[P087] SerialProxy add serialproxy_writehex command and add support serial send hex(serial write hex) and support serial
oiio
#1 Post by oiio » 30 Mar 2022, 13:20
Changed files:
https://github.com/letscontrolit/ESPEasy/pull/3980
ESPEasy 4MB :
https://github.com/oiiooiiooiio/ESPEasy/releases
Read HEX usage:
Device: Communication - Serial Proxy [TESTING]
Rules Set :
On !Serial#v* do
  LogEntry,%eventvalue%
Send hex usage:
serialproxy_writehex_tr,F11FE22EB66BA88A000786000000000303FA
UART0 on GPIO1 (TX0)
serialproxy_writehex_tr,1,F11FE22EB66BA88A000786000000000303FA
UART1 on GPIO2 (TX1)
serialproxy_writehex_tr,2,57AB000208000004000000000010
oiio
Re: [P087] SerialProxy add serialproxy_writehex command and add support serial send hex(serial write hex) and support se
#2 Post by oiio » 30 Mar 2022, 13:30
ESPEasy DIY Fingerprint Keyboard (Programmable Keyboard)
#3 Post by TD-er » 30 Mar 2022, 13:49
I did add a few comments on your PR, have you seen those?
oiio
#4 Post by oiio » 31 Mar 2022, 16:22
rules set:
rules.zip
(1.21 KiB) Downloaded 127 times
ESP Easy Loads a settings file:
config.zip
(566 Bytes) Downloaded 121 times
hex data_protocol:
FPM383C+CH9329芯片串口通信协议.zip
(1.44 MiB) Downloaded 129 times
tool:
send hex data_protocol_get_checksum.zip
(328.9 KiB) Downloaded 121 times
#5 Post by Ath » 31 Mar 2022, 16:58
Can you share a link to that fingerprint sensor device? Haven't been able to find that yet. (and I can't read the non-English text on the images :? )
oiio
#6 Post by oiio » 01 Apr 2022, 01:24
Ath wrote: 31 Mar 2022, 16:58 Can you share a link to that fingerprint sensor device? Haven't been able to find that yet. (and I can't read the non-English text on the images :? )
https://h.hlktech.com/Mobile/download/fdetail/177.html
https://translate.google.com/?hl=EN&tab ... en&op=docs
oiio
#7 Post by oiio » 01 Apr 2022, 02:19
TD-er wrote: 30 Mar 2022, 13:49 I did add a few comments on your PR, have you seen those?
thanks
Restore old settings :
https://github.com/letscontrolit/ESPEas ... d9354abd0c
Users browsing this forum: Ahrefs [Bot] and 85 guests
