How to write OLED status to variable
marstu
#1 Post by marstu » 08 Jun 2021, 21:30
Hi all,
I am using the following rule to switch my OLED on and off:
on Clock#Time=All,20:00 do //will run once a day
 oledframedcmd,display,off
on Clock#Time=All,06:30 do //will run once a day
 oledframedcmd,display,on
Which is working perfectly, now I would like to write the status of the display to a dummy device. Due to my age I am to lazy to walk in to the living room to find out if the display is off :D I thought the following would help, but didn't:
on Display_XYZ#state=off do
 taskvalueset,6,1,1
or
on displayoff do
 taskvalueset,6,1,1
Any idea how to solve?
Thanks and greetings
marstu
ESP8266, ESPEasy (always latest mega release in use :D ), and Domoticz (only beta versions :) )
Re: How to write OLED status to variable
#2 Post by Ath » 08 Jun 2021, 22:06
There are 2 challenges with this:
- You can't read the state of the display
- The OLED should not be kept on for prolonged times, as its content will burn in, most likely within a few months, depending on the brightness level
Well, now let's try and find solutions for that.
What needs to be done:
- Keep the current state
- Turn the display off between 20:00 in the evening and 06:30 in the morning
- Turn off the display after it was turned on
Looking at those requirements, I'd say that the 'keep off during the night' task can be skipped if the display is turned off after being on for some time. But that's just my opinion ;)
There are multiple ways to turn on the display, simplest is to use the Display button option, and set a reasonable time after which it is turned off again
For that button to activate, there can be an actual button to be pressed, or, more conveniently, a Pir sensor that is triggered when someone approaches the unit. Not even any rules needed here.
If you don't want to activate the display during the night-hours, all these actions can only be controlled from rules.
Keeping the state can be done in internal variables, to be set using the LET command, or in a Dummy device, that can hold up to 4 (numeric) values, using the TASKVALUESET command.
Using the most complex options, off during the night, Pir sensor turns it on, I'd go for these rules:
on PIR#State=1 do // Most PIR sensor give a high signal when activated
  AsyncEvent,displayon
on displayon do
  if %systm_hm% < 20:00 and %systm_hm% > 06:30 // Only when we are awake
    OledFramedCmd,display,on
    TimerSet,1,60 // Keep display on for 1 minute, then turn off
on displayoff do
  OledFramedCmd,display,off
on rules#timer=1 do
  AsyncEvent,displayoff // Timer turns display off
Disclaimer: Untested code.
#3 Post by Ath » 08 Jun 2021, 22:16
This solution is not keeping a state (yet), but I'll update that post later to add that if needed, as currently the display is always turned off after 1 minute, so no need to worry if it is turned off in time.
marstu
#4 Post by marstu » 08 Jun 2021, 23:07
Ath wrote: 08 Jun 2021, 22:06 There are 2 challenges with this:
What a pity.
I know, that's the reason why all are already only switched on for a few hours
Would be great, when there is one.
I already ordered some PIRs, either my problems will be solved here in the forum or I have to buy some new toys :D Great!
This would be ok.
on displayon do
on displayoff do
on rules#timer=1 do
I decided to go with this option, great idea, I will book some hours at the weekend to setup this new toy. Thanks a lot for this great idea.
marstu
#5 Post by marstu » 08 Jun 2021, 23:08
Ath wrote: 08 Jun 2021, 22:16 This solution is not keeping a state (yet), but I'll update that post later to add that if needed, as currently the display is always turned off after 1 minute, so no need to worry if it is turned off in time.
I'll let you know next week, but I guess this should solve my "problem".
marstu
#6 Post by marstu » 10 Jun 2021, 22:17
Hi Ath,
I slightly adapted your code and it seems to work, but need some further testing.
on displayon do
on displayoff do
on rules#timer=1 do
With yours and one of my other roles, the ESP seems to restart every 3 to 4 min. After deleting this rule:
on System#Boot do
  timerSet,1,60  // Set timer 1
on WiFi#Disconnected do
on WiFi#Connected do
  timerSet,1,0  // Clear timer 1
On Rules#Timer=1 do
  Reboot
endOn
The ESP is at least now up for 112 min
This is my slightly changed one:
on displayon do
on rules#timer=1 do
on displayoff do
My PIR is currently a way to sensitive and some adjustments are required, but this will be done at the weekend.
KR marstu
#7 Post by Ath » 10 Jun 2021, 22:26
I don't know why you would want to reboot if Wifi is away for > 60 seconds? Shouldn't be needed, I think.
If the display timer interferes with your Wifi check timer, then one of them should be using another timer, there are 8 available.
Now using timer 2:
on displayon do
    TimerSet,2,60 // Keep display on for 1 minute, then turn off
on rules#timer=2 do
on displayoff do
I have opened a new PR #3684 that adds the option to send events on Display On/Off and change of Contrast. I'm thinking if I should add an event on page-change, but that'll be a bit more complex
marstu
#8 Post by marstu » 10 Jun 2021, 23:39
Ath wrote: 10 Jun 2021, 22:26 I don't know why you would want to reboot if Wifi is away for > 60 seconds? Shouldn't be needed, I think.
Because downstairs I have really a bad WIFI connection with the latest MEGA version, that was the reason for this rule, and it is quite helpful.
Ath wrote: 10 Jun 2021, 22:26 If the display timer interferes with your Wifi check timer, then one of them should be using another timer, there are 8 available.
Now using timer 2:
on displayon do
on rules#timer=2 do
on displayoff do
Ah, again I learnt something new, thanks. Will try tomorrow, or at the weekend, and let you know.
#9 Post by TD-er » 10 Jun 2021, 23:46
If the WiFi reception is worse, please increase TX pwr to 20.5 dBm and check sending with highest TX power.
Setting to B/G mode will allow you to actually send with more TX power compared to "n" network. (20.5 dBm can only be achieved with 'b', which we don't use, so max. is 17 dBm)
marstu
#10 Post by marstu » 11 Jun 2021, 00:30
TD-er wrote: 10 Jun 2021, 23:46 If the WiFi reception is worse, please increase TX pwr to 20.5 dBm and check sending with highest TX power.
I already ticked sending with highest TX power, but will also change to 20.5 dBm.
TD-er wrote: 10 Jun 2021, 23:46 Setting to B/G mode will allow you to actually send with more TX power compared to "n" network. (20.5 dBm can only be achieved with 'b', which we don't use, so max. is 17 dBm)
Ok, will try B/G mode as well.
marstu
#11 Post by marstu » 11 Jun 2021, 15:51
marstu wrote: 10 Jun 2021, 23:39
Now using timer 2:
With the change in timer it looks like that everything re the PIR is working as it should. The display switches on, when the PIR detects something and went of after 1 minute. Furthermore, there are no reboots any more. So, thanks for your help.
marstu
#12 Post by marstu » 11 Jun 2021, 15:52
marstu wrote: 11 Jun 2021, 00:30
With these changes WIFI seems to be a little more stable, slower, but stable.
