TaskValueSet,TASKnr,VARnr,Value
gibus17
#1 Post by gibus17 » 04 Jul 2022, 18:18
HELLO,
I created a virtual device
value 1: calculatee
value 2: effectuee
if to update it I use
taskValueSet,9,1,2515
taskValueSet,9,2,3025
It's OK
However, if I use
taskValueSet,DUREE_filtration,calculatee,2515
taskValueSet,DUREE_filtration,effecuee,3025
it does not work
please show me my mistake
Re: TaskValueSet,TASKnr,VARnr,Value
#2 Post by Ath » 04 Jul 2022, 19:22
Where did you type those TaskValueSet commands?
And is there anything more around that code? (Please wrap your code using code tags for readability, using the '</>' button in the forum toolbar)
Wat version of ESPEasy is installed on your device? (Most explicit is the name of the .bin file you flashed)
And I assume the typo is 'effecuee' in because you re-typed it, not copy/pasted?
gibus17
#3 Post by gibus17 » 07 Jul 2022, 16:44
excuse english it's a google translation
I don't remember the .bin file
I realized the flash in January 2012 with this version:
ESP_Easy_mega_20210114_normal_ESP8285_1M
I am looking to change the code made at the time and use the name and value of the virtual device
Here is the code I am trying. I run using in the "TOOLS" tab
on filtration do
taskValueSet,FILTRATION,calculee,2020
taskValueSet,FILTRATION,effectuee,4500
The virtual device is called "FILTRATION" and it has two values: calculatee "and "effectuee"
The command returns "OK" but does not change the values
Thank you for helping me
#4 Post by TD-er » 07 Jul 2022, 18:09
Can you check on the Tools->Advanced page to make sure this checkbox is checked:
[x] Allow TaskValueSet on all plugins:
And when not sure about the syntax/names of the task and task values, you can always use the task index and taskvalue index (both starting at '1')
gibus17
#5 Post by gibus17 » 08 Jul 2022, 12:05
My current code uses indices. But they make code less understandable than name and value. It is for this reason that I seek to use them.
In the page "tools ->Advanced" I can't find
"Allow TaskValueSet on all plugins:"
#6 Post by Ath » 08 Jul 2022, 12:12
Then you are on an old(er) version of ESPEasy that doesn't yet have that setting. Please update to the latest version, available from the Github releases page
