Sonnoff DUAL R2
Posted: 11 Mar 2022, 17:25
I bought a Sonoff Dual R2 module. As far as I know it uses an 8285 processor. I have a few questions.
- what is the pinout, i.e. GPIO`s used for relay1 and relay2, the onboard LED indicating WiFi connection and the LED indicating that the device is on? The latter is probably not connected to any GPIO but is powered directly from the power supply;
- what is the GPIO for the onboard button?
- the module has free solder pads marked as Button0 and Button1. What GPIOs support them? Can they be used to connect an additional button and/or an additional LED diode directly to the module without an additional transistor?
- After soldering the contacts to connect the USB/UART programmer, how to force the programming mode?
- which FW should I compile? Should it be env:normal_ESP8285 with its own Custom.h or the default values will suffice. I just need to use relays, 2 LEDs and 2 switches (as long as it is possible to use the mentioned Button1 and Button2 solder pads).
Thanks in edvance for advice !
