Problem flashing Adafruit Feather Huzzah ESP8266
Posted: 10 Oct 2021, 17:29
Hello!
I got an Adafruit Feather Huzzah ESP8266 module which I can't flash it using the ESP Easy Flasher (0.04.007). The COM-port does not show up (see attached image).
- I'm using Windows 10.
- I can find the ESP8266 module under "Manage Devices" as a COM-port (Silicon Labs CP210x USB to UART Bridge)
- I have successfully flashed the ESP8266 module using Arduino IDE (using a simple LED-blink "sketch").
- I've tried to run ESP Easy Flasher as administrator
- I've tried removing the "settings" folder for ESP Easy Flasher
