm close 7
bcn 100
94836 : Info : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
Ok
state: 5 -> 0 (1)
rm 0
103399 : Debug : WIFI : Entering processDisconnect()
103501 : Info : WIFI : Disconnected! Reason: ‘(200) Beacon timeout’ Connected for 21 s
103502 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
103502 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 2
cnt
dhcp client start…
103616 : Debug : WIFI : Entering processConnect()state: 5 -> 0 (0)
rm 0
103619 : Info : Reset WiFi.del if0
mode : softAP(f6:cf:a2:ed:b5:ed)
103620 : Info : WIFI : Sebcn 0
del if1
usl
mode : null
fpm open,type:2 0
t WiFi to OFF
103736 : Info : WiFi : WiFiConnected() out of sync: DISCONNECTED RSSI: -73 status: STATION_CONNECTING
103737 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: Unknown
103749 : Debug : WIFI : Entering processDisconnect()
103850 : Info : WIFI : Disconnected! Reason: ‘(8) Assoc leave’ Connected for 1 m 43 s
103850 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
104627 : Info : WIFI : Connecting Linksys Velop WHW03 V2 30:23:03:39:C3:A3 Ch:5 (-77dBm) WPA/WPA2/PSK attempt #9fpm close 3
104730 : Info : WIFI : Set WiFi to STAmode : sta(f4:cf:a2:ed:b5:ed)
add if0
104888 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
104890 : Debug : WIFI : Disconnected: WiFi.status() = DISCONNECTED RSSI: 31 status: STATION_CONNECTING
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 2
cnt
connected with Linksys Velop WHW03 V2, channel 5
dhcp client start…
105896 : Debug : WIFI : Entering processConnect()
105897 : Info : WIFI : Connected! AP: Linksys Velop WHW03 V2 (30:23:03:39:C3:A3) Ch: 5 Duration: 1254 ms
105898 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
105955 : Debug : WIFI : Entering processGotIP()
105956 : Info : WIFI : DHCP IP: 10.187.1.143 (ESP-Easy) GW: 10.187.1.254 SN: 255.255.255.0 duration: 65 ms
105958 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
105958 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn. IP
105959 : Debug : WiFi : WiFi services initialized
pm open,type:2 0
121677 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 20040 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
121678 :sl
122567 : Debug : LoopStats: shortestLoop: 198 longestLoop: 6514901 avgLoopDuration: 476.44 loopCounterMax: 151515 loopCounterLast: 62353
122568 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 62351/1933/6/85.53
scandone
usl
151677 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 20040 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
152567 : Debug : LoopStats: shortestLoop: 198 longestLoop: 6514901 avgLoopDuration: 418.40 loopCounterMax: 151515 loopCounterLast: 70899
152567 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 70899/2132/6/92.48
181677 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 20040 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
182566 : Debug : LoopStats: shortestLoop: 198 longestLoop: 6514901 avgLoopDuration: 464.99 loopCounterMax: 151515 loopCounterLast: 63867
182567 : Debug : Scheduler stats: (called/tasks/max_length/idle%) 63867/2132/6/92.48
I can force 1 channel on 2.4Mhz, also, channel width, and only 2.4Mhz. What would you suggest?
Posted: 15 Jun 2021, 21:26
by Tebogo
Did some research for you:
4 different type of ESP8266:
Works with ESP_Easy_mega_20210503_normal_ESP8266_4M1M
- ESP Board
ESP Chip ID: 11037035 (0xA8696B)
ESP Chip Frequency: 80 MHz
ESP Chip Model: ESP8266
ESP Chip Cores: 1
ESP Board Name: PLATFORMIO_ESP12E
Storage
Flash Chip ID: Vendor: 0x20 Device: 0x4016
Flash Chip Real Size: 4096 kB
Flash IDE Size: 4096 kB
Flash IDE Speed: 40 MHz
Flash IDE Mode: DIO
Flash Writes: 10 daily / 14 boot
Sketch Size: 940 kB (2128 kB free)
Max. OTA Sketch Size: 1019 kB (1044464 bytes)
OTA possible: true
OTA 2-step Needed: false
SPIFFS Size: 934 kB (844 kB free)
Page size: 256
Block size: 8192
Number of blocks: 116
Maximum open files: 5
Maximum path length: 32
- ESP Board
ESP Chip ID: 10704639 (0xA356FF)
ESP Chip Cores: 1
Storage
Flash Chip ID: Vendor: 0x68 Device: 0x4016
Flash IDE Mode: DIO
OTA possible: true
Page size: 256
Block size: 8192
Does not work with ESP_Easy_mega_20210503_normal_ESP8266_4M1M
Does work with ESP_Easy_mega-20190226_normal_ESP8266_4M.bin
- ESP Board
ESP Chip ID: 15578486 (0xEDB576)
ESP Chip Cores: 1
Storage
Flash IDE Mode: DIO
Flash Writes: 13 daily / 15 boot
OTA possible: true
Page size: 256
Block size: 8192
- ESP board
ESP Chip ID: 6109418 (0x5D38EA)
ESP Chip Freq: 80 MHz
Storage
Flash Chip ID: Vendor: 0xC8 Device: 0x4016
Flash IDE speed: 40 MHz
Flash IDE mode: DIO
Flash Writes: 40 daily / 40 boot
Sketch Size: 793 kB (2276 kB free)
SPIFFS Size: 934 kB (860 kB free)
On the picture: the first one is the left one, the second is the middle one, the third one is the right one, the fourth one is build in, but looks like the third one.
Hope it helps to find out the differences why two work, and two not, and how to fix this..
Posted: 15 Jun 2021, 23:38
Just to be sure... have you tested with reduced WiFi TX power?
Can you make a better close-up of the one that doesn't work?
I have never seen a module like that.
It does look like a beefy AMS1117 as voltage regulator, but I don't see a lot of other larger capacitors.
Only one larger yellow one.
Where is the antenna located?
Also I would like to see a close-up of the parts next to the ESP chip.
On the right I do see a crystal, but since I have no clue where the WiFi antenna is located, I wonder if there are parts interfering with the antenna tuning.
Can you also get a close-up of the parts surrounding the 3v3 regulator? (the chip next to the CH340 and the yellow capacitor)
If you look at the NodeMCU board, you can see there are quite a few larger capacitors next to the voltage regulator.
When I design a board for myself, I always use 100 - 330 uF on 3v3 and a 22 uF close to the ESP.
Also 100 nF capacitors as close as you can next to the Vcc and GND pins of any chip like the CH340, ESP, flash chip.
On the right board I don't see as many capacitors as I would like to see.
N.B. they are also missing on the 'middle' board, but those fake Wemos D1 mini boards without shield over the ESP are notorously bad. It really is a wonder that board isn't causing issues for you.
They have a really underpowered voltage regulator (often max. current of 150 mA) and missing some beefy capacitors.
Also these boards lately have really bad USB connectors which are really picky on what USB cable you're using.
