Temperature and level sensor integration
Posted: 05 Jun 2022, 08:48
by oasisone
Hello, i've got a level and temperature sensor that transmits its data via serial interface i can read it via the code below but i wanted to implement it in the espeasy so i can make some rules and have statistics online and show the data on a display.
i was thinking of 2 possibilities:
1. manage to implement this code in the espeasy so i could use it directly but i am new to this so i would need some links with documentation
2. read it on a simple arduino board and then output the serial and use it in the espeasy for further processing here there is some more documentation online so i think i might manage
Any propositions on how to tackle this?
// Extracted from http://hack4life.pbworks.com/Arduino%20Solar%20Water%20Heater%20Sensor
const int inPin = 22;
void setup() {
  pinMode(inPin, INPUT);
  Serial.begin(9600);
#define TIMEOUT 50000
#define MARK_HEADER 7000
#define SPACE_HEADER 3000
#define MARK 500
#define SPACE_ONE 1500
#define SPACE_ZERO 600
int expectPulse(int val){
  unsigned long t=micros();
  while(digitalRead(inPin)==val){
    if( (micros()-t)>TIMEOUT ) return 0;
  return micros()-t;
// temp in celsious and level goes from 0 to 3
bool readTempNLevelSensor(char inPin, char &temp, char &level){
   byte data[5]={0,0,0,0,0};
   unsigned long val1;
   unsigned long st=micros();
   val1 = expectPulse(HIGH);
   if(val1>MARK_HEADER){
     val1 = expectPulse(LOW);
     if(val1>SPACE_HEADER){
       int c=39;
       for(;c>-1;c--){
         if(val1<MARK){
          if(val1==0){
            //Serial.println("Mark error 0");
          if(val1<SPACE_ZERO){
            //0
            //data[c>>3]|=(1<<(c & B111));
          }else if(val1<SPACE_ONE){
            //1
          }else{
           //Serial.print(val1);Serial.println(" Space error");
         }else{
          //Serial.println("Mark error");
       // Each reading should not take more than 70ms (use time to detect errors)
       if(micros()-st<70000){
         temp=data[3];
         level=data[2];
         //Serial.print(data[3]);Serial.print(" ");Serial.println((data[2]));
         //Serial.print(data[4],HEX);Serial.print(" ");Serial.print(data[3],HEX);Serial.print(" ");Serial.print(data[2],HEX);Serial.print(" ");Serial.print(data[1],HEX);Serial.print(" ");Serial.println(data[0],HEX);
         return true;
   return false;
void loop() {
  char temp,level;
  if(readTempNLevelSensor(inPin, temp, level)){
    Serial.print(temp,DEC);Serial.print("c ");Serial.println(level,DEC);
Re: Temperature and level sensor integration
Posted: 05 Jun 2022, 08:57
by Ath
You could try to receive the data using the Serial server, using the latest improvements in this pr, so it can be processed using rules, without a web-client connected.
You will need a Github account to be able to download the bin files from the Github Actions build (although the build partially failed, most build results are available).
